Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 167
  1. #121
    Veteran Member Three Rings stevengrande's Avatar
    Feb 28 2013
    NH
    Earlier this summer I brought my car to the dealership because I started hearing the same loud ticking noise as described in this thread. Fearing it was a follower issue, I had them check it out. They told me nothing was wrong and the noise was consistent with A4s with the FSi engines. Fast forward to seeing this thread, I'm bringing it to show them and then buying some JBWeld.
    -Probably sent while driving my A4 from my Nexus 7-
    2005.5 B7 AUDI A4 2.0T - UNITRONIC STAGE II / CTS TEST PIPE / GFB DV+ / RS4 RSB / OEM A3 STEERING WHEEL w/ PADDLE SHIFT MOD / LED INTERIOR MOD /
  2. #122
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Interesting, 100k miles on mine and no signs of this problem, just checked out the hose/connection on a cold start, absolutely zero movement.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
  3. #123
    Established Member Two Rings Avantageous's Avatar
    Oct 19 2011
    Dirty Glove Midwest
    I just went ahead and JB welded the hose to the cover after parking the car for the night.
    Started this morning and the noise is gone. Just like PDX04a4, I checked at 104K and no movement.
    But I like I stated, now at 106K and movement yesterday and tapping. Hopefully the fix will hold.
    Anyone who has done the fix for a while now can hopefully chime in. Also the brake issue didn't show up
    this morning. I am thinking this has resolved the issue.
  4. #124
    Oct 16 2008
    South Florida - Ft Lauderdale
    I came up with this fix and even today, at 140K, no issues
    Phil
  5. #125
    Oct 19 2011
    Dirty Glove Midwest
    I would like to thank fly300kts (Phil) for recognizing the problem and finding a solution.
    I apologize for not noting this.
    It's good to hear that the fix is holding up. I rechecked my weld and everything is solid.
  6. #126
    Junior Member Two Rings
    Aug 17 2013
    Tbilisi, Georgia
    Hi, i have read this thread, also have done this one. i have some RMP jump problem. after discuss this thread, i checked my vehicle and found this: http://www.youtube.com/watch?v=vExqaEZ23PA. so what you think about my car ? does this similar to vacuum problem or i should to replace this F***ing TC ?
  7. #127
    Active Member Two Rings Adamovich's Avatar
    Aug 16 2012
    Minsk/Belarus
    Seal "Pump to housing" - Victor Reinz № 40-76041-20
    2006 Audi A4 2.0T Quattro 6MT OEM+
    NGK BKR7EIX | ATE drilled front rotors | Eibach Pro-Kit | Ventus V12 Evo | F/R 15mm spacers | Interior LEDs | OEM LED license plate | Rear debadging | DTM spoiler | S line RV | Yellow Fog | R8 oil cap | Red Coil Pack Wiring Harness | VAG-COM mods
  8. #128
    Aug 17 2013
    Tbilisi, Georgia
    Adamovich
    what is a part number ?
  9. #129
    Active Member Two Rings Moxi's Avatar
    Jan 26 2014
    Boise, ID
    Same issue on mine, will post pics with before and after of issue with fix.
    Silver 2006 A4 Quattro 2.0T FSI (Sold)
    Silver 2010 A4 Premium + 2.0T FSI
  10. #130
    Oct 16 2008
    Quote Originally Posted by alecoder View Post
    Same problem. JB weld time
    Phil
  11. #131
    Oct 16 2008
    Quote Originally Posted by Avantageous View Post
    Your welcome
    Phil
  12. #132
    Aug 16 2012
    Minsk/Belarus
    Adamovich
  13. #133
    Veteran Member Four Rings Axis's Avatar
    Nov 15 2011
    3.0T 6MT Stage III Allroad | A4 B8.5 Sedan
    Montreal | I sell in USD
    Checked when I started my car when cold and I have this problem too, I was wondering if we remove the oem one use clip and we would put a 1" Fernco coupler on it, would it work?
    Not a fan of JbWeld put if I dont find an alternative I'll go ahead and JbWeld that sh!t.
    Wagons are made to haul things, mine is made to haul ass
    *****I sell in USD*****
    Click here to read my seller feedback
    B8.5 Allroad 3.0T 6MT Sport Diff 034 Stage II+
  14. #134
    Oct 16 2008
    Quote Originally Posted by Axis View Post
    Trust me, JB is the shit in this case
    Phil
  15. #135
    Veteran Member Four Rings Inked's Avatar
    Dec 11 2010
    Polaris Outlaw 525 Quad
    Central FL
    Phil
    x2....mines held up for 3 years now
  16. #136
    Established Member Two Rings mr_pulido88's Avatar
    Jul 02 2013
    Antelope Valley
    Would the loose hose and possible vacuum leak have anything to do with a CEL with codes P0011, P000A?
  17. #137
    Established Member Three Rings V2Rider's Avatar
    Feb 11 2014
    2011 Jeep Grand Cherokee, 2007 Audi A4 2.0T Quattro, 2006 GSXR 750 (very fast ) :)
    Minneapolis, MN USA
    Just looked at mine.....and I can pull the damn thing in and out! Wtf? Just gobbed a bunch of JB on it...we'll see.
    2007 Audi A4 2.0T Quattro TIP /Debadged/Piston DV/Hids/APR Stage 1 AMSOIL
  18. #138
    Feb 11 2014
    Minneapolis, MN USA
    I was just wondering......it almost seems to be like that on purpose. Is it supposed to move in and out, like a relief valve or something? If so, to late, lol. I already put the JB on it. Just wondering why it moves so freely.
