Results 1 to 16 of 16
Thread: Boost gauge
    Senior Member Three Rings SoFarGon's Avatar
    Jun 01 2010
    North East
    Boost gauge
    I have a newsouth electronic boost gauge, the one that sits in the vent. Now I'm not sure if it's working correctly but the needle takes a long time to "climb up" to where you can read the boost. Any ideas? Could it be a boost leak?
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    Do you have a 3.2? or a 2.0t :) :)
    Does the car feel really sluggish and slow? Or does it feel normal?
    Best regards,
    Sean.
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Senior Member Two Rings trevor51590's Avatar
    Dec 18 2007
    '21 S4, '21 Q5
    need a little more detail i'm afraid as to how this is happening. what driving conditions, how much throttle are you giving, what gear, are you tuned, etc
    '25 RS6 Performance | Daytona Gray/Congac/Black Dinamica | Executive | Black Optics | RS Sport Exhaust | RS Driver's Assist | B&O
    '21 Q5 Premium Plus | Navarre Blue | Nav
    '21 S4 Premium Plus | Daytona Gray | S Sport | 034 Stage 1
    --Gone but not forgotten--
    '23 RS5 Sportback | '18 A4 Premium Plus | '18 Q5 Prestige | '13 S4 Premium Plus | '11 S4 Premium Plus | '06 A4 2.0TQM | '99.5 A4 1.8TQM
    Jun 01 2010
    North East
    Car is stage 2 apr tip... I've seen gauges that totally jump... Fast. This one seems "sluggish". The car itself moves without a doubt. How long does it usually take to see full boost?
    Jun 01 2010
    North East
    Bump
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    no reason bump up your post from today, you gotta give people time to read it...
    is there a kink in your vacuum hose?
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    electronic ones may move smoother (read slower) the mechanical guages tends to jump and buzz and spike a lot
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Jun 01 2010
    North East
    Quote Originally Posted by mr shickadance View Post
    I had a feeling it could be that... How long would it take to see full boost on such a gauge?
    Jun 01 2010
    North East
    Established Member Two Rings bswomack's Avatar
    Jan 30 2011
    06 S4
    Raleigh, NC
    Since it is electronic your response should be pretty smooth unless you have poor connections, but if you don't think it is reading right or you might be losing boost the first place I would look would be your diverter valve
    Jun 01 2010
    North East
    Quote Originally Posted by bswomack View Post
    I have the forge
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by SoFarGon View Post
    you shouldnt be waiting there for seconds, but its not going to spike seemingly instantly like the mechanical guages.....it'll be a smooth rise to peak boost and may fall a few psi
    what numbers are you hitting on your boost? you should be higher then 15 if your stage 2 bolt-ons?
    [CENTER]Scott
    2011 S4
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Subscribed..
    So what vent gauge is the one to get? I want to be able to still close the ducts...
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Jun 01 2010
    North East
    Had a pinch in the line... Knew something was wrong
    Jun 01 2010
    North East
    Line was pinched... Now it's straightened out but still isn't "perfectly round" would this pose a problem? It's straightened out but you can still see where it was pinched. Should I replace?
    Jul 08 2010
    tucson
    danbury
    you can if you want to, a pinched line should make you have no response at all, if theres a crimp you could replace the hose, its what? 5 $ for like 4 feet and maybe an hr of ur time
    [CENTER]Scott
    2011 S4
