Page 1 of 6 123 ... LastLast
Results 1 to 40 of 209
    Veteran Member Three Rings Trile's Avatar
    Jan 26 2010
    Podgorica - Montenegro
    replaced the n80 valve - no CEL, smoother idle, no vibrations when in D etc
    25$ at the dealer.
    Replaced it in about half an hour, would have been quicker if I didn't do it at night using the moonlight to see anything :) the only problem was getting the vacuum hoses of the valve.. First used a hair dryer but it didn't help so I poured some boiling water and then had to use my superpowers to get it off !
    idle is smoother, the clicking noises of the valve are gone. downshifting and coming to a stop is no longer followed by juddering. When in Drive, it also doesn't vibrate as much. And of course, I don't have to pump the pedal to start the car after refueling.
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Did you have a CEL?
    Jan 26 2010
    yeap... the P0441 code. Emission control system:incorect flow, and few other related cels.
    It sometimes poped up and stayed for a day or two and then went away. Last time it wouldnt go off for days, so I stoped being lazy and replaced the valve.
    @mo17k - this is the part, it's positioned on the right from the pcv, you can't miss it :)
    imho, everyone should replace this if they have more than ..hm.. 50k miles on the car. Or even less. It's like the pcv and the cam follower, it WILL go wrong.
    Established Member Three Rings mo17k3y85's Avatar
    Oct 23 2010
    B7 A4, lexus RX330, F150 Roush
    carbondale il
    what is this magical part you speak of?
    06 Quartz Grey B7 - Lowered, 19" RS4 Reps, S-Line front bumper, Color matched Cupra Lip, Smoked reflectors, Spyder R8 led headlights, Hoen yellow fog lights, Led interior, Magnaflow exhaust, In.pro mirror caps, Tinted
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    ^ Whats going on in that picture there? Whats circled? I feel like its upside down for some reason idk. Good to hear everything is running better though!
    RIP QG TI B7 A4
    Jan 26 2010
    the n80 valve (evap valve) is circled :) the picture was taken from above..I know i know, but i was in a hurry
    here is another photo from another member on here,
    Dec 30 2010
    Quote Originally Posted by Trile View Post
    is this 2006 a4? i have a 2006 a4 2.0t i can not find where the n80 is...
    Mar 09 2010
    North E. Jerz
    Ohhh I see, where did you get the valve from? Just hit 52k miles and am thinking about replacing anything that should be replaced, that way it doesn't randomly fail on me
    RIP QG TI B7 A4
    Jan 26 2010
    dealer.
    part number 06E 906 517 A - it's 17 to 20$
    And it's not an 'updated' version like the pcv or DV so the old one will have the same number on it.
    I also replaced anything members on here mentioned... dv, pcv, cam follower. Car felt much quicker after that, and I didn't even know my cam follower was slightly damaged and my pcv was on the way out.
    Mar 09 2010
    North E. Jerz
    Ahh ok, wow thats not to bad at all. I just had my PCV replaced under warranty by the dealer not to long ago, going to get revision D DV soon hopefully, and I need to check my cam follower lol, little scared to though.. Thanks for the part # btw and the info. How long did the install take you?
    RIP QG TI B7 A4
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    I've tried to look the part up on www.genuinevwaudiparts.com it says it's $11.xx but it doesn't say there it's for our car(they have all this other models). It seems like I never find anything on this website. Can somebody give a hand here?
    Aug 18 2009
    A Unicorn
    Portland, OR
    Just replaced mine about a month ago. $15 from the dealer, and only a few minutes to replace. Car runs much smoother now. Had the same code: P0441 - gone.
    Shiro - it's for the 2.0T
    Oct 23 2010
    carbondale il
    so you have a code then replace? or replaced and it threw a code. Not sure what you guys mean by that.
    So it short, code or no code change it if you at or over 50k.
    Aug 18 2009
    A Unicorn
    Portland, OR
    CEL came on. Scanned it and found code P0441. Did some research and decided to replace the N80, which resolved the issue.
    Oct 23 2010
    carbondale il
    ^^ your sir, have some serious knowledge!!
    Veteran Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    Quote Originally Posted by mo17k3y85 View Post
    No offense meant to Tankdeer, but anyone with access to an autozone, 20 dollars, and google could have done this.
    http://tinyurl.com/24eclcu
    It even redirects to a 5 year old thread, here, that says the same thing.
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by Sprode View Post
    Why am I getting called out on this? I didn't start the thread, nor am I confused on the fix. I fixed mine a couple months ago by basically the same procedure you recommend. Scanned it (myself), researched, replaced. I am just trying to help others with the same issue since it's such an easy fix
    Aug 27 2009
    Arlington, VA
    I did not mean to insult you, and it IS good info. Thanks for posting it up. You did what many are incapable of doing.
