Ynnekdude!
Here are some thoughts for you, probably going to be a bit of a read. I got a 3.0T A6 in here the other day as I hadn't been under one since they came out.
Ho-kai:
On the S4 Milltek system- Obviously silencer design comes into play, but positioning is incredibly important here as well. For clarification, we use short downpipes, then a resonator (which is effectively under the front seats) then it heads into the offset bends, into another resonator (effectively under the back seats) and now it splits to the rear, where it either enters mufflers then tips, or is straight to tips (non-res).
This allows the resonated system to be incredibly civil inside (read: as quiet as stock, eliminating stock drone (do you have that too?), and just changes the tone).
This allows the non-resonated system to be quite reasonable inside under reserved driving, yet open up when you get on it. Most of the sound comes straight out the back.
Sound level will be up to you of course.
Your downpipes are more like the downpipes on the V8, kinda come straight back horizontally, then come down and in a bit, and then follows a straight-back symmetrical path to the rear.
So while you are making a custom exhaust, keep in mind you could probably even do test pipes easily.
Anywho. I'd recommend doing similar placement on your custom set up.
Let me know what you think so far and I'll happily offer any additional info I can.
