Results 1 to 14 of 14
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    anyone use a "universal" oxygen sensor vs a OEM one?
    pretty sure my o2 sensors on my 2.7t allroad are getting tired, its got 115k and mileage is pretty bad around 17mpg with 70% of my commute at 60mph, so ive noticed the prices are horrible...around 100bucks a peice so i was thinking of getting a universal one that i can splice into the existing harness, anyone done this before? ive heard of some universal ones lasting a couple months then creating a ton of problems, so is it going to be worth is to pay the extra 60 bucks for the bosch oem ones? anyone find any cheaper prices, any input would be awesome
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Senior Member Two Rings gbjoshe's Avatar
    Nov 20 2010
    VW CC 2.0t, Kia Optima Turbo, Old 2 door CL Benz
    Grand Blanc Mi.
    Ive had the same problem too. I have noticed my gas mileage around 15mpg. Even tho i do alot of city driving. But i even baby it and coast as much as i can and still get low mileage. When i went to auto zone to get the code checked it said about 5 different things but all related to the oxygen sensor, so im assuming i have the same problem!
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    I'm using the universal one's right now on my 2.7T. So far going on 2+ years without any problems. Very easy to do with the kit they come with, but if your handy with a soldering iron, I suggest going that route.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    I also use a Bosch 4 wire and just spliced on the OEM connectors..
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Registered Member One Ring lester's Avatar
    Feb 23 2011
    Citreon xsara
    FoShan GD. China
    I think it can be done. because the spec of oxygen sensor is few items, only the output voltage and the lines, try it, then tell us. hehe
    , lester
    Veteran Member Three Rings allroadstomtl's Avatar
    May 25 2009
    '12 Avant P+, '16 GSW
    Montreal
    I too noticed a drop in mpg, I've done everything to run as economical. I've even increased air in the tires. Is there a part # / name?
    '12 A4 Avant P+, S-Line 3 Spoke, S-Line Stone Guards,
    Sep 11 2009
    NE
    I bought delphi (I think) oxygen sensors a year ago, universal type. I think I paid like $20 each. Soldered them, shrink wrapped afterwards and made sure the were covered nicely with thermal blanket.
    Feb 07 2011
    Fishkill NY
    I bought 02s off of ebay for dirt cheap, some no name brand but i have had them in my car for 6 months and no problem. Thay were a direct connect no cutting or splicing.
    Jan 07 2011
    cincinnati ohio
    I just installed a bosch universal on my allroad last night. It was very easy to splice and the connection is in the top of the bay at the firewall. I dont see any reason it would fail and even if it corroded at the connection, that could always be redone. It saved around $100 and I didnt hesitate! I guess I will have to report back here in a few months or years to do a follow up as only time will tell!
    Active Member One Ring Bdog418's Avatar
    Mar 17 2011
    Bend/Oregon/Westside
    I also use a Bosch 4 wire and just spliced on the OEM connectors, works fine.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Replaced both main O2s with Bosch 4-wire replacements with the splice box, works great
    Account Terminated Two Rings
    May 04 2011
    Hartford, CT
    I'm using Universal oxygen sensor for about 2 yrs and it really helps me in reducing harmful emissions as well as extends catalyst life.
    Jan 31 2010
    S-Line A6
    East Haven, CT
    lol ^
    Veteran Member Three Rings patrick23's Avatar
    Dec 09 2009
    2004 Audi A6 S-line, 2001 Nissan Pathfinder SE, 1999 Subaru Legacy Outack Limited
    val-des-monts quebec
    lol x2
