Results 1 to 18 of 18
Hybrid View
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Question about climate control unit. B6 vs B7?
    First of all, ECS must be on crack http://www.ecstuning.com/Audi-B6_S4-...trol/ES438111/.
    But anyways, I just have ordered a b7 unit with part number 8E0820043AM, my original unit 8E0820043AD. Should I install a new unit or should I just swap the front plate? Units look exactly the same, but if I am not mistaking I remember reading somewhere, that b7 unit wont operate properly in b6 even if it correctly recoded.
    Does anybody have first hand experience with that?
    Jun 08 2008
    Calgary AB Canada
    Why not just try it and see if it works?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by onceover View Post
    Cause I just have ordered it today, but want to find out sooner than it arrives
    Veteran Member Three Rings FoRbAnNa's Avatar
    Jan 02 2010
    2006 A4 B7 DTM 2.0T Quattro
    Norway
    The unit in your ecs link, rev AG works in B6 A4 and S4 but the AM rev you said you ordered is an outdated B7 model that later was replaced by the BM rev. Which is what I bought that didn't work that well as I described above.. My original ac unit had the A rev, later replaced by both J and now AB. Going from A to BM didn't work so I suppose you would also have the same problems as I did. Here are some of the codes I got after installing a B7 ac unit in my B6:
    18043 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 35-10 - - - Intermittent
    00975 - Heated Rear Window (Z1)
    39-00 - Output won't Switch or Short to Ground
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    01320 - Control Module for Climatronic (J255)
    49-10 - No Communications - Intermittent
    Jan 02 2010
    Norway
    Am I missing something here? Is $1005 a bargin? Or did the price just go up? I paid $500 for a new ac last year and I thought that was expensive even though dealer wanted $1695..
    If you can manage without a rear defroster and always have the leds on the ac unit run at full lumination and won't mind 3-5 codes then yes it would work. I think there are some later B6's that can use B7 ac units but the early models def can't without having issues like I just said, ask me how I know.. I ended up swapping the front on my new 2DIN B7 unit over on my 1DIN B6 unit when I did my 1DIN to 2DIN dash conversion last year. Hot and cold air works fine but the rear defroster light would go out in less than a second after pushing the button. After what I found out the B6 uses a built in relay to control the power to the rear defroster but the B7 units have the relay somewhere else in the dash, not built in the ac unit and therefore a B7 unit won't work in a B6.. Also the lumination on the led display was running at it's strongest all the time and I always had like 1-5 different codes related to the B7 AC unit not working properly in my B6.
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Quote Originally Posted by FoRbAnNa View Post
    I went searching for the thread about swapping in a B7 HVAC control unit into my B6, but I just stumbled across this comment above which is causing me to stop in my tracks. I have an early (12/01) 2002, and had been thinking the B7 control unit (8E0 820 043 BM) was mostly plug-n-play, save for adding a circuit for the "off" button not found on my original unit. Can someone shed some further light on this situation? Is there a build-date cut-off that defines "early B6" for the purposes of this topic? I'm assuming mine qualifies as "early".
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Mar 01 2010
    Farmington Hills,Mi
    Lol I am not buying ECS unit, that price is just an error I believe, MSRP for this unit is about $500. I ordered a unit from a salvage yard for $50. I keep researching about it and somebody mentioned a resistor fix for rear defroster, however I cant find anymore info about it
    Mar 01 2010
    Farmington Hills,Mi
    Got the new unit today, its actually BM version. Will install and report back after my fever goes away and I can get out from the house. Its very nice to see that nothing is peeling on new unit lol
    Mar 01 2010
    Farmington Hills,Mi
    For those who will have the same question. As Forbanna posted b7 unit works in b6, but rear defroster will turn off right away
    Jan 02 2010
    Norway
    Have you checked for codes after the install? Got the same codes as I did?
    Mar 01 2010
    Farmington Hills,Mi
    Nope, I did not check the codes, I basically just ran out to check if it works. Still got fever and its too damn cold outside lol
    Veteran Member Four Rings frenchyofcp's Avatar
    Aug 19 2011
    Folsom, California
    Has anyone figured out how to run a B7 CC unit successfully?
    USP Club Member #138
    Daily: B7 Quartz Ti Avant 6MT
    S4 Project: B8 Glacier/ BO Prestige Avant
    Garage Queen: B5 Casa S4 6MT
    Ladies: B9 Moonlight / BO Q5
    Jun 27 2011
    I ran a b7 one in my b6. All I needed to do was to rewire the rear defroster through a relay. Matt Devo has a really good DIY for that. Not sure what everyone is talking about codes, but the b7 one worked great in my 2004 b6.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jan 24 2010
    Paramus,NJ USA
    As mentioned the only difference was you need to add a relay for the rear defroster at the ac head. There is a good DIY floating around somewhere IIRC.
    Ziddy Autowerks
    Jul 03 2010
    New York
    Ignore my comments a couple posts up ^^^ from 2019, as I was all screwed up in my thinking at the time. I'm currently running a late B6 unit in my early B6, and it was 100% plug-n-play; no need to add anything to enable the on/off button found on the late B6 units.
    What I don't know however is if there is an issue putting a B7 unit in an EARLY B6. I know about adding the relay for the rear defroster as discussed in Matt's write-up, but is there any validity to what I quoted above from FoRbAnNa?
    Jul 03 2010
    New York
    Here is the link to Matt's thorough write-up....
    https://www.audizine.com/forum/showt...ight=defroster
    There's no mention there of any difference between early and late B6 models when doing the B7 swap. I'm classifying that "info" as sketchy, at best.
    Jan 24 2010
    Paramus,NJ USA
    No you can adapt the ac head and it should be free of codes. I have yet to see anyone have issues. I have a b7 ac head in one of my b6 a4 from 2003 model year. As long as you adapt to the vin you should be good to go.
    Ziddy Autowerks
    Aug 19 2011
    Folsom, California
    Awesome, thank you guys! Going in my 04 USP.
