If you actually knew how to write, I would understand what you meant. You said flashing a car requires tools\labor\etc. I HAVE chipped cars and DO know how it works and can tell you for a FACT, no it doesn't. Unless you are chipping, say, a 2010 A4 where the ECU has to be pulled, taken apart, set in write mode with a node in order to load the software, and then put back together to be reinstalled in the car. That's labor. Plugging a USB cable from a laptop into the OBD II port of a car, logging into a VPN, entering some info., and clicking "Go" does not justify $100 in labor cost.
