Results 1 to 29 of 29
    Active Member Two Rings gmn06s4's Avatar
    Feb 28 2011
    nj
    LED city lights that actually work for B7 with no added separate resistor
    I have B7 S4 with the multicolored DIS (not the all red one) and I was looking for LED city light replacement bulbs for awhile and everyone I found required a separate resistor to be installed for the error code. I just installed the HPX 194 White LED bulb yesterday and they look great. The bulbs are very bright. They simply just pop in and do not throw an error code what so ever. Just figured I would post the link for anyone who was looking. Just make sure you select the CANBUS version which has the built in resistor. The link is below, enjoy.
    http://www.highperformancebulbs.com/hpx194ledbuw.html
    Dec 28 2005
    NY/NJ
    Current: 2024 SQ7, 2021 RS5
    Senior Member Two Rings PolishPete's Avatar
    May 12 2008
    IL
    Quote Originally Posted by Kyokio View Post
    Did you order the 5 LED SMT? Do you know if the 1 LED that's just below it will work?
    Thanks for the links folks.
    2008 A4 2.0T Quattro Special Edition / 35% Suntek Tints / APR Software / (Lease Ended)
    2007 RS4 / 35% Tints / APR Tune / More To Come
    Dec 28 2005
    NY/NJ
    Quote Originally Posted by PolishPete View Post
    i ordered the 1 led as recommended by one of the rs4 members and its works perfectly..
    original link is here
    click me
    May 12 2008
    IL
    Thanks.
    Established Member Two Rings Sebap3's Avatar
    Sep 22 2010
    B7 S4
    Brooklyn
    Quote Originally Posted by gmn06s4 View Post
    Ordered these and they work great with no bulb out light. I also ordered this: http://www.highperformancebulbs.com/hpxde11pland1.html for the day time running lights to use instead of regular resistors and they work great too but I ended up modifying them.
    2007 S4: SB/Black, 6 Speed, (2011 LED) Nav, DTM Trunk lip, TT-S Steering wheel, (RS4 shifter, brake handle, pedals), KW V3 coilovers, 034 Adj. Control arms, Hotchkis RS4 F/R sway bars, VMR 713 w/ Michelin PSS, RS4 Magnaflow, Piggies, 60% H.O. Ceramic tint, Carbon fiber valance, HID Fogs, Led: plate, interior, tail lights. E-Code head lights, LED city & DRLs, Deval CF Splitter, JHM tune, Apikol rear diff. mount, JHM SS, JHM LW F/R rotors with Stoptech pads.
    Sep 13 2008
    Western Chicago Burbs
    FYI, all S4's will have multi color DIS screens. just for future reference.
    Senior Member Two Rings JayNYS4's Avatar
    Oct 06 2006
    New York
    OP: Do you have a pix you can share? Thinking about getting a set...
    2006 B7 S4 Dolphin Gray
    2004 Infiniti G35 Coupe 6MT [SOLD]
    Dec 28 2005
    NY/NJ
    Quote Originally Posted by JayNYS4 View Post
    here's a pic of the autoillumination one's as a reference.
    Oct 06 2006
    New York
    [QUOTE=Kyokio;6400009]here's a pic of the autoillumination one's as a reference.
    Looks great! I just ordered from autoillumination.
    Veteran Member Three Rings Mr. Merk's Avatar
    Sep 20 2007
    1988 911 Carrera 3.2
    NW Arkansas
    any luck for license plate bulbs?
    13 S4 3.0T | Her daily driver
    88 911 Carrera 3.2 | My fun car
    87 S-10 383ci drag truck | Her fun car
    05 Sierra 5.3L SLT Crew | My daily driver
    14 Jeep Wrangler Rubicon | Her other fun car
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Sorry for going off track here but this pretty much means that if you get any LED bulb in the car you will need a resistor?? Like replacing the blinker bulb with LED. What size resistors do we need?
    -02 F'in Silver. GT2560/s AWE, ER/s RS3 Wheels, KW/s and every other typical S4 upgrade.
