Page 3 of 6 FirstFirst 12345 ... LastLast
Results 81 to 120 of 218
  1. #81
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Didn't David and Greg make ~300awhp on 440ccs? Im very doubtful about a K04 maxing out 440s
    Not sure what size injectors Greg/David/Charlie were running when they all made 300-330whp on race gas with their Elim kits.
    FT is not a K04, it is basically a hybrid that flow like a GT28r and GT2x.
    BTW just look at Mike's(Jet Jockey's) old setup, that was considered a K04.
  2. #82
    Feb 08 2011
    Do you really think REVO corporate will make a one-off file? That is what will happen when you 'tweak the timing maps' for the GTseries file. They won't do it.
    It wouldn't have to be a 1 off file if they then turn it into a file that can be sold to the public. It sure wouldn't be the first time it happened. I had them do a BT tune for a 2001 with a Elim kit when they did not offer one yet.
    It just depends on who asks them to do it and if they are willing to spend a little time tweaking the timing map curve.
    Quote Originally Posted by a4darkness View Post
    I should have said, "inappropriate in it's OST form / as it's readily available for a FT"
    Like Ecode? Doesn't really seem like something they'd be interested in though... don't see too much of them anymore.
    Who am I forgetting?
    Yes Ecode. I even suggested to Doug(slappy) that I would be willing to talk to Ecode, GIAC and 034 about doing a FT tune.
  3. #83
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by M-Hood View Post
    It woudln't be a 1 off file if they then turn it into a file that can be sold to the public. It wouldn't be the first time it happens. I had them do a BT tune for a 2001 with a Elim kit when they did not offer one yet.
    2011 is a much different business environment than 2001 for the B6 A4. They won't do it.
    -Doug
  4. #84
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    Someone (dealer) should buy maestro and make a perfect file for the FT, then call tapp and ask for a group buy on the suite at a lower cost, from there share/sell the FT file with the end users...then you have a great file with all the added benefits of maestro...
    A3 8V | 10.89@129 | Boss700 | Eurodyne
  5. #85
    Feb 08 2011
    That 2001 was the year of the car not the year I had it done. lol
  6. #86
    Senior Member Two Rings lave3k's Avatar
    Apr 30 2009
    03 A4 1.8t, 03 Honda 954rr
    FTC, Colorado
    The duty cycle is pretty nice on the 440's, with a 200g/s car without water methanol it hits about 80% peak. At 210+ g/s things get into the mid/high 80's. Target AFR is the huge factor here and is dependent on tune/octane/ambient temp etc. To move beyond this point you really need to get around rising IAT's particularly in 90 degree heat, if water/methanol is used then you're supplementing your injectors and they'd be more than adequate.
    The 440's work very well and are an all around great value, the 550's are more advanced and if cost is not a barrier than they would work quite well as well. The tune at this point has over 50 maps customized to support this system and 550's could be part of a custom remote tune.
    Motoza Performance Custom Tuning, under construction..... again.....
  7. #87
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    Quote Originally Posted by lave3k View Post
    lave3k, do work for Motoza, or are you just a customer/knowledgeable? Your posts have been helpful --thanks.
  8. #88
    Established Member Two Rings RudeJude518's Avatar
    Oct 10 2010
    Albany, NY
    There is a thread over in VWVortex.com in the forced induction forum. I can't link it since I am on my phone, but they were making a custom tune with the help of some people. I can't recall the exact info since I havnt been there in a while. But I can link it later, or someone here can find it and do that...maybe this will help with the tuning questions?
    Xbox Gamertag: Ya uraHERB soi
    Call of Duty when I can find time between work and taking care of the new baby.
  9. #89
    Veteran Member Three Rings rarak69's Avatar
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    550's sounds better to me, but not for the money.
    lave3k how is you clutch holding up? are you on stock or aftermarket clutch right now?
  10. #90
    Veteran Member Three Rings Rirruto's Avatar
    Dec 09 2009
    Ocala
    Quote Originally Posted by RudeJude518 View Post
    Good info
    -Bryan
    2005 Dolphin Gray S4
  11. #91
    Oct 10 2010
    Albany, NY
    Here is the link I was talking about...
    http://forums.vwvortex.com/showthrea...ht=FrankenTUNE
  12. #92
    Dec 09 2009
    Ocala
    That thread discusses custom tuning that is already being explored here via the same company.
