Results 1 to 12 of 12
    Jan 11 2007
    Salt Lake City, Utah
    Power limit of RS6 motor?
    I know normally the tranny is the limiting factor with modding RS6's, but now with some people doing 6-speed swaps in the RS6's, I was curious if there's a general consensus on how much power the stock internals can handle before upgrading?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Feb 13 2008
    IDK. But, if you have the money to do an 6MT swap and you are going to do a turbo upgrade...I think I'd go for broke. Literally.
    07 RS4 - Milltek Sport, KW V3s, Hotchkis Sways, Rotiforms and a few other little things
    13 A6 2.0T - Intentionally boring AF so she stays stock
    Missed: cbock's Stage III+ C5 A6
    Established Member Two Rings RodV8's Avatar
    Feb 26 2011
    CA
    Theres a few 700-800 hp rs6's on youtube but they are obviously built at that point. I think most chips and tuning on stock turbos and fuel, most are in the 500 range. Dont think to many people have pushed the rs6 to the limits in the usa being that they are rare and more of a collector.
    Senior Member Three Rings exogen's Avatar
    Dec 08 2009
    Alaska
    I bet with upgraded IC's, meth and an aggressive tune with a full TBE/dp's you could hit 600hp. normal stage 1s are 500/520hp i think. so its prolly possible. Some good numbers have been made on ko3s with high psi on stock block, they just prolly wont last long haha.
    Jan 11 2007
    Yeah, I'm not really curious what can be made with stock hardware, rather I'm more curious about the power limitations of the stock motor before failure. It would be sick to get a cheap high mileage one and go nutty ha.
    LOOKING FOR:
    Jun 01 2010
    little silver, nj
    If you really need to know that answer check rs6. Com. Many owners are qualified Audi mechanics. And gear heads. The cosworth motor is a bull. If u look at a thread I started here, I bought a wrecked rs6 for it's motor and driveline. The owner had a dahlback racing stage 3 kit installed with level 10 tranny. My swap will be done in 2 weeks, and the engine which previous owner drove for 2 years makes 700/800. He had no issues. As noted above, my current engine in my rs6 all internals, turbos are stock, with noted mods, I'm making 535/670, no issues, but I'm at 1 bar, for KO4's maxed out. Part of the DBR kit is GT30's.
    03' RS 6 Ebony, and lets just say Special Sauce........
    11' CTS-V Wagon...Grocery Hauler
    Veteran Member Four Rings SteveKen's Avatar
    Jan 11 2005
    Pittsburgh, PA
    I've heard, but have never seen proof, that cooling is the limiting factor on the RS6 motor. Not sure if it's engine cooling or IATs, but MTM cars have the awful looking cutouts on the hood as well as some special air deflectors on the belly pan.
    Also heard that the 700HP limit is due to the stock intake manifold.
    I'm just going off of memory here, so somebody correct me if I'm wrong.
    If you care to experiment, I've got a spare RS6 motor that I can sell you. :)
    Steve
    2013 S6 • 2012 Q7 TDI S-line • 2010 GTI • 2001 Honda S2000 • 1977 Honda CB750 F2 • 1965 GMC 1500 WideSide
    Jun 01 2010
    little silver, nj
    ditto on the spare;)
    May 16 2008
    South Texas
    The engine itself is good for 700-800hp the limiting factor being the rods.
    Jan 11 2007
    Quote Originally Posted by Scotty@Advanced View Post
    Cool. Any aftermarket rods currently for the motor? They aren't by chance the same dimensions as the rods in the 1.8t and 2.7t, are they?
    LOOKING FOR:
    May 16 2008
    South Texas
    Quote Originally Posted by jibberjive View Post
    Yes they are out there. The rod dimensions are the same as a 2.7tt, however the V8 rod has the bearing tang on the opposite side.
    Veteran Member Three Rings ben916's Avatar
    Feb 02 2010
    2012 CR-V (sipping gas while I gulp it)
    Newcastle, WA
    IIRC, the 4.2 V8 motor from the RS6 is the same motor in the Gumpert Apollo (obviously with different states of tune and unsure of the turbo set up).
    Also, those brits at MRC Tuning are doing crazy things like 2 fuel pumps, upgraded fuel rail, upgraded injectors, upgraded turbos, just to start.....
    SOLD - 03 Audi RS6 Avus (905355), Carbon, Sportec cooling, Frozen rotors, EBC Reds, Aces 4, Apikol, Phaetons, Plus Pedals, Aluminum paddle shifters, KomfortBlinker, Hotchkis, RNS-E
