Results 1 to 12 of 12
    Apr 18 2009
    trunk cannot be completely closed help plz
    Hi guys,
    Most of time that I shut the trunk, the lock of the trunk wont lock the trunk. Very few times, trunk will be locked during my driving. A few weeks ago, I used to shut my trunk hardly in order to close my trunk completely, but it doesnt work in that way anymore. So, I have to keep my trunk unlocked and going up and down while im driving.
    I checked out some other similar posts for trunks, and I assume that we have got different problems. Am I wrong?
    Any suggestions?
    Thank you very much guys. Have a good holiday.
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    I ran into a sililar problem a bunch of times...
    trunk just wouldnt close...
    for me it was an easy fix....
    I close the trunk by putting my hand directly above the lock when I push it down to close...
    for some reason it closes every time!
    Oct 20 2008
    Denver
    2 threads on same problem?
    Apr 18 2009
    Quote Originally Posted by HamidsVikes View Post
    I did that too but it didnt work for me tho
    Apr 18 2009
    Quote Originally Posted by AudiTFSI3o3 View Post
    Hey could you plz tell me where is the other post and the solutions is. Very appreciated for ur help man.
    Established Member Two Rings Dre_audi's Avatar
    Oct 24 2009
    tricycle
    toronto
    Are you sure its not frozen... this happened to me 2 nights ago and i just got out the blow-dryer and thoughed out all the components
    Senior Member Two Rings jayM's Avatar
    Jun 28 2007
    Lol, I tried the blow dryer which didn't work but a quick spray of wd40 did the trick.
    Apr 18 2009
    Quote Originally Posted by jayM View Post
    Hey, man. How did you spray on the latch? Did u take out every stuff and spray on them or just spray on the latch without taking the panel out? Thank you very much.
    Jun 28 2007
    i did not take the panel out, just be careful not to get it on the carpet. good luck
    2012 Mercedes-Benz C350 4matic Sedan
    2006 Audi A4 2.0t quattro - Sold
    Vancouver, Canada
    Apr 18 2009
    Sweet. I will try that later. Thanks a lot man.
    Sep 07 2009
    10 Allez|09 SJ
    Royal Oak, MI
    also check the rubber around the trunk. for a while i had to slam my trunk since it wouldn't close and it turned out the rubber was coming off. reattaching it fixed.
    Hello: 2012 A4 Avant - Stock!
    Goodbye 2013 S4
    Goodbye:07 A4 | Huper Optik 30% | Whispbar
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    GO B7 forum...would you expect anything less than stupidity????
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
