Results 1 to 13 of 13
    Veteran Member Four Rings Mantvis's Avatar
    Jun 05 2009
    mk1 Audi TT 180hp, mk1 Audi TT 225hp, mk4 VW GTI
    Chicago, Naperville
    S-Tronic Launch Control
    Is it true that 6 speed S-Tronic has somewhat of a launch control? I have the 2003 TT
    I read through few forums, and Jason (hes on this forum just forgot his nickname) told me that i can do that.
    So i just wanted to ask how many of you tried this?
    It does seem to go to around 2.5k or 3k RPM's and i can get a decent launch.
    The question is, how safe or bad is it for my car?
    If you don't need both hands on the wheel, then you're NOT driving.
    Established Member Two Rings TTS-RQ's Avatar
    Nov 06 2008
    Marblehead
    I do the LC at every chance I can. That's why God made warranties.
    TTS-Roadster
    Ibis/ Black Nappa
    Prestige Pkg.
    APR Tuned
    AKA: Fissues
    Jun 05 2009
    Chicago, Naperville
    Quote Originally Posted by TTS-RQ View Post
    Im assuming you have mk2...
    i have mk1 2003, there is no more warranty...
    Senior Member Two Rings jza80's Avatar
    Dec 13 2006
    TTS Conv, R33 Skyline GTR, Suzuki B-King
    South OC, CA
    How do you activate launch control? I have a TTS, I did not see any reference to this in the OM. Thanks!
    Jun 05 2009
    Chicago, Naperville
    press brake pedal ,and the mash the throttle the rpms should go up to 3k i think
    Nov 06 2008
    Marblehead
    Come to a full stop,
    Put it in Sport or Manual,
    Turn off ASR and ESP by holding down the button until the Display says it's all off, (MY '10 or newer only one touch)
    Check yer mirrors,
    Push accelerator to the floor, (making sure it's reving freely and not grabbing the clutch)
    Dump the brake,
    Hang the fu@k on!
    TTS-Roadster
    Ibis/ Black Nappa
    Prestige Pkg.
    APR Tuned
    AKA: Fissues
    Dec 13 2006
    South OC, CA
    OK thanks!
    Senior Member Two Rings fcjasontt's Avatar
    Jan 26 2010
    Aurora, IL/ McHenry, IL
    Like I said its not really a "launch control" its more of a brake boosting/assisted launch (mk1 that is, not sure how mk2 is). You should build a PSI or two of boost. If you are really good you could two step it and use your ebrake to help hold the car. With FWD it may = Tire spin.
    AND LIKE A SAID, with your trans situation, I HIGHLY do not recommend it other then for reasons of doing a quick torque converter test.
    J'S REPAIR AND PERFORMANCE
    PLAINFIELD,IL 815.556.0027
    VAG-COM EQUIPPED
    Jun 05 2009
    Chicago, Naperville
    hmmmm, i can get about 6psi out of it
    Jan 26 2010
    Quote Originally Posted by Mantvis View Post
    well there ya go ;)
    VAG-COM EQUIPPED
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    In an attempt to bring this thread back to life.....
    I have a MKII TT, not a TTS, do I have LC? I sure hope so.
    Thanks in advance.
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Jun 05 2009
    Chicago, Naperville
    Quote Originally Posted by JGreen76 View Post
    Thanks in advance.
    damn i made this tread loong time ago :DD
    But here you go
    Jun 05 2008
    Houston, TX
    Cool, thanks man!
    PAST:
