Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 167
  1. #81
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Finally had my fluid changed and the shifts are smoother. At nearly 75K miles, it was shifting fine but had some roughness 2nd to 3rd and 6th to 4th. That roughness is gone and I discovered a great shop -- J's Repair and Performance in Plainfield, IL. It was not inexpensive since I used Audi fluid but have not had any issues over the two days since it has been done.
    Thanks to fly300kts for strongly advising the Audi brand fluid. It must be GOOOOOOOLD; it's priced as such.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
  2. #82
    Established Member Two Rings Aznkae's Avatar
    Aug 04 2010
    Big wheel
    Brooklyn, New York
    I had my fluid changed about a month ago with the ecs kit. Before I had jerking mostly on 3rd gear downshift. Now after the fluid change I have jerking on 1-2, 2-3 upshifts. I'm thinking to have the fluid levels checked again, but the mechanic said he got around 5 quarts in it. Anyone had similar experiences? I'm at 100,500k miles.
    2005.5 Artic White 2.0T quattro Tip
    Unitronic Stage 2, AFE Drop-in Filter, 034 Turbo inlet pipe, R.A.I. HFC/Downpipe, Magnaflow 16601 Exhaust, Koni FSD/Eibach Pro, Apikol Snub, RS4 Rear Sway Bar, Podi Electronic Stepper Boost Gauge, Upgraded Piston DV, R.A.I. Catch Can
  3. #83
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by Aznkae View Post
    Not sure how to say it: USE OEM FLUID
    Phil
  4. #84
    Aug 04 2010
    Big wheel
    Brooklyn, New York
    Phil
    http://http://www.ecstuning.com/Audi-B7_A4-Quattro-2.0T/Maintenance/Drivetrain/ES2500835/
    This was the kit that I used. All OEM parts and fluid. Had the fluid level check again today and seemed ok. But the little fluid that came out did look pretty dirty already. Prob driven only 500 miles. Wondering what to do next.
  5. #85
    Senior Member Two Rings rs6's Avatar
    Mar 23 2005
    2014 Cayenne S, 2013 F-150, 2006 A4, Focus Electric
    San Francisco
    FWIW I used the Ford branded fluid (which is supposed to be identical), and I've put about 50,000 miles on the car with no issues.
  6. #86
    Oct 16 2008
    Are you sure that you are checking the oil lever at the correct temperature using VAGCOM?
    Phil
  7. #87
    Aug 04 2010
    Big wheel
    Brooklyn, New York
    Phil
    Yes. All steps were followed in accordance to your DYI. I still have two more quarts of the OEM fluid and I'm wondering if I should try to squeeze more in there. Is there any harm in overfilling or is that even possible? I take it the fluid expands when it gets to a certain temperature?
  8. #88
    Oct 16 2008
    Do not overfill and yes the fluid expands a lot
  9. #89
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Can you link to the Ford branded fluid? I know that Blauparts has a Ravenol fluid whose specs are supposedly the same as he OEM fluid. I think Blauparts has it for $31 with a $3 off per liter special righ now.
  10. #90
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    This DIY helped a lot!!! My transmission is much smoother.
    Thank You!!!
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
  11. #91
    Sep 27 2008
    Phoenix
    19jdog how long did this take and did you use OEM fluid?
  12. #92
    Jul 28 2014
    SACRAMENTO
    Quote Originally Posted by wootwoot View Post
    3 hours. I ordered the kit from Blauparts. $100. Worst part was being under the car. I can only get my car up 20". It was a little clostrophobic for me.
    04 B6 A4 USP 2.7t
  13. #93
    Oct 16 2008
    Quote Originally Posted by 19jdog View Post
    Thank You!!!
    You are most welcome
    Phil
  14. #94
    Jan 06 2009
    Bump...
    Is the tiptronic trans similar to the manual trans in that the oil sump is shared with the differentials? i.e. draining and re-filling the trans pan also drains and re-fills the front/center differential? I can see separate fill/inspection plugs for each and the service manuals aren't very clear.
