Page 14 of 60 FirstFirst ... 4121314151624 ... LastLast
Results 521 to 560 of 2386
  1. #521
    Jan 02 2011
    2014 S4, 1989 325i
    Either I suck at searching or this doesn't exist: When I unlock the car I want the LED drl's on but NOT the fogs. How can I disable the fogs but keep the LEDs on the leaving home/coming home setting? I still want to be able to manually turn on the fogs when I need them.
  2. #522
    Feb 26 2012
    Coquitlam, BC Canada
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    This is the setting that is to be used to do the windows and sunroof for the B8 S4 but for some reason does not work. Well it well put the windows up but not down. Does anyone have any ideas/suggestions. Thanks
  3. #523
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Did you check the settings in the MMI?
  4. #524
    Feb 26 2012
    Re the MMI settings. What am I to look for in this area as I had a fellow Audi club member do this for me. Thanks Stereodue.
  5. #525
    Feb 26 2012
    Hey Vincent, I have a question that maybe you or another member can help me out with. I have a 2012 B8 S4 and just did the following setting: Enable Remote Operation Windows and Sunroof [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2 Bit 2 - Set to 1
    but have an issue wit this. Maybe I am not doing this correctly, but when holding down the lock on my key fob the windows and sunroof will NOT go down. If put down manually the widows will go up if I hold down the lock on my key fob. Do you you or any other member have any ideas. The input was done by a fellow Audi Club member who has the Vag-Com cable and software. Thanks
  6. #526
    Veteran Member Four Rings achilleas101's Avatar
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    Hoseman, go into the Car Control module within the MMI. you should now see a new item, called windows. if you go in there, it has something like 'remote operation'. you have to enable that. i don't know the exact wording or if it's different if you have Navigation, but for me, without Nav, it's just a new menu item that appears under windshield wipers.
    Gone but not forgotten:
    2013 S4 Imola Yellow | Black leather/Silver Alcantara | 6MT | B&O | Sport Diff | Silver 19x8.5 Avant Garde m550 | XPel Ultimate full hood/fenders | Eurocode SS
    2003 A4 3.0 6MT;
    1998 Acura Integra GSR 5spd
    Gone and most likely in a junk yard somewhere: 1990 Toyota Tercel
  7. #527
    Feb 16 2012
    Hyundai i30
    Bergen
    VCDS & Hidden menu: The complete list
    Quote Originally Posted by Hoseman View Post
    If you hold the unlock key, the windows will open, and the lock key will close them.
  8. #528
    Veteran Member Three Rings lenti's Avatar
    Mar 31 2011
    A5 B8.5 3.0TDI -13
    Sweden
    Guys i got this VCDS cable today, and tried the VAG mods, everything works great, all settings and coding seems to work with Rosstech and the cable is cheap :D
    http://www.aliexpress.com/item/vag-1...858629615.html
    The Rosstech software seems to be registered but dont use any internet connection when using this cable and VCDS :)
    did the Parking light full brightness mod :D
    its really nice with that mod and use the Led fog lights
    Keep LED's at Full Brightness with Parking Lights
    This will stop the LED's from dimming when the parking lights are turned on.
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 3: Bit 2 - Change 0 to 1
    2013 Audi A5 3.0TDI Ice Silver / SC-6 20x10.5 / H&R Coilovers / 19mm Spacers / RS5 BBK Kit / BMC Intake / Custommade Tailpipes 4" / S-Tronic Software / Stage 2 DPF/EGR OFF by Stertman Motorsport
    Custommade Exhaust 3" straight pipes from Turbo
    346HP 730NM
    _________________________________
    For more pics visit my FB http://www.facebook.com/MR.Doberlluka
    For all my mods visit http://www.garaget.org/lenti
  9. #529
    Veteran Member Four Rings well_armed's Avatar
    Sep 19 2012
    Quote Originally Posted by lenti View Post
    Translation: Software Piracy is Fun!
  10. #530
    Active Member Two Rings All_four's Avatar
    Feb 06 2013
    '07 Volvo XC90 | gone but not forgotten '07 Black Magic GTI 6MT
    Pennsylvania, USA
    Has anyone tried to enable the amber side markers to blink with the turn signal? I don't know if it would actually be a potential VAG-COM adjustable 'feature' or if it would need a separate fuse (guessing these cars use electronics to blink versus fuses....).
