Results 1 to 40 of 60
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Quote Originally Posted by CHECKERED View Post
    I was able to get a full set from a totaled RS4 for $1150 shipped fronts and rears
    Are the rear brakes on the RS4 different than on the S4? Floating rotor like the front?
    JHM Tune ~ JHM Intake Manifold ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ JHM 40/60 Rear Diff ~ JHM LSD Rear Diff ~ KW V3 Coilovers ~ Porsche 18Z calipers ~ BBS CH
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    Quote Originally Posted by mbgt72 View Post
    I did have one question though, with the brake lines, are the OEM RS4 ones stainless steel lines or just similar to S4 brake lines? Just curious, as to if there was a SS line upgrade option that could be done at the same time.
    On the outside they look similar, rubber, but they are stiffer, some people say they are internally stainless steel braided, I will actually cut one open and see, I have stoptech stainless steel lines in the mail, so yes you can get true SS lines, which I recommend because they are cheaper than new OEM RS4 lines.
    Quote Originally Posted by mad70sx View Post
    a write up for the rear RS4 brakes is coming soon (3-4 weeks I need extra parts). But to answer your question, the RS4 rear brakes are different, it’s a “semi floating rotor” ...I guess a hybrid between a true aluminum hat floating rotor and a traditional cast iron
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