    From this link, pages 5, 6 & 7, I assume they are separate?
    http://www.zf.com/media/media/docume...9A_Catalog.pdf
    Edit: They are definitely separate. Front and center use 75w90 gear oil.
    Also, I have the trans out of the car so I would like to pre-fill it cold before putting it back in. I assume using the fill/inspection holes on the side of the trans will result in the same fluid level as using the pan fill port? Thanks!
    B6 2.7t BEL tuned by Bische
    B7 2.0t
  15. #95
    Oct 16 2008
    Quote Originally Posted by ADCS View Post
    Yes rear left side plug is same level than bottom plug
    Phil
  16. #96
    Veteran Member Three Rings wding2000's Avatar
    Jul 04 2015
    08 A4 Quattro Avant; 16 Golf MK7
    I have following posted in another thread, but figured it can be useful for anyone doing trans fluid, thus decided to copy to this main DIY thread (with edit). I have spent quite so time researching these.
    For 6-speed tip Quattro, to make sure have the same trans, go under car to look at (green metal) label - it should have 6HP19 and model# 1071-040xxx. Label is 6HP19, but it is actually 6HP19A (A for Audi, Z for BMW).
    There are three type fluids:
    - G055005A2 or ZF LifeGuard 6 (tan): these are factory fill for A4 2005 and early 2006 models. These cannot be mixed with new fluids (below) unless you have dealer update ECU software to a new version. If not, you need to stick with LG 6 fluid.
    - G055162A2 or LG 6+ (blue): these are factory fill from late 2006 models.
    - G060162A2 or LG 8 (green): these are replacement for blue LG6+, and blue and green can be mixed. LG 8 is also used for ZF 8-speed auto trans.
    Due to switch date in the middle of 2006, that is why you have to look at VIN number, starting from the 8th digit from right. It should start with 5, 6, 7, or 8 (for 2005, 2006 etc).
    - VIN 5A40000 - 6A99999: factory filled with LG 6 (tan);
    - VIN 6B00000 - : factory fill LG 6+ (blue), can use LG 8 (green).
    You can buy ZF fluids, which is exactly what Audi sells, but at lower price. Again, this is for 6HP19A trans.
    08 a4 2.0t quattro avant | eng bwt 200hp | tip 6-spd zf 6hp19a | akebono ceramic | andros 18x8 et35 cb72.2 72-57 centric rings | pirelli p0as+ 235/40r18 | hu xtrons px5 mtce_gs_3.40 android 8 | rev d dv
  17. #97
    Senior Member Three Rings Jimmyjamms's Avatar
    Sep 20 2014
    Hilux SR5 3.0TD
    Sydney AU.
    Got the transmission serviced (tip). I supplied the oil (OEM green) that I had delivered from America as for some reason Audi charge $180 per liter down here in Australia. Had kicking issue many describe. Picked the car up this afternoon and the service tech told me they didn't drop the pan and replace the filter! Fucking pissed. Filter wasn't in stock as 'Audi don't suggest replacing it'. Gear changes are a lot smoother though and I've told them to order me in a filter and do it as I've asked. Won't be paying this time though. Can't believe they'd change the ATF without doing filter.
  18. #98
    Aug 05 2010
    Central IL
    Glad the kicking is gone, but I am sure you realize additional fluid will need to be provided when filter is changed.
  19. #99
    Sep 20 2014
    Hilux SR5 3.0TD
    Sydney AU.
    Yep. We're going to strain it out through a filter this time and if it looks ok, re use. I still have 2 liters of new fluid so I'll use that first and top off with strained fluid.
  20. #100
    Jul 04 2015
    Quote Originally Posted by Jimmyjamms View Post
    He is lazy. Definitely want to change filter and clean those magnets. AUS $180 a liter! That is pricey!
  21. #101
    Sep 20 2014
    Hilux SR5 3.0TD
    Sydney AU.
