Results 1 to 19 of 19
    Registered Member Two Rings
    Mar 06 2005
    USA-VA
    Turbo timer... a must have or a waste of time?
    I have heard so much about turbo timers and the actual need to use a TT, the thing ive heard the most is that new cars dont need more than 30 seconds to cool down so a turbo timer is totally worthless.... is this true? and what are your oppinions on the HKS turbo timers? Also correct me if im wrong but does a turbo timer not make your car easy to steal?
    -Chip
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I was told by a tech at Audi that the S4 actually has some kind of pump that recirculates the oil for a little while once you shut the car off. This way u wont need a turbo timer. From what ive read on these forums though, that info seems to be wrong. Maybe someone with more knowledge could shed some light on the subject for us.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Mar 06 2005
    USA-VA
    yeah, it seems like they would do that.... I mean anyone buying a sports car is going to drive it hard at least some times and not want to wait for it to cool down.... so what gives, turbo timer worth the risk of your car getting jacked?
    Apr 07 2004
    Silver Audi 2000 S4
    Beaumont TX and Fort Collins CO
    Just get the alarm system with remote start and turbo timer function. Way cool just got it installed last week.
    great question! couple corrections i'd make:
    1. No car currently made with a turbo has a pump that circulates oil. The S4 has a coolant pump that circulates coolant throughout the entire engine (including the turbo)
    2. Its not anymore harder to steal, think about it: no key, steering column locks, and if the installer installed it right the timer shuts off with the ebrake down. That's how i install it and how all timers should be installed. and when the alarm is armed, timer running, someone breaking the windows to get into the car will be alerted by triggering the motion sensors in the b-pillars.
    3. The critical part of a turbo is the spindle where oil lines meet to lubricate the shaft shared by the exhaust turbine and intake impeller.
    4. unless you cool down your car after each hard run, you don't need a turbo timer. if you are often pressed for time or need to be away from the car the moment you get to your destination, a turbo timer is good insurance along with synthetic oil (which has a much higher coking temp/breakdown temp)
    also i'd add that a stock car does not generate enough heat for the factory to warrant building in a oil/coolant system.
    the S4 afterrun coolant pump was meant for environments where the car continues to heat up after the car has been shutdown. Its commonly received that the coolant pump very rarely runs even on the harshest of chip/engine mods.
    Norcal/SoCal Audi Electronics/Audio/Alarm Installer. Email me Any questions. Red LED mod: Turbo Timers
    http://www.audimods.com/agravic_sig.jpg
    Feb 23 2004
    2001 Audi S4 & 2004 Audi A4 Avant
    FWIW...I installed a GReddy TT during the summer...I used it for a few weeks, religiously.
    Once the novelty of walking away with it running wore off...the power button went to off.
    I would think, unless you really beat the piss out of your car on a regular basis, AND need to park and run right after, you probably are fine. I live by the water, about a half mile from any road that would be safe to drive hard on..so I have a pretty cool-down when I go home.
    That said...it might get more use in the summer when it is warmer and I am more likely to drive hard. Given a choice, I would install it again...
    Registered Member Three Rings rolledthatho's Avatar
    Jan 10 2005
    winston salem, nc
    and just to clarify your statement on only needing 30 seconds...
    well it depends on 2 things how hard you run it before you cut it off
    and
    how big your turbos are...
    i wouldnt have a turbo car w/o one...
    Jan 10 2005
    winston salem, nc
    btw my opinion is the apexi pencil style, its small and non box like, its red like the interior colors at night and it works flawlessly with no problems at all
    and by problems i mean like some TT's wont let you use your remote locking sys while the car is counting down
    which ones don't? greddy, apexi, blitz, hks, generic ones all work on b5s. its how you install it.
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    I have my TT running my coolant pump system. You can also change out the sensor that makes the afterrun coolant pump come on. ECS has them basicly it is a lower temp switch, so the car uses the pump, or you can run it off your TT, disconnecting the switch all together.
    Veteran Member Two Rings
    Aug 25 2004
    S4
    Socal
    the after run pump thermo switch is on this page
    http://www.ecstuning.com/stage/edpd/...tegory=Cooling
    after i installed it I started leaking coolent from one of the hoses that go to it, I just needed a new clamp but it was not fun getting to it.
    Jan 10 2005
    winston salem, nc
    hey agra, actually the apexi was supposed to have some downfalls but to tell you exactly i dont know each one...
    for instance some dont have a big enough sender in them and the instant you cut the car off the rpm drops (not noticable) low enough not to power the ABS causing 3 loub beeps
    others havent been able to use their keyless entry, but, maybe it is how you stall it all these were on audiwolrd and people were using the same write ups, who knows...
    but i like how small the apexi, not all boxy
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    i have an apexi one that i will sell if anyone wants it. i dont think i am going to use it afterall. it is brand new. pm me if interested.
    2018 Navarra Blue S5 Sportback
    2001.5 Blue Raspberry S4 Avant w/ hybrids on E85
    Past Audis:
    2015 Glacier White Allroad 2.0T
    2012 Ibis White S4
    2001.5 Nogaro Blue AWE/GIAC Stage 3 S4 16,500 mi
    Fast Intentions Wide Mouth DPs and custom 3.5" exhaust
    2000 Silver A4 Avant 1.9tqm 217k mi.
    2000 T28 A4: SOLD
    Active Member Four Rings 2.7Thai's Avatar
    S4, Pathfinder
    AV
    I love mine, it's nice just to get out of the car and walk away. I mean they aren't that much, you could get a used one for 50 bucks or so, and its peace of mind that you are getting that extra cooling time. its like having two locks on one door.
    Veteran Member Four Rings duffS4's Avatar
    2009 Audi A4 Avant, 2011 Audi Q7 TDI
    Ithaca, NY
    That's exactly why I have it. My turbos are babied for warmup/cool down.
    Apr 12 2004
    2000 stgIII s4, 1997 jeep
    denver
    the S4 actually has a reverse flow coolant pump function. if the coolant is hot enuf it will pump coolant after the engine is shut down. but it reverses the flow of coolant which eliminates any bubbles in the fluid.
    knowing, is half the battle
    Registered Member Three Rings S-fear's Avatar
    Feb 12 2004
    S4, A4 1.8T, Subaru Legacy, supercharged Miata, Turbo Alfa (top 10 in GRM $2000+ challenge). UR Quat
    SE MI
    Gosh, I wish what you said below was true. Well, it probably is true if you DO NOT drive an S4. I have been disecting my car and finding out something different.
    With the S4, the turbo (especially driver's side) does not have adequate ventilation. The engine is well insulated from the heat, but that just keeps the heat in the turbo. This car was not designed to have this engine shoe horned into it.
    Stock turbos blow around 75,000 miles because off this heat problem. About the only thing you can do about this is to cool your car down very well, or install a turbo timer. There is just no way for the heat to exit the turbo effectively in this car (these comments do not apply to non S4 turbo cars).
    Jeder Bloedmann faehrt 'nen Porsche, Jeder Arsch 'nen Audi Sport
    Nur Geniesser fahren Fahrrad, Und sind immer schneller da
    as opposed to a "chipped" car
    Somewheretown, PA
    Thats the after run coolant pump. It comes on when the coolant is about 220 or something even higher. The only time mine ever came on was when my water pump went and the car was hot hot. So you replace the control switch with the one from ECS or you wire it into your TT, or a relay circuit controled by whatever you want. But if you read the whole thread you would have seen we already talked about this,, and theres a link to the part if you want one.
    reading, is half the battle
