Results 1 to 7 of 7
Thread: problems?
    Registered Member Two Rings darby ofool's Avatar
    Feb 04 2005
    96 cbr 900rr, 91 blazer and i had a 99 m3 but sold it for the s4
    Nevada
    problems?
    i just bought a 90 audi 200 turbo and was wondering what problems they have if any at all
    Jan 21 2005
    WNY
    Pretty solid car...There are some electrical glitches with the instrument cluster, mainly lighting...The engine is pretty much bullet proof. Two knock sensors, the most updated CIS fuel injection system (CIS III). The typical suspension parts go bad...(rear transverse links, and assoicated bushings, front tie rods, ball joints, ect,ect) But that is routine service stuff. The climate control can sometimes go on the fritz (mainly a problem with the 5000's). Otherwise, excelent car!!! You should be very happy.!
    Registered Member Three Rings
    Feb 12 2004
    '04 Ram 3500 CTD, '71 Bronco
    Breckenridge, CO
    Deffinately a solid car. I think the 2.2 20v is about the best engine Audi has made. They do have the electrical problems mentioned above, but most (not all but most) can be easily and cheaply fixed with basic skills and tools.
    One thing to look at is the breaks. I'm not sure, but I think the '90 had the UFO disks which can be expensive to replace.
    The only major problem I know of with them is the headlights of lack of headlights. A Euro light conversio is easy but expensive, but do yourself a favor and at least install some aftermarked fog lights under the bumper.
    Rob
    --Rob
    Jan 21 2005
    WNY
    Well, if it's a 1990 200TQ, it still has the 10v turbo. The 1991 200TQ had the 20v turbo and the UFO brakes.
    Yep. Those lights suck. You could also swap the lights out of a 100 (or 5000s). They work 100 times better, but don't look nearly as good as the "turbo" lights (same ones on the 1986-88 5000CS turbos, and of course the 200's.) The grill needs to be changed as well (the grill for the 100's has the smaller rings on it) All this can be done for probably around a $100.00, see your local boneyard.
    Feb 04 2005
    Nevada
    thanks for the info
    and i do have to agree the headlights aren't the best
    Veteran Member Four Rings maxh2o's Avatar
    Apr 13 2004
    B5S4,C2avant,Cgt,UrQ
    San Francisco
    Just curious, whats the weight and front:rear distribution ratio of your car?
    http://www.audizine.com/gallery/data...70780_copy.jpg
    Dominating the fast lane since 1984.
    Feb 04 2005
    Nevada
    i dont know i bought it for my girlfriend as a daily driver
