Results 1 to 18 of 18
    Veteran Member Four Rings TofuShop's Avatar
    Aug 24 2010
    o2 Spacer options
    Hi guys,
    I ordered a Eurocode HFC and was looking at o2 spacer options to prevent throwing a CEL. Below are the only ones i've been able to find. Can you guys comment on which you are using or which is better? not sure if our o2 sensor is made by bosch or not. on my old car, i used a spacer similar to the 034 motorsport unit and it worked great. i've never seen one like the one rai motorsport sells
    thanks
    http://www.raimotorsport.com/RAI-J-P...p/11620vib.htm
    (non-bosch)
    http://www.034motorsport.com/fabrica...s-p-18885.html
    (bosch)
    http://www.034motorsport.com/fabrica...s-p-18938.html
    Aug 24 2010
    no one? could someone at least tell me if our o2 sensor is a bosch unit or not?
    May 16 2009
    Maine aka Canada Jr.
    yes its a bosch (at least on my 3.2 a5) and I was running the 42 draft design j-type spacers when i had my custom downpipes on.
    Mar 02 2007
    Fresno, CA
    Why not get a proper tune (see: APR stage 2) that eliminates the CEL and gives you the added benefits of more power and smoother delivery?
    Established Member Two Rings valida4's Avatar
    Mar 03 2010
    New York, NY
    Maybe he needs the O2 sensor reading to pass emissions.
    2010 Phantom Black Pearl A4 2.0 6MT :: Premium+ :: Nav :: Sports Package :: H&R Spacers :: S-Line Stone Guards :: APR Stage 2+ :: Podi :: aFe
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by valida4 View Post
    Yeah, maybe... but he didn't say that.
    Aug 24 2010
    Sorry, yes, i need the spacer to pass emissions. But, i am also scheduling an appt to get an APR flash to take advantage of the Spring special they have going on.
    Thanks for the help, i'm going to order the 034 spacer for Bosch units.
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Quote Originally Posted by Alkivar View Post
    I remember you mentioning this spacer a while back. Do you no longer have the custom downpipes because this spacer failed to work long-term or did you get rid of them for another reason?
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Jun 26 2009
    Bremerton WA
    I installed a Eurocode HFC a little over a week ago. I popped a P0420 code (second O2 out of tolerance) fairly quickly (not unexpected). I know that once I push software it would go away but it would still show up as Emissions not ready if scanned. Decided to give RAI spacer a shot. I ordered over the weekend. Monday, I got the shipped notification which was nice. I'm not far away but was surprised to have it on my doorstep Tuesday evening (UPS ground). Excellent build quality. I installed it and cleared my CEL, I have only gotten one shakedown drive to try and set the CEL again. I wish it had came with a guide to what orifice to install for different applications. If it helps I went no orifice installed. If this fails then I will record the O2 voltage reading and work my way down the sizes.
    VMR 710's, APR software, Eurocode HFC
    Veteran Member Three Rings rippin'av's Avatar
    Nov 18 2009
    '00 S4 Stage 3, '05 LR3, '08 ML63 AMG, '02 BMW 1150GS, '71 BMW R75/5
    CA
    Quote Originally Posted by van462 View Post
    Sorry, little bump to see how this has held up with some more miles on it. I'm going to be putting the 034 HFC on and need a spacer. I don't want to get the APR testpipe file so I will need a solid spacer to pass emissions. Visual inspection is another issue but I'm not as worried about that as the sensor, etc.
    Options:
    RAI
    Stratosphere
    Who else makes one that is proven effective?
    2015 Jeep Unlimited Rubicon
    2000 S4 6MT ASP Stage 3
    Jun 26 2009
    Bremerton WA
    Installed in June and even without putting any of the available orifices (even more gas reduction) I have yet to have any codes pop up. I am really impressed at the RAI hardware its quite a value.
    Active Member Two Rings AlexDD's Avatar
    Jun 28 2012
    Atlanta GA
    This is the one i will have installed on my testpipe. Thanks for the heads up.
    Ps. It is the spacer as the one for the GTI, right?
    2015 Sepang blue
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    I might update my Spacer to the RAI version one of these days for S&G's.
    Another good thread on spacers here:
    http://www.audizine.com/forum/showth...-with-catalyst
    Tschüß!
    Šave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hüper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/ÜSS • Hankook V12's • ST-40 BBK
    Deactivated Three Rings
    Aug 08 2011
    Fairport, NY
    Veteran Member Three Rings jordancl's Avatar
    Jun 29 2010
    MA 01230
    I've had my strat 90* spacer on for over a year with no issues, although it took a few weeks after install to stop getting a cel
    Aug 08 2011
    Fairport, NY
    Quote Originally Posted by jordancl View Post
    Ours are the same as Strat used to sell
    Nov 18 2009
    CA
    I need one of those 90 degree deals! Any chance for a GB?
    Jun 03 2009
    Raleigh, NC
    Yeah, I only get a CEL when I'm doggin' it and let off the gas super quickly/and or brake to slow down fast.
    Tschüß!
    Šave