  19. #139
    Oct 16 2008
    Quote Originally Posted by V2Rider View Post
    No
    Phil
  20. #140
    Feb 11 2014
    Minneapolis, MN USA
    Lol....ok then. Short and sweet :)
    When are you coming up to the arctic to put try the Bose :)
  21. #141
    Oct 16 2008
    Traveling in 2 weeks to Rice Lake, dropping off an aircraft.
    Trust me, if I can bail out, I will, don't like the cold
    Phil
  22. #142
    Feb 11 2014
    Minneapolis, MN USA
    Phil
    I'll PM you my number, if your up here, and have time, you can experiment on my car (and maybe discount me) ;)
  23. #143
    Oct 16 2008
    PM me but again, I am trying to pass along this trip
    Phil
  24. #144
    Feb 25 2012
    Hudson, Qc.
    Thanks for the solution Phil, same noise on the car and now it's fixed
  25. #145
    May 20 2010
    Way to resurrect a thread. I'm gonna try this. I notice that when I go from neutral to drive, my RPMs usually fluctuate. Maybe part of the cause. Plus my brakes sometimes have a bit of give, and sometimes not. Explains a bit... I hope.
  26. #146
    Sep 03 2013
    Nashville, TN
    Can say +1 to another one to solve noise and rpm fluctuations. Thanks Phil :-)
  27. #147
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Does the sound you refer to almost sound like a starter gear failing to disengage for a few seconds?
  28. #148
    Feb 15 2016
    Cambridge,Ontario
    just got pointed to this thread from a fellow enthusiast as i was having the exact issue. looks like the route cause is a failing oring where the plastic piece goes into the housing. as noted by adamovich above a new o-ring should fix it without JB weld. However what is not clear is how that plastic piece comes out. Is it held in place by the vacuum pump housing or will that whole plastic piece wiggle out so you can replace the o-ring ?
    without that info people are going to gob jb weld to fix the rattling , but could possibly still have a vacuum leak due to the failed seal .
    Thoughts ??
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  29. #149
    Oct 16 2008
    Thoughts ??
    jb weld
    Phil
  30. #150
    Feb 15 2016
    Cambridge,Ontario
    Ok thanks Phil. Looks like you were first so go try it so thanks for the tip. Funny think was guy thought this was serious issue so let the car go cheap 😉
  31. #151
    Veteran Member Three Rings Flexcj5's Avatar
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    Plastic valve is held in place by two tabs, one on either side. The valve has to be pushed down and tabs depressed then it pulls out. I've used "L" shaped needle nose successfully to depress the tabs.
    If your valve has up and down play the factory oring is the issue. It's square sided and seems to wear quickly. Replace it with a round oring and it will seal nice and tight.
    Silver 05 2.0t B7 REVO stage 2+ w/ ER SMICs, RAI DP & Stasis exhaust.
    Debadged and tinted on Eibach/Koni FSDs rolling on Euromesh 3's (245/35 R19 et33)
  32. #152
    Feb 15 2016
    Cambridge,Ontario
    Thanks Flex I think that is the cleaner fix I am looking for ..
    1976 Yamaha XS 360
  33. #153
    Feb 22 2016
    Mundelein, IL
    Sorry to resurrect a super old thread, but my car has exact same issue, with rather large vacuum leak. If I JB-Weld it, will that make it a huge PITA if I have to eventually replace the pump? Seems like it would be pretty difficult to separate the hose from the pump.
  34. #154
    Oct 16 2008
    Quote Originally Posted by Tarheel92 View Post
    No, you can scrape the JB weld off at later time
    Phil
  35. #155
    Established Member Two Rings Gerblack's Avatar
    Feb 15 2006
    2006 A4Q,tip 2.0TMarch 19
    Memphis, TN
    Your original Pictures are down any way we can get those back up?
    I live the life I love I love the life I live.
    AH-64D ATTACK baby
  36. #156
    Jun 23 2008
    Glad I found this thread, I noticed a wicked loud noise / rattle when I did my cam follower replacement earlier this week. Will have to see if my hose is loose too. So many little things on this motor!
  37. #157
    Oct 22 2018
    SOCAL
    Thank you so much. Mine did not appear to have movement, however there was a large area of deposits around the connection and metal. Cleaned the area and hose with carb cleaner and small wire brush followed by a toothbrush and isopropyl alcohol. JBWeld (for plastic/metal) 30min set time and now all is well.
  38. #158
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by hokipau View Post
    New oring would have solved it and look less ghetto. Its a Valid fix but ugly in my mind.
    1976 Yamaha XS 360
  39. #159
    Jun 13 2010
    Fairfax, VA
    Gotta thank Phil for the admittedly quick & dirty fix. Had this issue once the cold weather hit, and doing it his way took all of 2 minutes in the subzero temperatures (no garage).
    2007 A4 2.0T Brilliant Black Tip-tronic: Pictures
    DONE:
    Revo Stage 1 Flash
    RS4 Sway Bar
    ST Coilovers (24" F / 24.5" R)
    TO DO:
    Paint Calipers Red, Faux Carbon-fiber interior trim, Faux Ti Trim (Vinyl), Cupra R Lip
    Replace Symphony II+ with RNS-E
  40. #160
    Apr 11 2012
    2008 VW R32 Audi TT 225 mk1 audi B7 A4 1999 Jeep Xj B6 a4
    Corning NY
    anyone have a part number for the oring? have same issue. thanks
