Page 52 of 60 FirstFirst ... 2425051525354 ... LastLast
Results 2,041 to 2,080 of 2386
  1. #2041
    Feb 12 2018
    Toront/Ontario/canada
    Anyone know how to increase alarm horn sound.
    My A3 was load
  2. #2042
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Quote Originally Posted by Adams-Allroad View Post
    My A3 was load
    It's been discussed on the B7 A4 platform. No dice on that platform ... I wish!
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
  3. #2043
    Established Member Two Rings Antique-ace's Avatar
    Mar 02 2014
    Central KY
    Question Need help activating ambient interior lighting
    I've made several attempts to enable the ambient interior lighting on my 2014 S5 coupe (MMI 3G plus) without success. I've tried the following:
    From the green (hidden) MMI menu:
    Go to car -> carmenuoperation -> interior lights -> set to 5.
    return to car then go to cardevicelist and made sure interior lights is highlighted
    reset MMI
    After the MMI resets this change does make the "interior lights" option appear on the "Car" MMI menu but it is greyed out and when I click on it I get a message that this feature is not available.
    I also tried adding the following step to those above in the green (hidden) MMI menu:
    go to carbusassignment and change "interior light" from unspecified (9/9) to CAN Komfort (1/9)
    (I also tried changing this to the 5/9 setting)
    Reset MMI and I still cannot access the "interior lights" option on the "Car" MMI menu.
    Any help would be appreciated.
    2014 S7 Prestige: Brilliant Black / Black Valcona / Carbon Atlas | 20" 5-parallel-spoke, Innovation pkg, Cold Weather pkg | Coded with OBDeleven |
    2014 S5 Prestige Coupe: SOLD
    2010 S5 Prestige Coupe: SOLD
  4. #2044
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    And you have also coded the below ??
    Code:
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 16
    Bit 6 - Interior/Ambience Lighting Adaptation active
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
  5. #2045
    Sep 06 2017
    05 Subaru LGT (HTA71)
    MA
    Did you try accessing that option with the car in a different mode? Like fully engine turned on? Or in accessory mode? Or battery on engine off mode?
    I've noticed certain MMI options are sensitive to the state the car is in. Honestly now that I'm thinking about it the engine probably has to be on for that one
    > S4 Swapped B8 Avant <
    > 2015 Glacier White allroad P+ (RIP) <
  6. #2046
    Mar 02 2014
    Central KY
    Quote Originally Posted by rlarsen View Post
    Code:
    [09 – Cent. Elect.]
    No, I will give that a try. Thank you.
  7. #2047
    Mar 02 2014
    Central KY
    Quote Originally Posted by Allthea View Post
    Yes, I tried accessing the option with the engine running and also with the engine off. I will try again though. Thanks.
  8. #2048
    Mar 02 2014
    Central KY
    Code:
    [09 – Cent. Elect.]
    That coding did it! Thank you Rene! My interior ambient lighting is now enabled and works perfectly.
    Also the engine must be running to access this menu option (and any of the other "Car Systems" menu options).
  9. #2049
    May 10 2016
    florida
    anybody knows where to find coding info for MMI video in motion setting for a audi b8
  10. #2050
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by mnthny4 View Post
    Everything you need is here: http://www.audienthusiasts.com/Articles_VIM.html
  11. #2051
    Mar 05 2016
    Is there a coding via VCSD for the fogs lights to come ON/OFF same time with the headlights low beams?
  12. #2052
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by TC_S4 View Post
    I asked the same thing. Answer was no
    2011 A4 Avant Prestige S-Line
  13. #2053
    Established Member Two Rings nelsonlye's Avatar
    Feb 26 2018
    Kuala Lumpur
    Hi all, i'm trying to search for the code to disable "Engine Shut Down" When the Driver side door is open.
    Example:
    1. When you stop you car, put your gear to "P"
    2. Open the Driver Side Door
    3. Engine will shut down.
    Is there any code that I can disable the engine shut down? been searching for this code, however can't get any.
    Thanks.
  14. #2054
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by nelsonlye View Post
    Example:
    Thanks.
    Every time you open the door the engine shuts off? Talk about a huge PITA what car is this on?
  15. #2055
    Feb 26 2018
    Kuala Lumpur
    Quote Originally Posted by Novarider View Post
    Yes Sir, everytime when i stop the car, and open the driver door, the engine will stop. However got sometime it don't shut down. I yet to get the logic. B8.5 model
  16. #2056
    Jul 02 2017
    Knoxville TN
    Check this thread out. Does your car have the auto stop/start feature like if you are in traffic?
    There is a code in that thread you can try. Few people said it worked.
    https://www.audiworld.com/forums/a6-...2834841/page6/
  17. #2057
    Feb 26 2018
    Kuala Lumpur
    Awesome, Thank you very much. Will try on the coding.
  18. #2058
    Feb 05 2018
    Atlanta
    Hello, new to all this, it seems like I’m stuck on this screen and can not exit. I pressed the car button but no luck. I pressed all the buttons but still no luck. Any help?
