Results 1 to 20 of 20
    Established Member Two Rings TRON1C's Avatar
    Mar 03 2011
    2011 Audi A3 2.0TFSI
    San Diego, Ca
    Need help locating vagcom mods for my 2011 A3
    Title says it all. I'm was going to do some basic vagcom mods to my new a3, but i wanted to check to see if anyone knew of any mods that change the lights, indicators, or anything else specific to the a3's with the factory led headlights...
    Also, I noticed that my navi unit doesn't play dvd videos. Anyone know a way I can get around this to play videos, maybe off an ipod or the sd cards? I'd greatly appreciate it.. I really want to add video in motion to my car.
    2011 Lava Gray w/ iPod linked MMI Navigation
    Mods: 20/40 Tints, Vagcom
    Still Want: License plate delete, Stasis chipping, Radar Detector, Video Link through Ipod
    Established Member Three Rings SwampCat84's Avatar
    Nov 11 2010
    North Hollywood CA
    You can do the "Winking" VAG mod.. thats where the LEDs stay on in the front when you signal I believe... Theres also the "needle sweep" and you can VAG your tails to behave like the euro tails.. Thats what I need to get done to mine since I just got the Euro Tails put in... I would be interested to know if the codes are different for our 2011s because no one has been able to get into my car with their VAG yet... not even Audi! haha.. :)
    LAURA ELLIOTT
    • 2011 A3 2.0 TFSI FWD
    • VMR V710 Matte Black 19"x8.5" 235/35/19
    • Bilstein PSS10 Coilovers
    • Neuspeed P-Flow Air Intake
    • 15% Rear Tint, 50% Front Tint
    • Euro Tails
    • More to come!
    Mar 03 2011
    San Diego, Ca
    Yea, I just noticed that when in DRL mode, the LED's go off when you signal. Definitely gonna try to change that so the LED's stay while only the indicator blinks. I'm not familiar with the Euro style tail lights... what do those look like in comparison to the American ones?
    The things I want are mostly the basic mods: needle sweep, window rolldown/up w/ remote, all doors unlock w/ one click from remote, and remove seatbelt chime.
    Again, if anyone can think of anything else please let me know. I'll also update this after I get my car back to let you know what mods are available for the 2011 A3's.
    Established Member Two Rings a3driver11's Avatar
    Sep 13 2010
    LA
    I want to VAG it so there is no light on inside the annoying orange reflectors in the headlights to make it look more euro spec. This can be done right?
    A3, RS5, TTRS, R8, SQ5, Q7....kind of addicted.
    Mar 03 2011
    San Diego, Ca
    I don't really understand...
    Established Member Two Rings ppcchengf's Avatar
    Nov 23 2010
    Irvine, CA
    The DRL on during signal is vary easy to do, but if you have a newer version of the the vag-com the location of the check box is actually different from the older module, you just need to look for it. as for the needle sweep, i believe its not possible with the A3 instrument clusters.
    2011 Audi A3 FWD Ibis White, INduktion Motorsports Intake, KW V3 Coilover, GTI peddles,
    Stoptech 355mm Big Brake kit, BSH pendulum mount, Forge Twincooler, Forge Catch Can, AWE DV,
    APR Front & Rear Sway bar, Advan RZ-DF 8.5X18, Hankook Ventus V12 evo 235/40, Neuspeed Turbo Discharge pipe
    Mar 03 2011
    San Diego, Ca
    I'll see what is available on Wednesday when I take it in, and report back. If needle sweep isn't available I'll cry.
    Veteran Member Three Rings pretarion's Avatar
    Jan 02 2007
    Plano, Texas
    Needle sweep is not available in the States. It is available only for the S3 cluster, not for the standard A3.
    The one thing I was hoping to find out how to do is keeping the LED's on the same brightness as the DRL's when you turn on your main lights. Did you notice the LED's dim when turning on the fogs and headlights. I heard there was a way to keep it the same intensity as when you have the DRL's on.
    2012 Audi TTRS Carbon Package
    Active Member Two Rings cubantexan's Avatar
    Sep 20 2010
    Plano, TX, USA
    Quote Originally Posted by pretarion View Post
    Tim, is this you? I think that must be new to 2011 because my LED's stay at the same intensity when I turn on the lights on my 09.
    -Carlos
    Jan 02 2007
    Plano, Texas
    Hey Carlos,
    Yeah, it's me.
    That is strange. Mine dim when I turn on the main lights or foglights.
    Mar 03 2011
    San Diego, Ca
    So apparently the only things they could do on my car was emergency braking and remote controlled windows... I guess those two are already in the car, they just need to be activated. He also said there was a message in there that said "More to come soon" or something like that, so hopefully more options will be available in the coming months.
    My brothers A4 was much easier though, they gave him everything: seatbelt chime, needle swipe, indicators, led intensity...
    Sep 20 2010
    Plano, TX, USA
    Hey Carlos,
    Yeah, it's me.
    I stand corrected Tim. It does dim. I will have to look into that.
    Sep 20 2010
    Plano, TX, USA
    Quote Originally Posted by TRON1C View Post
    Seat belt chime can be turned off.
    Mar 03 2011
    San Diego, Ca
    Quote Originally Posted by cubantexan View Post
    Perhaps with longcoding, but it's not a native setting yet.
    Jan 02 2007
    Plano, Texas
    I inquired about the LED's staying the same brightness when turning on the foglights from a website in the UK.
    This is the response I got.
    I would love to see if it works, but don't have a Vagcom.
    Can someone try this out?
    09 Cent Elect
    Coding
    long coding helper
    Byte 24
    bit 0 to 6 DRL Dimming decimal value % 92 *1 = 92%
    bit 7 DRL as postion lights checked
    change the number to 100
    it is a number x 1% = brightnes percet
    eg 100 x 1% = 100%
    retick bit 7 box again
    if you want your rear lights with the drls add 1 to the byte 18 bit 7
    eg my TT is 58 LED drls BiZennon i change it to 59
    i now have all side lights with DR
    You need to change the digit on the top line long coding as there is no option with the helper
    use vcds 10.3 but I use the new VCDS 11.2 download
    Sep 20 2010
    Plano, TX, USA
    I will try it tomorrow.
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    I was able to get the seat belt chime off and the Windows to roll down. Had to reference a thread from Vortex on the MK6 to get it right for the Windows. What you do is make the option to roll down the windows with the remote become available in the DIS and then activate it there.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Jun 08 2011
    Oslo, Norway
    Did it work?
    Jul 11 2011
    If you have a newer version of VAG-COM position of the box is really different from the old module, you pick. such as scanning a needle, I think it is not possible with groups of instruments A3.
    Feb 02 2011
    India
    BUMP! and new codes lately?