    -Bryan
  13. #93
    Veteran Member Three Rings BerNur's Avatar
    Jan 31 2009
    Brandon FL / Astoria NY
    not for nothing but Motoza is the way to go... i can pass those sonatas 2.0t.. WINNING
  14. #94
    Apr 08 2009
    Connecticut
    So if you're running UNI stage 2+ and just install 415cc injectors, wouldn't there be ill effects?? or are you guys saying the ECU will adapt??
    stock
  15. #95
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Quote Originally Posted by dubgli View Post
    Not sure, and I don't want to buy 4 inj to find out it idles like crap.
    However word is Uni is working on the B6 2++ file now!!! yeah yeah. If it is like the MKIV file, it will use 440cc injectors. I'll keep everyone up to date here.
  16. #96
    Apr 08 2009
    Connecticut
    Quote Originally Posted by cdn20valve View Post
    okay. cool. disregard my pm. thanks. now i have to dig up my 386's from storage.
    stock
  17. #97
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    Bumping this back on top
    Installing mine in a week or two....still can't decided which tune -_-
    I'd be happy to run bigger injectors than TT 225s as you mentioned that its already maxed out
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
  18. #98
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Finally, some kind of update. All the FT threads have gone cold all of the sudden.
    As for your tune, I vote Motoza. Whatcha thinking?
  19. #99
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    I 2nd the motoza tune. There has been no official word on uni 2++ for the B6 in a while.
  20. #100
    Dec 01 2007
    San Jose CA
    Uni seems to be pulled in many different directions, but their desire to try and hit all the requests is appreciated. However, the bottom line is that they tune via octane so I'm betting if they do release a FT tune it will be 93 specific. No good for us CA kids.
  21. #101
    Oct 08 2009
    12 more rings
    Northridge, CA
    I see.....I guess Motoza it is! with 440 injectors right? time to save up haha
  22. #102
    Dec 01 2007
    San Jose CA
    Unless something has changed, that should be it. Perhaps you should shoot your future tuner and email and see what he says ;-)
    Side note, if I was not starting school in 2 weeks I would FULLY take those seats off you Francis. But no more mods for me. Sad Panda.
  23. #103
    Oct 08 2009
    12 more rings
    Northridge, CA
    what seats? my stock seats?(how is that an upgrade? haha) I'll take them up there if you want...
    and yeah...hopefully its not gonna cost me an arm and a leg. $500 fixed price! lol
  24. #104
    Dec 01 2007
    San Jose CA
    Damn, delivery even? That would be awesome. Hmmm.
    I have the non-perforated, non-power, non-heated ones. But that doesn't concern me. Don't really care about that stuff. For some bizarre reason, my driver's seat is like worn out... it has little cushion and kinda bottoms out a bit. Came that way from the PO. I think her husband was a big fella or something? That's all I can think of.
    Back on track, yup... it is a fixed cost and thus far there have been very positive things said about Motoza. But more importantly, you'd be getting a tune customized to your setup + fueling. I know I keep mentioning that, but it's something that does make a difference for us poor folk w/ 91.
  25. #105
    Oct 08 2009
    12 more rings
    Northridge, CA
    ^^ yeah let me know if you want em. pm me your email address and I'll send you pics, just be patient waiting when I'm gonna deliver it, may be August or before that?LOL
    I'm definitely sold on Motoza, post #86 kind of help me decide to go with 550cc instead and CTS still has them on sale for about $50 each. Have to agree regarding the fuel, needs a tune that will put smile on my face even if I only put pump gas. Don't to drive 30-50 miles away from my place just to get a 93-95 octane, which cost $$$.
    So who should I pm/send an email to again? I forgot who it was lol.
  26. #106
    Dec 01 2007
    San Jose CA
    a4darkness (at) me (dot) com
    We'll discuss. I'm not in any serious rush as my car will likely be parked semi-permanent status from mid July on. Not gonna bring my A4 to The City.
    First off, please do not support CTS' morally flexible business practices by giving them a cent of your hard earned money. Jeff Lee has done far too much for this community, we need to support him by not supporting CTS.
