Results 1 to 12 of 12
    Veteran Member Three Rings Mark.'s Avatar
    Aug 23 2009
    nh
    Boost gauge installed wrong?
    So I had a shop install my podi boost gauge but when I'm driving the needle never goes past the 0 psi. So it seems like only the vacuum is reading? do I have it in the wrong setting or dos they install it wrong?
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    most likely they installed it wrong, or the hose has a pinch, or you have a boost leak and have had it for a little while (you would have noticed a drop off in performance tho)
    but most likely its a pinch in the hose
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    What did they tap into to read the boost? FPR?
    Aug 03 2010
    GSX-R 600 Red Matte Black
    Fort Lauderdale
    theres probably a pinch on the line. Even if you were leaking it'd be more than 0psi. You have to check where the line is going and check also RIGHT behind where you installed the gauge, thats where mine was pinched.
    Established Member Two Rings flashovermac's Avatar
    Apr 07 2009
    If it DOES read vacuum, sounds like they may have installed it behind something with a check-valve. Tapping into the FPR line is said to be best, and is where I run mine. Also, while you're in there, throw in an anti-buzz fitting... incredibly frustrating without one.
    Just something to consider on top of what everyone else said, as often times, a pinched line would USUALLY result in an understated boost reading with minimal to no vacuum.
    Veteran Member Three Rings TrboPowr's Avatar
    Nov 23 2005
    2007 A4 S-line Turbo, 2007 A6 Avant, 2010 Porsche Cayenne GTS
    Washington DC
    sounds like a pinch to me
    2007 RAI B7 BORG WARNER EFR
    Deval│Vorsteiner│Bilstein│Brembo│Oettinger│Borg Warner
    Mods = Bitch slap to my bank account
    Aug 23 2009
    nh
    yeah im going back to have em look at it, the other thing they did was run it through the headlight switch so the only way its on is if my lights are on
    F.T.W.L.T.B.D.W.I.C.T.W
    B8.5 S4, APR Stage 2, APR Intake, APR Dual pulley upgrade, AWE cat back.
    Registered User Three Rings Mike@Addict's Avatar
    Sep 02 2009
    Bellevue, Wa
    i had the same issue. i have the non electronic one. The valve was on mine in a bad position and had to take it off and make it face the other way cuz the hose was pinched against the pod wall
    Jul 08 2010
    tucson
    danbury
    Very odd that they wired it to the headlight unless i read it wrong n they wired the back light to the guage to turn on when ur lights are on
    Is it a mechanical guage or electronic ?
    [CENTER]Scott
    2011 S4
    Veteran Member Three Rings jayuuey's Avatar
    Aug 22 2007
    SF Bay Area
    It's a mechanical since he mentioned the anti-buzz. It does indeed sound like a pinch somewhere. Do you know where they routed the line?
    Jay
    Current: Ibis White A4 Avant S-line TI 2.0T MT6 (JHM STS, Unitronic Stage1)
    Sold and quickly forgotten: 09 Forester XT Limited
    Sold and will be missed: A4 2.0T Quattro, 6-speed manual, APR Stage 2+
    (old) norcal audizine GTGs, etc. http://www.flickr.com/photos/jayuuey/sets/
    Aug 23 2009
    nh
    its the electronic one
    http://podi.ca/P1Packages.aspx?CarID=2
    second one on that page
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Quote Originally Posted by Mark. View Post
    If the gauge is on only when your headlights are on then it is wired incorrectly.
    The red wire goes to a switched +12V source, yellow to constant power (for memory) and black to ground.
    If you are turning your gauge on and off with the headlight switch and it is not shutting down correctly there could be a whole bunch of reasons why you are not getting a correct reading.
