Results 1 to 8 of 8
    Sep 18 2009
    Montreal
    What does that part?
    I did a leak test this week end and i found that the cap of this part : 058 133 753B, was off,
    So i tried replace it correctly but everytime i was putting 20 lbs it was popping, so i bought epoxy glue to fix it permanatly
    So do you think i should replace it?
    Jun 30 2008
    Erie, Pennsylvania
    It is not 2 pieces. It is one piece and there is no "cap". If it has blown apart, it is damaged and must be replaced. Epoxy is an OK solution in the short term, though.
    Make sure to get the updated part: 058 133 753D
    The new one is reinforced so it doesn't blow apart at that weak point.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Sep 18 2009
    Montreal
    Ahh ok so there was a weakness on this part! Alright then thanks for the info
    But what is this responsable of ? I remember when the "cap" popped off, my car started to goes wrong and my cel started
    blinking
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Is that the suction jet pump?
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Jun 30 2008
    Erie, Pennsylvania
    Yes, it is called the "suction jet pump". It provides vacuum to the brake booster as well as the PCV valve. It is somewhat mysterious how it works. It uses the small constant flow of the PCV system to amplify the vacuum applied to the brake booster, using the venturi effect. It was originally introduced on automatic only cars, but was later used on all Audi's.
    This part has a few weaknesses:
    - The most visible is it actually blowing apart, where the brake booster end comes apart under boost. This is due to it's weak plastic construction, heat cycles, the effects of the blow-by gases, as well as running higher than stock boost pressure (or pressure testing at high psi).
    - The other weakness is the propensity for the small PCV passage to clog up. This is common because of the oily blow-by gases create deposits on the internal passage, eventually blocking it off. Once this is blocked off, the venturi effect no longer works, so the piece is no longer adding benefit. Additionally, with the PCV system clogged, crankcase pressure can increase, also causing oil leaks, seal problems, contaminated oil, and sludge.
    If you understand how the vacuum system works, you can safely eliminate this device, but some vacuum re-routing and fabricating will be necessary. Normally, the best advice is just to replace it with the updated version. I also suggest to check the PCV valve while changing it. With the small hose disconnected, it is pretty easy to check it by sucking and blowing into the hose. It should flow with vacuum and close with pressure.
    Sep 18 2009
    Montreal
    Wow man! You really know stuff !! Thats crazyy !!
    Thanks imma buy. The new version:)
    Jun 30 2008
    Erie, Pennsylvania
    Not so crazy(!?) The vacuum system is not hard to understand, it just takes some study.
    Sep 18 2009
    Montreal
    Yes maybe but its not everybody in here that study weaknesses of every part in the vacuum line,
    Anyway thanks
