Hi Guys,
For a month now, we get cold fronts in FL and since, when starting the car in the morning, I was hearing a really bad metallic banging noise, almost like a bad valve but once the car was warm, the noise would disappear. Checked the oil, WagCom for codes but everything was fine.
This morning, I replaced my cam follower, like every 15 000 Miles (and still, everything is fine at 100 000 miles). Then, started the car to check for leaks and I finally found where the stupid noise is coming from:
First picture to locate the area of concern:
Vacuum pump behind the High Pressure Fuel Pump. Notice the black traces in the area
Now some close up:
Check the difference between the 2 pictures and notice the gap when the elbow is pulled. When cold, the hose is really rigid and since the engine shakes a bit, it triggers the banging noise. Once warm, the hose absorbs the vibrations and the noise is gone. Of course, there is a leak as well.
Went to the dealer to see on ETKA what spares were available and the Vacuum pump housing needs to be replaced. No, thank you. Grabbed some JB Weld on my way home and tomorrow, will pull off the elbow and will apply a nice bead around the metallic tube of the vacuum housing
Let me know if any question
Phil
Phil
