Page 321 of 321 FirstFirst ... 221271311319320321
Results 12,801 to 12,827 of 12827
  1. #12801
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    This. Fix the alignment and that wonít happen.
    Alignment wasnít off by much. Front right toe was barely out of spec. Camber is obviously out of spec. This was the right rear. It has the most camber dialed in. I think I just need to be better about rotating the tires.
    Still got 25k out of the set which Iím frankly satisfied with.
    And Iíd been wanting to drop down in size for a bit and switch to the Michelins.
    Just wish Iíd noticed it sooner so I didnít have to scramble around today but ultimately worked out.
    They price matched TR, kept their warehouse open so they could go get the tires today, installed and did an alignment.
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
  2. #12802
    Aug 18 2009
    A Unicorn
    Portland, OR
    25k isn't bad but be aware that this isn't camber related. That is textbook toe wear
    Edit. Had you caught it in time you could have had the tires flipped and gotten 45-50k out of them
  3. #12803
    Jun 02 2004
    LA
    Thanks. As I said I had it aligned too. But that tire also has -2.7 degrees of camber
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
  4. #12804
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by oatzel View Post
    It's not necessarily that it wasn't aligned, it's that factory alignment sucks for lowered cars - because the toe-in eats the inner edged of the tires. You really want close to 0į toe for best tire life. Especially once lowered
  5. #12805
    Jun 27 2011
    What Did You Do To Your Avant Today?
    Yea that extreme wear on the inner inch or two is from toe and camber combined. Zero out the toe and you wonít have that issue.
    Its worse with lowered cars but stock height cars can get the exact same wear if the alignment is hosed. Happened exactly the same as in your picture on my b6 at stock ride height because the toe and camber were out. Lowered heigh just exacerbates the issue.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - R8 V10 Coils and Spark Plugs - AMI retrofit - Mk2 RNS-E
    2012 Q5 2.0t - Stock Mommy Missile with new timing chains
    Former USP CLUB MEMBER #136
  6. #12806
    Senior Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Ecs just introduced their adjustable rear toe arms. They would help with this and at only $150 they would pay for themselves with just 1 tire.
    https://www.ecstuning.com/b-ecs-part...027967ecs01~a/
    2011 A4 Avant Prestige S-Line
  7. #12807
    Jun 27 2011
    B8s donít have adjustable rear toe? Weird.
    -CP
  8. #12808
    Senior Member Three Rings Dusty Mauve's Avatar
    Feb 04 2011
    Bergen, Norway
    Can be adjusted, but has its limitations.
    Static, what else?
    09 A4 b8 Allroad / 2.0TDI Revo
    00 A4 b5 Avant / 1.8TQ
    Instagram
  9. #12809
    Feb 07 2018
    Camas WA
    127.46 on sale (15% off)
  10. #12810
    Apr 01 2005
    one wagon one truck
    Michigan
    rear main seal last week at audi dealer while on vacation :(
    2003 A4 1.8tqms Mototec Cold air intake, USP door Blades, GIAC software and bigger injectors.
  11. #12811
    Registered Member One Ring BuiltA4's Avatar
    Jul 10 2019
    Nothing Worth Noting
    Phoenix
    Rubber Fender Trim
    Today I managed to add rubber fender trim around my avants' widebody kit. Just cleans it up a but. :)
  12. #12812
    Active Member Two Rings chounder's Avatar
    Jul 03 2017
    Oregon
    Got new pistons, rings and a timing chain...thatís what I did with my Avant today.
  13. #12813
    Veteran Member Four Rings Pat_McGroin's Avatar
    May 09 2010
    Downey Ca
    Not what I did but someone did to my avant while I was at work.
    Rick
    Brilliant Black 2008 S4 Avant Tip.
    Gone but never gotten - Ibis 2010 A3 2.0T
  14. #12814
    Established Member Two Rings cmess331's Avatar
    Aug 01 2018
    Richmond va
    Did someone miss the fact th6 there was a car to there right!!! Sucks that an s4 avant had to get damaged.
    Sent from my SM-G973U using Tapatalk
  15. #12815
    Jun 27 2011
    No note? People are such assholes.
    -CP
  16. #12816
    May 09 2010
    Downey Ca
    Quote Originally Posted by cmess331 View Post
    Super unfortunate. Nope, no note. ĎTwas a shitty way to end my day at work man, weíll see what my insurance will do.
    Rick
  17. #12817
    Established Member Two Rings DG7's Avatar
    Jun 02 2012
    B8 Avant, 8V S3 SB, F36 435i
    California/Tuscany
    Dropped off the avant at Pacific German. Considering an S4 swap.
  18. #12818
    Jul 03 2017
    Oregon
    all put back together! Special thanks to the guys @ Matrix Integrated for fixing what Audi of America wouldnít!
  19. #12819
    Apr 12 2018
    ga
    Quote Originally Posted by chounder View Post
    What caused your issue?
  20. #12820
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by dkmesa View Post
    It's a B8...
  21. #12821
    Jul 03 2017
    Oregon
    It's a B8...
    Ha! So true... new pistons, rings, timing chain & tensioner to name a few. But man I do love the look of the Avant, so Otto will be staying for a while :-)
  22. #12822
    Apr 12 2018
    ga
    It's a B8...
    Ha that's really the only answer needed. Was curious if it was due to one of the many B8 specific weaknesses or one of the many weaknesses that impact B8.5 as well. My car had a new short block under warranty by PO 20k miles ago, new turbo 3k miles ago, new fuel injectors last week. Holding my breath that it will be reliable for a decent amount of time to come haha.
  23. #12823
    Jun 27 2011
    Yikes. Thankful my Q5ís issues were limited to timing chain tensioners and I caught it before anything bad happened.
    -CP
  24. #12824
    May 09 2012
    Virginia
    It's a B8...
    Sadly it could be said because itís a B5, or an Allroad or a B6 or a B7 or a B8. They all have issues.
    We are all sick for staying.
  25. #12825
    Aug 18 2009
    A Unicorn
    Portland, OR
    True, but the B8 is a special kind of monster.
  26. #12826
    Senior Member Three Rings S-Liner's Avatar
    Oct 21 2014
    '11 Suburban LTZ
    Satellite Beach Florida
    I got my dash lit up; ESP, TPMS, and Parking Brake malfunction
    This sucks
    '10 A4 Avant Prestige Plus S-Line w/sport pkg
    My Oil consumption results..."Oil consumption measurement found to be using 3.26 quarts per 1000 miles"
  27. #12827
    Jun 27 2011
    Inb4 Audi says thatís normal behavior... haha.
    -CP
