I just did the rear and front diffs and the tip ATF/filter today. Not too difficult. My only hiccup was the center diff. I don't have a short 8mm allen socket and the plug seems to be really torqued on there. There's not a lot of room between the center diff and the trans tunnel side wall for my bit and a ratchet so I'll see what I can find in the Chinesium mines online.
I did this at 126750 miles on the clock. The diff fluids came out real clean looking and the ATF was pretty clean as well. It was tan and not very cloudy so I expect it was LG6. My trans does not have the firmware update. There was a middling amount of gunk on the magnets and the pan didn't have much goo so I wonder if the trans had been serviced sometime before I got the vehicle. Clean diff and AT oils and not a lot of crap in the pan is a good thing at this mileage.
I used Moble 1 LS 75W-90 in the diffs; Redline D6 in the trans. It may be a little early to tell but it looks like the fluid change fixed a shift flare from 1-2 that I experienced when cold. It was getting pretty annoying when trying to merge into traffic. Shifts are crisp now. Some of that may be the new filter. Here's the old one, opened:
It's got a fair amount of stuff in the media so maybe line pressures were down, causing the lazy shifts? The date code on the filter seems to indicate a 2006 manufacture date. The pan gasket was the metal/rubber one. It's the 11-bolt pan.
One thing of note, when reading the original DIY: according to VCDS the upper temp range for measuring the fluid level is 50C, not 40C. I started out at 39C on an engine that had been off for more than 4 hours. I filled, ran through the gears and topped off as the trans went up to 42C, then shut it down for about an hour while I did the diffs. It cooled down to 39C again and I ran through the process again but not much, if any, fluid was needed. I used about 5.5 qts. I whipped up a redneck fluid transfer pump from a $20 Amazon pump and some bits to make the filling process easy:
(No, I did not use Transmax here. That's from one of our Saabs...)
Next up: front suspension refresh and probably the beknighted oil cooler/filter housing, which I see is weeping gently, like my guitar.
Sorry, too much Beatles on the radio today.