    You can find the Bosh 550's for ~$50 here:
    http://www.034motorsport.com/fuel-in...r-p-17564.html
    http://www.intengineering.com/Bosch-...-p8144662.html
    http://www.kineticmotorsport.com/pro...tor-994-0.html
    Contact, you meant at Motoza? [email protected]
    Let us know how the discussions go and what you plan is ITT.
  27. #107
    Oct 08 2009
    12 more rings
    Northridge, CA
    ^^ LOL yeah, I read that thread...didn't know I forgot to type "don't worry, that's all I'm gonna buy from them LOL"
    I'll shoot you an email by tom. regarding the seats
    As for the plan, no crazy plans here coz I'm in college budget so all my funds will be coming from my part time job only. And still has monthly payments til Nov. -_-
    Anyways, hopefully I dont pass $2k to make all these work. already got a descent FMIC w/ piping and the FT4 setup for $950.
    If I pass the $2k mark, I might be forced to sell my recaros or just the boser hood =/
  28. #108
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Glad I'm not the only one who remembered.
  29. #109
    Oct 08 2009
    12 more rings
    Northridge, CA
    Quote Originally Posted by ZimbutheMonkey View Post
    Hey, I remembered too....just forgot to type it haha.
    Oh, and thanks for the links Thomas
  30. #110
    Dec 01 2007
    San Jose CA
    You bet man.
    Also, FU CTS. You're doing it wrong.
  31. #111
    Oct 08 2009
    12 more rings
    Northridge, CA
    hmm....Dave is not replying!! Its been 2 days already(well 1 business day lol)
  32. #112
    Oct 08 2009
    12 more rings
    Northridge, CA
    alright, he replied!
    Unfortunately, they recommend 440 injectors :/ "We recommend the 440's and have good experience setting up these injectors. Can tune to any injector but it is quicker/easier with the 440's" - Dave
    I told him my car can be a hamster to test the 550 injectors. I really hope he agrees so we can see the full potential of this turbo as someone mentioned that the FT4 is almost maxing out 440s. for the right price, I'll be more than happy to help develop the 550 tune =)
    with 91 Octane -_-
  33. #113
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    Quote Originally Posted by audi_nightrider View Post
    Unfortunately, they recommend 440 injectors :/ "We recommend the 440's and have good experience setting up these injectors. Can tune to any injector but it is quicker/easier with the 440's" e than happy to help develop the 550 tune =)
    with 91 Octane -_-
    I tend to agree with Dave, with an added wrinkle: put the intercooler money into w/m. You can bump your octane while keeping the IATs at a good level. And the added fuel will more than cover you for any (unlikely) injector shortfall.
  34. #114
    Oct 08 2009
    12 more rings
    Northridge, CA
    I already have the FMIC though, is it gonna create any problem of I run both FMIC and w/m at the same time with the FT4?
    I haven't bought the injectors yet thats why discussion is still open: 440 vs 550. If Dave says to just stick with 440, I'll just do it and then install w/m like mentioned ^^
    thanks!
  35. #115
    Dec 01 2007
    San Jose CA
    Interested to see how this all pans out.
  36. #116
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    thanks!
    No issues with FMIC and W/M. Works great together. Go with 440's, than get yourself on the dyno!
  37. #117
    Oct 08 2009
    12 more rings
    Northridge, CA
    probably gonna add w/m later on as I want to save up some $$$ for now.
    Dave told me that he'll think about 440 vs 550 though =)
  38. #118
    Dec 01 2007
    San Jose CA
    Really... he's considering 550's even on 91? Oh wow.
    I know this was kinda discussed to death in the other thread but if it is indeed a possibility, well this is pretty exciting stuff.
  39. #119
    Oct 08 2009
    12 more rings
    Northridge, CA
    ^^ yessirr, we'll see what happens though. Don't really want to force him to do the tune for 550...but why not if he insist
    w/m sounds awesome but that's another $350-$500
    Thomas, you got my email right? sent it last monday
  40. #120
    Dec 01 2007
    San Jose CA
    Bump for an update.
    My bad on the delayed reply Francis. Will hit you back this week!