    Most of you have probably either disabled, covered, removed, or never had amber side markers but I figure if they are there, I might as well try to get some additional use out of them
  11. #531
    Feb 06 2013
    Pennsylvania, USA
    B8.5 vag com differences
    Many of you have probably already noticed this, but for those of you with new s4's (and possibly new to coding modifications), these codes change a lot - even within a production model and calendar year
    If you go through some of the mods you want to do and notice that they are already checked, the label is a little different, or the feature isn't even in the same place - post a note and I'm sure you'll have some folks willing to help.
    Also, you may note that some of these features, once enabled, still need to be switched on, or activated to meet your tastes, within the MMI menu...so poke around
    Coming from a GTI, I have to say the '13 s4 software seems a bit more reliable and easier to navigate than the '07 Gti; then again, I assume it also shows improvement over the '07 s4.
  12. #532
    Jan 02 2011
    2014 S4, 1989 325i
    I want to be able to charge my cellphone while not in the car. How can I enable power to the aux/cig lighters while the car is off?
  13. #533
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    Quote Originally Posted by acaudi View Post
    not sure if it's possible, but why would you want to do that and run the risk of killing your battery? i've known at least 2 people who had that happen to them (in other cars) because they left something plugged into the lighter while they were away from the car for several hours.
    2003 A4 3.0 6MT;
  14. #534
    Jan 02 2011
    2014 S4, 1989 325i
    I've done this in every car I've ever owned for at least the past 15 years. I'm pretty sure the car battery can handle it.
  15. #535
    Feb 08 2013
    2019 Cayman GTS, 2016 Forester XT, 2013 S5, 2011 A4 avanti, 2004 TSX
    Got a 2013 S5, is there a way to have the fog light turn on automatically when headlight on? Also is it possible keep the DRL on when parking brake is on?
    2019 718 Cayman GTS 6MT
    2016 Subaru Dark Grey Forester XT touring
    2013 Audi Phantom Black S5 6MT Sport Diff, 20" BBS CH-R, Navi, B&O, PSS10, AK, EC sway, Alcon BBK, RS grille & Ecode
    2011 Audi Deep Sea Blue A4 Avant prestige, 19" OEM Ti rotors, PSS10, AK, sway, RS style grille + rear spoiler, Votrex diffusor
    2004 Acura Premium White TSX 6MT
  16. #536
    Veteran Member Four Rings thedollardoctor's Avatar
    Oct 28 2012
    Dayton, OH
    Anyone else have the issue of enabling windows and sunroof to open with keyfob and then only have the sunroof work? I can't seem to get the windows to go down with the keyfob with this feature enabled. Anyone have any thoughts? I tried disabling and re-enabling. I tried with the rear window "lock" on and off. Nothing seems to be working! I've had it work in the past so I am stumped on this one. For those of you who DO have this working, what are you doing with the keyfob? I am pushing unlock once and holding it, and my sunroof will "vent" up, but that's it. Any help is appreciated!!
    2013 Audi S4 | Ice Silver | DSG | GIAC/AWE Stage II with DSG Tune | Roc Euro Intake | AWE Full Exhaust w/ Resonated DPs | VMR V713 19x9.5 et45 Matte Black | H&R OE Sport Springs | USS Sway Bars and End Links | Alu Kreuz | Color Coded Custom Painted Headlights and Emblems by ONEighty Customs | RS4 Style Honeycomb Grille by ECS
  17. #537
    Senior Member Four Rings lapisia's Avatar
    Feb 24 2013
    audiland
    Quote Originally Posted by thedollardoctor View Post
    Did you check your settings in the MMI?
    2013 DSG S4
    goodies: eurocode / xpel
  18. #538
    Oct 28 2012
    Dayton, OH
    Quote Originally Posted by achilleas101 View Post
    Bingo! I totally forgot about this! Thanks bro...... I owe you one! And we both know what that "one" is don't we :-) I'll get to it tonight and PM you what I find.
    On a side note, I have enabled "mmi hidden menu" but..... apparently it's hidden from ME?!!? Where the hell are the hidden features? Am I retarded or something...... don't answer that |-)
  19. #539
    Feb 24 2013
    audiland
    car & menu at the same time.
    2013 DSG S4
  20. #540
    Oct 28 2012
    Dayton, OH
    Quote Originally Posted by lapisia View Post
    Thanks bro, I'm sure it's in this thread somewhere a hundred times, but I'm too lazy to look :-) thanks for helping a brother out
  21. #541
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    hahaha yep... awaiting patiently.
    do people know if hidden menu is only for Nav equipped cars in the 2013? will probably check that out tonight when i finally disable the DRL wink.
