Results 1 to 10 of 10
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    RAI "Threaded J-Pipe for CEL prevention" - Question
    My cat is failing I get a P0420 cody...which indicates a failing cat, right?
    Will the use of this pipe: http://www.raimotorsport.com/RAI-J-P...p/11620vib.htm allor me to turn off this code?
    Also, if anyone is selling a working OEM catalytic converter please PM me.....thanks
    -Sami-
    Aug 17 2009
    Pittsburgh
    I have this on my B6. It does not work. It is hit or miss. Really really nice piece though, and Clint@RAI is a heck of a guy. Great customer service for sure. I'd get it. If it doesn't work, just get the secondary O2 coded out.
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    So the test pipe they advertise on here for getting rid of your "cat" with no check engine light doesn't clear your check engine light? interesting.
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    ^^ i've been fighting to get my 5spd to pass for 4 months now (hasn't been legal to drive since i bought it), installed a J pipe just before one of the coolant hoses blew apart. got the coolant line fixed, going to try to get it passed AGAIN on Wednesday this week, i'll let you know how it goes.
    Feb 19 2007
    Charleston, SC
    Thanks for the responses guys.....Also, if anyone is selling a working OEM catalytic converter please PM me
    -Sami-
    Senior Member Two Rings Alphazuzu's Avatar
    Oct 05 2008
    Holly Springs, North Carolina
    My car has been illegal for over a year..... all because of this stupid CEL cuz I have a test pipe. I have tried everything, I even went BT and was told unitronics could write it out, just to find out that my year(2002) is the only car they cant write the CAT out of. I haven't tried the j pipe but I have tried a extended nonfowler and I still get the code. I even replaced the rear 02. AHHHH its madning. let me know if you find a product that gives you any luuck.
    Senior Member Three Rings eastcoastjettin's Avatar
    Dec 26 2007
    MA
    the J-pipe does not remove the CEL, rather, it fools the O2 sensor so that it does not detect your high flow, or in your case, failing cat. If you want to pass emissions to my knowledge, you need to install this J-pipe or another form of 02 spacer, and then clear the CEL for the cat efficiency code and the J-pipe will keep it from coming back. Hope that clarifies things for you. I ran one for years and it worked fine, but I also had a tune that wrote out the Cat efficicency code.
    [2018 Ibis S6] [1972 Plymouth Duster 340]
    Aug 03 2008
    Philadelphia, PA
    Quote Originally Posted by eastcoastjettin View Post
    gotcha. thanks for clearing that up
    another question though....If i were to install this and unplug my battery (resetting the ECU) would that clear the code with the j pipe preventing it from coming back on as well? or could this only be done with a tune?
    -Kyle
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    Quote Originally Posted by A4OrlandoB6 View Post
    you can clear the code with a vag com or almost any obdII comunication device. will the J pipe keep the code from coming back? maybe
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Dec 26 2007
    MA
    Quote Originally Posted by alpinestar180 View Post
    Correct, this is the easiest and best way to go I would say. OP, yes you can unplug your battery for i think 20 minutes? but you then lose your radio presets etc. Its a lot easier to go to Autozone and have them scan the car/clear the codes. The J pipe keeps the code from coming back. Glad I could clear that up for you.