    Established Member Two Rings -yz-'s Avatar
    Sep 29 2010
    Washington, DC
    Bumping this old thread because I just spent an hour searching LED City Light replacements. So can anyone else confirm that these LED's http://www.highperformancebulbs.com/hpx194ledbuw.html are simply plug n' play without screwing around with resistors? Secondly, if they are plug n' play can someone confirm that they didn't melt their damn headlights?
    Also, if there are plug n' play (no code) LED license plate lights... please share the link. Not looking to spend $50 for a pair of $5 dollar bulbs.
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Quote Originally Posted by -yz- View Post
    Not sure how much they are but ECS has licsense plate lights. i bought the whole kit so i dont know how much they are charging.
    Veteran Member Three Rings madkimchi's Avatar
    Sep 09 2009
    Bicycle and roller blade.
    Kent, WA
    bastards sent me a wrong bulbs. how annoying...
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    Give a pair of these ones a try. I use them on my MKV Jetta which is also sensitive to the bulb out warning: http://www.superdiscountleds.com/pro...ight-Bulb.html
    If you still get a bulb out warning with those bulbs then just throw a set of these resistors in. No wiring needed like most other resistor kits: http://www.superdiscountleds.com/pro...28pair%29.html
    Sep 09 2009
    Kent, WA
    employee/owner is being a total dbag right now. i hope he gets a flat tire soon.
    Veteran Member Four Rings slvrb7's Avatar
    Dec 28 2011
    2016 Polaris RZR 1000, 2016 Jeep Wrangler JKU, 2017 Range Rover, 2018 Land Rover Discovery
    North Texas
    My halogen bulb city light is melting my housing need leds that won't asap
    Kris
    Senior Member Three Rings dc2002's Avatar
    Jan 29 2007
    Roswell GA
    http://www.tunerdomes.com/index.php?...&productId=172
    Put these in over XMAS no recode or DTC's.
    May 08 2012
    Long Island/NY
    Quote Originally Posted by dc2002 View Post
    Tried the link and it didn't work :/
    Which ones did you get?
    Active Member Two Rings 08RS4's Avatar
    May 13 2011
    88 Mustang
    Texas
    Quote Originally Posted by xXDB89Xx View Post
    Link took me to "194CB3 ERROR CANCELING PREMIUM WEDGE (T10)"
    AKA: Slainte
    May 08 2012
    Long Island/NY
    I tried it again and worked thanks! Maybe site was under maintenance when I tried?
    Nov 09 2011
    Columbus, OH
    How are these working now that it has been 9 months?
    I have been browsing the various LED city light 194 options with built in resistors:
    -autolumination 1 LED 5050 model
    -your tuner dome ones ( http://www.tunerdomes.com/index.php?...Id=172&added=1 )
    -HPX http://www.highperformancebulbs.com/hpx194ledbuw.html
    I have A4 with stock bi-xenon's that turn, color DIS, and the 2 knobs for DRL etc.
    I'd love to get LED DRLs, but I see they require manual added resistors. I'd gladly pay someone in Central ohio to do the DRLs though haha :)
    Senior Member Two Rings S4nikator's Avatar
    Jun 29 2010
    British Columbia
    Just ordered the HPX DRL & City Lights from HighPerformanceBulbs.com... Hope they work!
    Apr 08 2014
    Hey guys just getting into the Audi scene now! I've done many LED replacements in my previous vehicles from my G35 to my 335xi. What are the bulbs that are each thing in the Audi? I have 09 B7 S4. So license plate,interior etc and what else i'm I missing? Is it the 194?
    Established Member Two Rings zacktexas's Avatar
    May 13 2017
    2006 Subaru Forester
    reviving this thread. i placed an order for two 11 watt super white 194's for my city lights from autolumination.com. order was placed on the 19th and i have yet to receive any tracking number. have also sent two emails regarding where the hell my tracking number is. are these guys scammers? out of business? i paid through PayPal and im about to look for a refund if i dont hear back from them within the next 3 days.
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    We have insane bright city LEDs that are 100% error free and ship same day from US with a tracking #:
    http://deautokey.com/product/city-le...its-audi-b6-a4
    -Clean white color temp
    -True Lifetime Warranty
    -Weekend Support
    -24/7 replies - normally within hours but always same day.
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