    2003 A4 3.0 6MT;
  22. #542
    Nov 21 2012
    Philadelphia, PA
    Dumb question but I'm about to make my first change later this afternoon. I want to disable the setting that turns the LED strip off when you're signaling it. I assume this is the right one, but wanted to be sure before I messed with it. Can someone confirm?
    Disable LED 'wink' on turn signal
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    Current: 2016 A3 w/ Black Optics
    Sold: 2013 S4 with AWE intake and resonated exhaust.
  23. #543
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by afig367 View Post
    Correct
  24. #544
    Nov 21 2012
    Philadelphia, PA
    Correct
  25. #545
    Senior Member Three Rings Creatre's Avatar
    Mar 18 2012
    Summerville, SC
    Is there anyway to keep the Music playing after you turn the car off, but before you open the door? My B8 A4 with MMI/Nav had this feature, however my B8.5 without MMI does not do this. I find it playing before opening the door quite luxurious and nice to finish songs/discussions depending on what I'm listening to. I thought I saw a thread on this a few days ago, but can't find it now and doing vag com stuff tonight.
    Anyone know the coding for this or where to set in menus?
  26. #546
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    My B8.5 has done that since I picked it up from the dealer.
  27. #547
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    Quote Originally Posted by Stereodude View Post
    +1
  28. #548
    Jun 28 2012
    North NJ
    as does my '12 B8 although I have MMI so perhaps that is the deciding factor?
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
  29. #549
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    ok, i finally got into the parking brake module with security access. followed the order - security access, enter code (78713 for the 2013s for those still looking for it), close, go to adaptation. i want to change it so that i don't have to depress the brake pedal to release the parking brake, but the channel list is not by numbers per se. it's a drop down. the one that seems right is "manual release", as it has 2 values possible "with button and brake pedal depressed" or just "with button". the first is what's selected currently.
    i select the other - "with button", click do it, it prompts me to use the default shop codes, but then it give me an error that the workshop id is not accepted by the controller. followed by another popup saying "request sequence error."
    anybody run into this?? what am i doing wrong? do i need a different workshop number, or to do something else first?
    edit: summm bitch, i figured it out. went to another control module (did the DRL blink one) and it had 06325 in there for workshop number. so i used that in the parking brake module and it worked. FINALLY. So not sure if that workshop number will work for everyone or if you have to see whats in your car specifically, but apparently, you can't just use 12345.
    is Vincent9993 updating the initial post with new info, in particular for the B8.5 differences?
    2003 A4 3.0 6MT;
  30. #550
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    and on a separate issue, trying to go into 5F to enable the hidden menu, i get a "no response from controller" error. is this because i don't have Nav and it's not there? or something elese??
    and btw, i AM using a ross tech legit cable in case anyone is wondering if that might be an issue...
    2003 A4 3.0 6MT;
  31. #551
    Feb 06 2013
    Pennsylvania, USA
    Do you have the car turned on? This is typically because the cable is not active (look for the light on the connector)
  32. #552
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    Quote Originally Posted by All_four View Post
    yep, am able to do everything else with it. i don't have the ignition on typically, but car is on and light on the cable is green.
    2003 A4 3.0 6MT;
  33. #553
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Quote Originally Posted by Schadenfreude View Post
    Maybe, I missed that he didn't have MMI when I read his original post. I have MMI also. So, the lack of MMI might explain it.
  34. #554
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    I don't think there's a hidden menu if you don't have NAV. What are you trying to do that requires access to the hidden menu?
  35. #555
    Jun 28 2012
    North NJ
    This. DavidB8's site lists the coding as "(Only for navigation equipped cars)"
    http://www.audienthusiasts.com/VagComMMI.html
  36. #556
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    ah, so lack of Nav it is. oh well, no biggie. Was gonna futz around with the aux vent, but that's not a big deal. Was more concerned that i had something wrong but that explains it.
    2003 A4 3.0 6MT;
  37. #557
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Re: VCDS & Hidden menu: The complete list
    I have a 2008 C6 WITH nav and I get the same message as you. I'm trying to activate gauge sweep but after reading around, I'm not sure it's available on MY 2008 or earlier.... anyone?
  38. #558
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by SlickMachine View Post
    I finally just called Ross Tech, my 2008 instrument cluster doesn't support gauge sweep, for those attempting the same thing.
  39. #559
    May 27 2013
    CR
    Hi,
    I have an Audi A4 1.8TFSI of the 2013, ECU MED17.5.2, I want to know if someone can give me the engine´s long coding list, I need to switch the area to Rest of World. The engine´s long coding is:
    0A031013040400002000
    thanks
  40. #560
    Mar 26 2013
    baltimore
    thanks for this