    Quote Originally Posted by wding2000 View Post
    Yeah I got a bit of a shock when I got quoted! ...and then just as big a shock when he told me they didn't pull the sump. Damn dealers. I'm gonna stay there and watch them this time!
  22. #102
    Established Member Two Rings $@m I @m's Avatar
    Aug 09 2015
    Audi a6 3.2 sold
    Easton Maryland
    So is there a recommended time frame to have the transmission fluids flushed? Long Story I just bought my car it had an exhaust leak so mechanic put a clamp on now while the car automatically shifts i hear a weird clamping sound but that couldn't be the transmission because this started after the exhaust clamp put on
    Sent from my LG-E980 using Tapatalk
  23. #103
    Oct 16 2008
    Quote Originally Posted by $@m I @m View Post
    How many miles?
    Phil
  24. #104
    Aug 09 2015
    Audi a6 3.2 sold
    Easton Maryland
    Has about 147,000 miles the clamp is now fixed by the way
  25. #105
    Oct 16 2008
    I would definitively do it now
    Phil
  26. #106
    Aug 09 2015
    Audi a6 3.2 sold
    Easton Maryland
    Phil
    Alright thanks Phil
  27. #107
    Mar 09 2015
    Another satisfied DIYer!
    I bought my 08 Cabriolet with 96k miles. The erratic revving got a little worse so I serviced the trans. I was a little upset that it still ran the same after, but after putting some miles on the car there is zero revving now.
    I serviced mine in the middle of summer, so the hardest part was keeping the fluid temp down. Had to go through the filling procedure a few times.
    Thanks again!
  28. #108
    Oct 05 2015
    Detroit / MI / US
    Phil, if you'd like to add this to your head post:
    Trans oil - another good source for the ZF oil is http://www.importecautoparts.com - listed at $20.59/qt for the LG8 , with the ZF logo and P/N "G060162A2 ZF" slapped on it (for peace of mind, should you need it) - they offer free ground shipping for orders over $100.
    They also have the original trans oil mfg label at $17.02/qt (search for the P/N, you will see both listed).
    Price was current as of 11/30/2015 (I just ordered me a 6-case).
    Luc
  29. #109
    Apr 14 2008
    '18 A6 3.0 Prestige, '14 A6 3.0 TDI, '17 Q5 3.0
    Quote Originally Posted by A4Trial View Post
    Luc
    Just the post I was looking for! Never heard of them, OEM parts at a reasonable price and free shipping. Called one dealer and they told me TIPs don't get the fluid changed, 2nd dealer $923.23, local shop $795. Now I need to find a place to do it.....If the leveling wasn't so important I could do it myself.
  30. #110
    Oct 16 2008
    Luc
    Great find Luc, thank you
    Phil
  31. #111
    Apr 14 2008
    Do you really need to change the plugs/seal ?
    Audi B7 A4 Quattro 2.0T Transmission - Plugs - Automatic Drain Plug Seal - Ensure a proper seal after transmission fluid service - Genuine Volkswagen Audi - Audi Volkswagen
    01V321379
    $4.80
    01V321376 - Fill Plug - Remove to fill the transmission with fluid. M30x1.5 - Genuine Volkswagen Audi - Audi Volkswagen
    Fill Plug
    $13.95
    018321377B Transmission Plug With Seal - Stop leaks and replace a stripped plug - Genuine Volkswagen Audi - Audi
    $8.40
  32. #112
    May 20 2010
    On my 07, I tried some LG8 to mix, and that did not go well. It slipped horribly, and when was drained again, it was very thin and runny. I had all the fluid swapped over to Redline D4 (3 drain and fills), and it's been perfect. I suggest going for that if you are looking to save some money--it's been great!
