I just bought an A4, and the speedometer and odometer don't work.
The only code it has is Vehicle Speed Sensor - Implausible Signal
I swapped out the VSS with a new one, still no speedometer, and the code is back.
If I go into #17 on the diagnostic display (in the heater controls) it shows 0 for vehicle speed all the time.
I checked the wiring at the plug for the VSS, and it looks fine. One pin tested good for ground and the other must be for signal.
I'm thinking the only thing left is something inside the tranny... probably a magnet? It's a manual.
Does anybody have any input on what to replace and how? I've searched but haven't found much info.
Thanks in advance
FIXED! Solution is HERE: http://www.audizine.com/forum/showth...ausible-Signal
