Results 1 to 18 of 18
    Established Member Two Rings radioactive's Avatar
    Aug 23 2009
    Chicago, IL USA
    Connecting a USB flash drive to B8 A4 P+
    Hi Guys,
    I have a 09 A4 P+, It has a Ipod connector but I want to use a USB flash drive instead of ipod. Can I use this one in the link..
    http://www.ecstuning.com/Audi-B8_A4-...5074/ES265074/
    2009 A4 2.0T P+ Quattro, Tiptronic
    Brilliant Red
    Vag-com Mods
    LED interior and Rear Licence plate
    Xenon Match Fog lights
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    Quote Originally Posted by radioactive View Post
    Hi Guys,
    Yes - that is the Audi AMI adapter for USB. It'll work just like the SD cards in your dash.
    Senior Member Two Rings FmL 50cmonsters's Avatar
    Mar 18 2010
    Hilton Head Island, SC
    Will this work with a USB external Hard drive? Is there a storage limit like the SD card slot? Unfortunately all of my music does not fit onto the 32GB SD card, which I believe is the max size SD card accepted by MMI
    Stock: 2010 Deep Sea Blue/Cardamon Beige A4 Premium 2.0T 6MT w/Sport Package
    Mods Installed: APR Stage II Tune, 034 HFC, Eurocode IC Pipe, H&R RSB, AWE Downpipe/catback, VAG-COM, Halogen > Ecodes, H&R Spacers 20r/15f, Weathertech floor liners, JHM Solid Throw Short Shifter, Blesk LED license plate
    On the way: Saving for dem coils
    Chris
    Veteran Member Three Rings John4378's Avatar
    Mar 19 2009
    Houston, TX
    Can you connect the AMI - USB cable to the HTC EVO's USB - micro USB cable to use for playing Pandora through the car's audio while simultaneously charging the phone? If so, this is a no-brainer!!!
    Dearly Departed - 2008 A4 Avant 6MT S-Line w/ APR Stage 2, 034 HFC
    2006 Lotus Elise
    2005 Ducati Monster S2R
    2006 Ducati Monster 695
    2009 A4 6MT S-line w/ APR chip, AWE exhaust, AWE FMIC, Eurocode HFC
    2011 Ford Explorer - Family Swagger Wagon.
    Jul 12 2010
    Q5 3.0T
    32GB and still not enough for you?
    2010 A4 quattro, Tiptronic, Ibis White
    Oct 23 2010
    LA
    ^^ seriously...I have 8gb and it's way more than enough, hell, I even have some vacation videos on there and there's still space left.
    Mar 18 2010
    I have over 400GB of music alone.
    Chris
    Jun 18 2009
    coventry united kingdom
    I had a 320gb usb drive that i tried to connect to my ami,but it wasnt recognised.I think its cos id reformatted it to ntfs as opposed to fat32.I have a 160gb ipod classic attached at the mo with 60gb of music on it.Its a real pita scrolling through.Ill end up in a ditch soon cos i cant scroll and drive....so a few playlists on a smaller drive will do me thinks.I like my face the way it is!!
    Way Too Impatient
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by FmL 50cmonsters View Post
    Wow, that's pretty impressive!
    Have you considered having multiple 32GB cards to have different styles of music/playlists?
    Brandon @ VMR Wheels
    Mar 18 2010
    I have considered it, but obviously if someone could confirm that this usb connector could connect to my 500gb external drive, I would both have everything in one place and not have to worry about losing little SD cards. And I could always organize my music into playlists on the drive anyways to avoid the scrolling/loading issue inherent in having 400GB of music arranged by artist. I feel for johnniethepie even with 32GB it can sometimes takes forever to find what you really want.
    Chris
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Essex, UK
    I'm afraid to say the limitation is not gonna be the disk size. In the UK a few guys have tried big disks and the AMI simply doesn't support more than 4000 tracks. On guy even checked with Audi that he'd be able to use all the 250Gb on the "Audi Centenary Limited Edition HDD" and they said yes.......and then they admitted they were wrong.
    A HDD needs to have a max starting/continuous draw of 500mA.
    Unless they've updated the system since my MY2010 then I believe the manual still holds true :
    "USB mass storage device and memory card: max. 4000 files in total and max. 1000 files per directory"
    I put a iPod Classic in (via my AMI) and that's 160Gb so that's fine for my 100Gb of music. I guess with 400Gb of music you may need to wait for a bigger iPod to come out as they don't suffer the 4000 file limitation.
    Having said that I just found this from March :
    "I use a 320GB Segate 2.5" drive (Old one out of my Dell laptop after an upgrade) I mounted this into a SilverStyle caddy, cost me £20 from scan.co.uk. Using this with the standard Audi AMI to USB cable and pluged into a standard USB to mini USB to caddy. Formated the disc using Windows to FAT32, filled with 18,000 odd tracks (my complete music collection to date) Works fine. It remembers the last track it was playing, even if I remove from car, add more music onto drive and replace. (With ingition off off course) Fits into little tray too.....
    Point to note, Yes the disk is powerred as soon as you plug it in, as I see a green activity LED on the caddy flashing, but then goes to sleep after about 5 mins of no activity, so Yes the disc isn't running continually so don't worry.
    One thing I changed from the standard iTunes folders, was I changed the way I organise my music on the HDD for easy navigation from the MMI.
    I basically made 26 Folders at Root Level, AAA,BBB,CCC - ZZZ then copied each artest into each lettered foldesr, so AbbA into AAA, Boyzone into BBB etc, then from the MMI interface its very easy to find a track by just say 4 clicks, you can get to any album in your collection, for example, 1/ scrol to VVV, 2/ scrol to Vertical Horizon in list, 3/ Scrol to Album Name in list? 4/ Press to Play, so thats only 3 levels down and one click.
    On an iPod to get to Artest begining with V would take loads of spinning of the MMI wheel, if like me you have a large music collection.....
    Hope this helps."
    Jun 18 2009
    if you flick the mmi wheel real quick then it turns into a quicker search menu
    Way Too Impatient
    May 16 2009
    Maine aka Canada Jr.
    i have a 500gb drive hooked up to mine... no limit that i've found for drive size... just limit of how many files you can see at a time.
    Mar 19 2009
    Houston, TX
    Quote Originally Posted by John4378 View Post
    Will this work?
    2006 Lotus Elise
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Bring back the Phat Box with way more capacity
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Aug 23 2009
    Chicago, IL USA
    I took the risk to order this. I was able to connect a 16GB USB flash drive. Not tested the bigger ones yet. But will post after this week end
    Brilliant Red
    Vag-com Mods
    Active Member Two Rings basamx's Avatar
    Jan 21 2012
    Lexus ISF
    Franklin
    Hi, I have the iPhone 5, instead I getting an adapter, can i just get the USB mmi connect and plug my iPhone into that? Will it work the same way?
    2009 Audi A4 B8 | LED License Plat Lights | H&R Sport Springs in-transit | VMR V710 19" Gunmetal ORDERING
    Jun 03 2009
    Raleigh, NC
    Quote Originally Posted by basamx View Post
    No. The Audi AMI cable has a chip in it to allow the Apple interface to work with the MMI interface. The new adapter between iPhone 5 & AMI Cable will be necessary.
    Tschüß!
    Šave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hüper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/ÜSS • Hankook V12's • ST-40 BBK