  33. #113
    Apr 14 2008
    My VIN is 6A152XXX and the fluid part # that they give me (at 3 different dealers, 1 was a VW) G 060 162 A2 crosses over to the ZF8, according to your info I have the LG 6 tan that can't be mixed with the newer ZF8. My trans is a 6HP19A JJE , all the parts sites say that it takes the newer type fluid. Is there a way to check for the update without taking it to a dealer, like with a VAG Com or maybe through my service records? Got the parts and fluid and now I can't do the job until I'm sure......I also did a lot of research on this. Where did you get that info from?
  34. #114
    Jul 04 2015
    Quote Originally Posted by dadman View Post
    From various forums and docs, but mainly:
    - ZF Trans Lubricant TE-ML 11
    http://www.zf.com/global/media/en_zf...s/TE-ML_11.pdf
    which only mentions 6HP19A as MPL dependent, but nothing specific.
    - Audi TSB
    http://www.audi-forums.com/general-a...squeaking.html
    http://uberlame.com/a6_tsb/Transmiss...2037-06-13.pdf
    Page 1: VIN range
    Page 3: for JJE trans code, old SW ver 0010, new ver 0060. I believe VAG com can read this out.
    This bulletin (2006) refers to updating to G055162A2/LG6+ (blue), which has been replaced by G060162A2/LG8 (green) since.
    - ZF ppt
    http://www.apra-europe.org/dateien/d...chatronics.pdf
    Check page 52/56/59/61: Page 52 refers to LG6 for MPL 1071-040-014 and 044, and page 59 LG8 for others. This MPL (main parts list) is the model number on transmission plate from underneath your car.
    In my case, I have 08 A4 tip 6HAP19A, HYH trans code, MPL 1071-040-052. So I am very certain it has new fluid and SW ver. The car has 2,000 miles since, and has been great.
    First in order a standard disclaimer: this is how I interpret from those docs, you may form your own opinion. That being said, if I were you, I would VAG com read out trans SW ver, and also check MPL number. If still in doubt, I would flush the fluid completely, not just drain and fill, instead of guessing game and playing with chances. Just follow TSB: take the car to dealer to ask them to check and update SW, drain/fill yourself a couple of times to flush out old fluid as much as possible, then do final adaption drive. You may spend a bit more on fluid for peace of mind of knowing you have new SW and fresh fluid - I guess ZF updated the fluid and Audi issued a TSB for a good reason. Or can have dealer do it. But it is your call.
  35. #115
    Apr 14 2008
    - Audi TSB
    Page 1: VIN range
    - ZF ppt
    Some of that info has changed, the recommended fluid, LG8 has changed from green to blue and the VIN takes precedence over everything else for determining the right fluid. My VAG is showing a 0030 SW version (I think), I'm going to call them. The first ZF TE-ML 11 link has just been updated on 1-1-16, I didn't compare to see what has changed. My dealer said that he would install the new version SW for the price of 1 hr labor, not sure if I should change the fluid first or later, there are some questions about if and when the adaptation is needed too. What a PIA...
  36. #116
    Jul 04 2015
    PITA - could not agree more. What trans code you have?
  37. #117
    Apr 14 2008
    JJE , I'm trying to find out what the latest SW version is.....mine shows 0030, old is supposed to be 0010 and new 0060. Not sure what 0030 is??
  38. #118
    Senior Member Three Rings mfdk's Avatar
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    i finally had the chance to replace the fluid last night following Phil's DIY, everything went pretty smooth and i managed to get close to 6qrts. Test drove the car and what a differene.
    Today, after driving for around the neighborhood I did notice every once in a while when downshifting from 4th to 3rd gear i can feel some sort of jerk-jump or kick, i used vagcom to check for any codes and this showed up on my scan
    009984 - Transmission Friction Element / Clutch A
    P2700 - 000 - Apply Time Implausible - Intermittent"
    After clearing it, it has not come up yet, any ideas...?
  39. #119
    Apr 14 2008
    Quote Originally Posted by mfdk View Post
    Did you use the newer type fluid in a car that needs the SW update along with it?
  40. #120
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    No i used the original fluid type, did not want to bother with newer fluid that requires sw.
    Sent from Outer Space
