Results 1 to 3 of 3
    Oct 27 2006
    Currently only S4
    Fort Walton Beach FL
    Pressure control valve removal
    I'm doing the bypass on my aux water pump and am removing the y pipe. Already ran into a problem. Tried search and could not find an answer.
    Is there a trick to removing the pressure control valve from the y pipe? Do I just pull it out? I don't want to break it. Thanks.
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    The plastic ring around the clip should have two spots for you to squeeze, it'll pop right off after that.
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Oct 27 2006
    Currently only S4
    Cool, thanks a ton!
    Rob
