Phil - I found another excellent post from you! I trust your posts completely and hope you can answer few of my questions about confusion with VAG part #s
I have the same auto 6 speed tranny and ETKA is showing G-052-145-S2 as the oil to use. I called the dealer and they confirmed that my code is HHL and I need to use G060162A2 - the same one you used. I started to research this HHL tranny and found out that it's a ZF6HP19A transmission made by ZF.
ZF website say the following for ZF6HP19A
all 6HP19
6HP19A(2) (trans parts list dependent)
ZF LifeGuard6 (ZF No. S671 090 255)
=> Audi Oil No. G 055005 A1 / A2 / A6
Split oil supply front / rear axle differential:
- Filling front axle differential with transmission oil Castrol SAF-AG4
=> Audi / VW Oil No. N 052145000, Porsche Oil No. 999.917.545.00)
- Filling rear axle differential with transmission oil Castrol SAF-AG4 Q (SAF-AG4 + 4% FM Additive)
=> Audi / VW Oil No. G 055145 A2)
Common oil supply front /rear axle differential:
- Filling with transmission oil Castrol SAF-AG4 Q (SAF-AG4 + 4% FM Additive) => Audi / VW Oil No. G 055145 A2
So the G 055145 A2 is a bit cheaper and it's the ZF6 kind, where there are posts saying to use zf8 is it the G060162A2 ?
Furthermore.. I read this post about about same part# tranny ZF6HP19A that was also used in Phaeton:
So the questions are:
is the G060162A2 is for sure the right fluid to use?
is it worth the risk to buy cheaper but generic ZF fluid?
is it needed to change fluid 2 times to get rid of old fluid in tranny(read post below)?
is any software flash needed to use newer G060162A2 fluid?
Thanks in advance! !
-------------------------- read post that i found ----------------------------------
This is only from my experience and according to my understanding, so please use your own judgment as well.
Phaeton’s transmission ZF 6HP-19A, is very sensitive to ATF. the part number in ETKA got updated at one point, it is now showing as G060162A2, but the original factory filled ATF is not G060162A2, and VW didn’t bother to notify the dealer that this change took place. And once you changed the ATF, Since the usual way for dealer to change ATF is to drop the pan, drain the fluid, and replace the filter can only get rid of about 40% of the fluid, once different types of ATF got mixed, that’s not what you want. For this transmission, the clutch will burn due to mismatch ATF type, and will require a software update to the TCM.
That is what happened to me, but at that time neither the dealer nor I know this, until I found out through the hard way: my transmission starts to shift strangely, then I found the info on this forum and provided it to the dealer and push them to check with VW. I even scanned my car with Vag-Com and provided them the ECM and TCM software version number, along with the email I got from ZF which confirmed an software update is needed once ATF got changed.
So the solution the dealer got from VW is this: Change the ATF one more time after driven certain Kms, drain the old fluid, refill with G060162A2 again and then update the TCM, according to VW, this should correct the problem, It will drain about 80% of the old fluid, and the TCM software version is brought from 1003 to 1905 in order to adjust to the new type of ATF.
So, in conclusion, below is the procedure done on my car:
Part 1 of Transmission Service Units:
Perform Automatic Transmission Service:
Service includes filter, fluid and new pan gasket,
Change automatic transmission fluid and filter.
Replace rear differential fluid.
QTY Part Number Description
1 01V-321-379 Washer
1 09L-321-371 Gasket
1 09L-325-429 Strainer
1 G-052-145-S2 Axle Oil
1 G-052-145-A1 Axle Oil
6 G-060-162-A2 ATF Oil
Part 2 of Transmission Service as per VW QTM
(Only after car been driven by customer for 500 miles since the first service):
Change fluid for second time (No need to replace the filter or pan gasket) and top up.
Perform TCM software update as per QTM.
VW Tele-update TCM Module
-------------------------------------- end of post i found about phaeton ------------------------------------------------------------------------
