Results 1 to 4 of 4
    Sep 28 2006
    Lexington
    Cruise Control Works After 20 Minutes of Driving Please HELP!
    Ok I know this sounds weird, but it takes my car about 20 minutes for my cruise control to work. Could this be in the switch, or could it be the module behind the glove box needing to heat up? I'm think when I shut off the car, the car needs 20 minutes for it to relearn the car has cruise control?
    Please Help!!
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Established Member Two Rings adam.wilber's Avatar
    Sep 15 2010
    NC, Fort Bragg
    press and hold the button in for like 30 seconds while holding a steady speed and see if it works... that's what i have to do with mine and even then it doesn't always work the first time.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    my car you have to tap the button a few times before it grabs and the cruise turns on.
    Are you going fast enough in that drive for it to work? I think its like 45 or 50+ before it works.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    the problem is with cruise control module, it needs to be repaired
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