  19. #2059
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by dev1983 View Post
    Have you tried the three finger restart ??
    Rene Larsen
  20. #2060
    Feb 05 2018
    Atlanta
    Thanks!!
    I went to go try that method but I guess the car just needed to power down for a bit. All good!
  21. #2061
    Veteran Member Three Rings USAF_Danny's Avatar
    Mar 05 2015
    Supercharged E92 M3, A3 E-Tron
    Orange County, CA
    Quote Originally Posted by Antique-ace View Post
    I did everything correctly and even turned up the brightness but I can't get mine to work :(
    YouTube: DV Motions | Instagram: @danny.vuu @undisclosedm3
    []SQ5
  22. #2062
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by USAF_Danny View Post
    Not working - what of it doesn’t work ??
    - do you get the MMI menu item, and if you do, can you then select a new value on the dial ??
    - do test it with doors closed ??
    - etc.
    Rene Larsen
  23. #2063
    Mar 05 2015
    Orange County, CA
    - etc.
    I unlock the hidden menu, turn it on to active through VCDS, Turn the brightness up on the MMI, turn in my head lights, and the footwells aren’t on.
    []SQ5
  24. #2064
    Mar 20 2009
    Copenhagen, Denmark
    And with closed doors ??
    Rene Larsen
  25. #2065
    Mar 05 2015
    Orange County, CA
    Yeah. I tested it while I was driving too, no go.
    I have no idea what’s wrong. When I first did the coding, I didn’t activate the byte so it was grey in the MMI screen. After I activated it, it allows me to adjust the brightness so I did full brightness.
    It won’t work for some odd reason. But as soon as I open the door, the footwells come on like normal.
    []SQ5
  26. #2066
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Some time ago (maybe 1 year) I've installed e-codes and had the code removed by a shop. Worked well.
    Now I've recently purchased a ross-tech cable and started playing around with VCDS modifying some of the elements from page 1 to my likings. Even tho the settings for disable amber lights are OFF, I still get the code now. I've done a auto-scan export but I'm not sure if it's safe to post it here?
    Any idea if something else than this code is necessary to remove codes comming from installing e-codes??
    [09 –Cent. Elect.] [Coding -07] -> Long Coding Helper -> Byte 10 Submodule 0
    Bit 3 - Set to 0 to disable amber side markers
    Murdered B8.5 S4
    Build Thread
  27. #2067
    Mar 05 2015
    Orange County, CA
    Got the ambient lighting to work.
    Anyone know any codes for the high beams, mine won’t stay activated now for some odd reason. I have to push/pull and hold the stick in the position to keep it on.
    []SQ5
  28. #2068
    Sep 06 2017
    MA
    What was the fix in case someone else runs into a similar problem?
  29. #2069
    Mar 05 2015
    Orange County, CA
    I just reversed all the codes and re-activated them. That did it for me.
    []SQ5
  30. #2070
    Mar 31 2008
    eS-4
    CAL*SO
    how can I change the brightness of the DRL while the fog light switch is on?
  31. #2071
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    Anyone know how to change the minimum speed for the cruise control to activate?
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
  32. #2072
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by mys4.org View Post
    You need a B9 so you get the Stop’n’Go cruise control - OEM on the B8 the minimum speed is 30 kmh, and this can’t AFAIK not be changed.
    Rene Larsen
  33. #2073
    Sep 06 2017
    MA
    so I finally got a cable and cheap laptop. Now to figure out how all this stuff works. I need to go dig up an intro page that gives more step-by-step beginner info and then once I've tried a couple with some detailed instructions I'm sure everything on the first page will make sense.
  34. #2074
    Established Member Two Rings Blueiris's Avatar
    Aug 13 2018
    B8.5 S4, B8 Q5, Honda Snow Blower, Craftsman Lawnmower...
    Boston/MA
    Can someone help me with accessing the secret green menu? I have unlocked it via OBDEleven but not sure how to access it.
    2015 S4 Prem+ Black Optics
  35. #2075
    Feb 25 2018
    North West, UK
    Have you reset the MMI?
    http://mr-fix.info/audi-mmi-force-restart-reboot-2g-3g/
    Sent from my ONEPLUS A5010 using Tapatalk
  36. #2076
    Aug 13 2018
    Boston/MA
    Quote Originally Posted by Clowny View Post
    I have, but don't see any additional menus
  37. #2077
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    It's not an additional menu, it's a button combination
    Quote Originally Posted by Blueiris View Post
    2018 A4 | Mythos | Prestige | S
  38. #2078
    Aug 13 2018
    Boston/MA
    Quote Originally Posted by JBAeroEngineer View Post
    What's the button combination to access it?
  39. #2079
    Jul 02 2017
    Knoxville TN
    Deleted
  40. #2080
    Junior Member Two Rings audia4avantB7's Avatar
    Apr 16 2011
    Ford Focus(wife’s car)
    Netherlands
    B8/B8.5 VCDS &amp; Hidden Menu: The Complete List
