Does anyone know how much brake fluid it takes to do a complete brake system fluid flush on the B7?
2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
05.5 B7 A4 longest running with no motor issues at 373whp
Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
