Results 1 to 18 of 18
    Senior Member Two Rings Peterjk4's Avatar
    Apr 18 2009
    B7 RS4
    NoVA
    Large fuses in Aux Fuse Panel- Need Identification
    I have been having some electrical problems and may have found the cause. The previous owner tapped into one of the 40AMP 32V fuses and its blown ,the wiring seems to be fine.
    The fuse is in slot E right in footwell, bottom left
    I just don't know the following:
    1. what the fuse is suppose to be rated at?
    2. What its for?
    I will take a picture of its location.
    All of the other fuses are 50AMP 32V
    Any help would be great
    Current- No V.A.G.
    Gone, but not forgotten:
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    98' C5 A6 2.8 Avant QA
    01' B5 1.8T Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Apr 18 2009
    B7 RS4
    NoVA
    Does anybody have a Bentley for the C5?
    Current- No V.A.G.
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    Actually I have mine right next to me. Give me a little while to flip through it, if its not in there I can go through the elec bently i have as well.
    '24 CX-90 PHEV | '68 GTO 4MT | '20 GMC Canyon (No rings to be seen :/ )
    Previous - G01 LCI X3 | F25 X3 | '14 Ibis White B8 A4 6MT | '03 B6 3.0 6MT | '00 C5 4.2
    Oct 24 2009
    2011 X3
    CT / RI
    is this pass or diver footwell?
    Oct 24 2009
    2011 X3
    CT / RI
    The only thing that I can come up with right now, is the right a pillar connector station, I can't find anything else with an E location, and the right a pillar connector station's slot E should be open. Let me know where your looking at. I want to say that your looking on the drivers side foot well, where you have to drop the panel under the steering column and disconnect teh light and OBDII port, correct? If so im not showing a slot for E on the 13-fold relay panel, the 8-fold relay panel, and the micro central elec panel that resides in the driver footwell.
    Apr 18 2009
    B7 RS4
    NoVA
    Thats correct, I'm looking down in the drivers side footwell
    The order I see the fuses in:
    D E F
    [15a Normal Maxi] [??40Amp Large Maxi] [50Amp Large Maxi]
    The E slot had a blown 40Amp large maxi fuse.
    Current- No V.A.G.
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Apr 18 2009
    B7 RS4
    NoVA
    I'll take a picture and post.. that might make this easier.
    Thank you for your time!
    Current- No V.A.G.
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Oct 24 2009
    2011 X3
    CT / RI
    Ill look it up some more when I get back to the house today. Ill be posting up some Bentley info to see if either im not following correctly, or if either of us is confused. I dont have a physical 13-fold relay panel to look at, so Im stuck with bentley pictures. I should post this infor up around 4-5 this afternoon.
    Apr 18 2009
    B7 RS4
    NoVA
    Current- No V.A.G.
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Oct 24 2009
    2011 X3
    CT / RI
    alright thanks. Im making up some pancakes and then ill take a look at the bentleys and ill let you know!
    Oct 24 2009
    2011 X3
    CT / RI
    Alright, that is the 8-fold relay panel.
    Slot F: is correct with a 50A fuse that is for the ABS module
    Slot E: That should be a 40A Fuse for the Engine Cooling fan.
    Slot D: is correct with a 5A fuse that is for the Engine Cooling Fan Control Module
    Slot C: is the not used until 2002-2004
    Slot B: 40A fuse for the Level Control system (should only be for allroad)
    Hope this helps.
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    Pancakes sound pretty good right about now..I may have to stop by the waffle shop on the way to the Autozone
    That helps, Thanks for taking the time to look this information up.
    Also I saw you have a A4 3.0 6spd.. I just sold mine this summer and regret it everyday!
    Oct 24 2009
    2011 X3
    CT / RI
    Quote Originally Posted by PSU S4 View Post
    Yeah I love the car, but it just isnt the old C5 I had. Dont, get me wrong, the car is great. Its just not my first love you know?
    You two are in the same town? Thats pretty slick. The closest AZ'ers to me is about 20 minutes, then 30, then 45 away.
    Apr 18 2009
    B7 RS4
    NoVA
    PSU S4 is my younger brother I was using his laptop in the garage....oops
    I totally understand, the B6 wasnt my first love either. If I could fit into a B5 comfortably longer then 1hr before my back starts to hurts (I'm 6'5) I'd keep the 96' A4 12v forever. The C5 is definitely growing on me though, its very comfortable and a great hauler. It carried over alot of what I liked from the C4's (size being the most important). The only draw back for me is the automatic transmission, I have been contemplating swapping a 5 or 6 speed manual, but cant justify it on a sub $1,000 car..
    Current- No V.A.G.
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Oct 24 2009
    2011 X3
    CT / RI
    Did you ever replace the fuse? Just wondering if your election problems went away or not. . .
    Apr 18 2009
    B7 RS4
    NoVA
    Yes I did, believe it or not, the transmission short to ground problem i was having went away. I found a few more spliced in wires, I have no idea what the previous owner had wired in. So many hot wires were taped and then grounded to either 40-50amp fuses, I think he wired in a vacuum cleaner :) I also found another Maxi that was blown and replaced it.
    While on this topic again, I am wonder if I am missing an relays in this photo?
    Current- No V.A.G.
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Oct 24 2009
    2011 X3
    CT / RI
    We in the same spot? Driver footwell? I don't have my bentley with me in mississippi. Ill call someone at home to get to the house and see what he can come up with.
    Apr 18 2009
    B7 RS4
    NoVA
    Hey no need to do that, It can wait for another day. I really appreciate the kindness
    Current- No V.A.G.
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