    Jul 26 2009
    DMV Area
    Yes, but nobody else did it here yet. So I think it's good info
    Jan 26 2010
    @tankdeer - same here.
    love the forums ! :D
    Apr 24 2009
    Moreno Valley, CA
    Did this a month or so ago + my PCV valve.... oh man, car feels like normal now. smooth and plenty of power
    Aug 18 2009
    A Unicorn
    Portland, OR
    Conversely, I have a 2006 and mine is exactly where it is in that pic. Facing the engine, it's back and to the right, under the PCV, slightly forward and more right than the HPFP
    Jul 26 2009
    DMV Area
    can somebody confirm that this is the right part?
    Emission system Egr system Solenoid valve A3
    05-08 $15.50 $11.16
    This is what comes up when I put the part number above on genuineaudiparts.com.
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Anyone with this error, also get a recurring gas cap warning? I'm stuck between replacing the gas cap (seal possibly bad) or replacing the n80 valve.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Aug 18 2009
    A Unicorn
    Portland, OR
    I did not. If you're getting a gas cap error, I would check that first. Although the N80 is cheap so it couldn't hurt to do both.
    Feb 06 2009
    328d, Tacoma
    I'll go with the valve 1st, as it's cheaper. If it's a no fix, at least I know the valve will be good to go for awhile. $17 at my dealer and being set aside.
    Thanks!!!!!
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Senior Member Two Rings socaljoe's Avatar
    Sep 26 2006
    bunch of junk...and spiders
    Southern Kalifornistan
    I replaced mine just last week, problem was the car was a real pain to start every after re-fueling. I had to floor the gas pedal just to start it. After replacing the N80 purge valve, the car easily starts right up after re-fuel, and it's back to being smooth now. The part costed me $18 at the dealer
    Bone Stock
    Veteran Member Three Rings digitalAUDI's Avatar
    Apr 14 2010
    Union, NJ
    Current: 2004 Audi Allroad 6MT, APR Stage 1 (for now)
    Previous: 2006 Audi A4 6MT, Revo Stage 2, 034 Motorsports HFC, B&B Performance Exhaust, Tein S.Tech Springs, RS4 Rear Sway Bar, Upgraded DV, CXRacing Intercooler w/Piping, TSW wheels
    Dec 18 2009
    Pennsylvania
    I just bought this at the dealership today $16. Will replace it possibly today, even though there's nothing wrong with mine.
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I got the part from the dealer today for $18, I have no related codes but from some of the posts above and the price of the part, I couldnt resist.
    OP: how did you take off the oem hose clemps, seem like they cannot be reused. BTW, thanks for the info.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Sep 26 2006
    Quote Originally Posted by airborneriflema View Post
    just buy a new set of clamps(I bought the screw adjustable ones), the crimp type clamps that were one were a pain to remove. I had to use a screw driver to pry it off the hose. Removing the clamps and busted valve took me about 45 minutes (and back ache). The new valve and new clamps were installed within 8 minutes.
    Bone Stock
    Feb 06 2009
    328d, Tacoma
    Quote Originally Posted by digitalAUDI View Post
    If you're close enough to a dealer, I'd just go that route. So far it's been 16, 17, and 18 dollars from the dealer. Most online sites, you'll still have to pay shipping. And you might be able to get it on the spot, as my dealer had one in stock.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Jul 26 2009
    DMV Area
    my problem is that I am 40 miles away from the dealer and I'm pretty busy and never get there by the time they close. They won't ship anything to me. I'll try that link. Thanks
    Junior Member One Ring
    Feb 13 2009
    06 A4 2.0 S-line (gone at 190K), 2011 A6 3.0T, 96 3000GTVR4
    Marblehead MA
    Maybe check the price with your stealership first. Picked one up in Burlington, MA last night... got to the counter and it was $25. AARGH, I hate dealers.
    Jul 18 2007
    Lancaster CA
    Recently had cel stating gas cap was open, then idle was too rich. Also after filling up gas tank the car would be hard to start. Replaced the N80 purge valve, reset the fault code and everything is working great- idle is smooth and very stable.
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by hal View Post
    i love that dealership, i actually trust them there
    May 21 2007
    Florida
    shoulda gone to ira! Chuck is the man. Also Audi of Nashua is damn good as well.
    2018 Navarro Blue Q5
    Feb 27 2013
    United States
    I have an audi a3 2006 2.0l and the enging light is on and its idle high with a loud noise what you think this might be help please!
    Dec 18 2009
    Pennsylvania
    You should be fine using this clamp as a replacement if you fuck up the other ones:
    I'll be installing mine tomorrow.
    Dec 27 2011
    Savannah.GA. US. TO. ON. CAN.
    Post Do not use garden variety hose clamp
    Quote Originally Posted by B72.0T View Post
    This is absolutely the wrong hose clamp to use. Garden variety hose clamps that you can buy at any hardware store do not belong in any vehicle at all.
    Don't use it. This garden hose clamp slots have sharp edges that cut into the hose. The clamp band have sharp edges that cuts into the hose as well.
    Use either OE or OEM hose clamps that don't cut into the hose. The OE or OEM clamps have stamped & rolled teeth with fillet radius corners that dig into the hose. The clamp band edges are angled ~ 15-45 deg. so it doesn't cut into the hose. OE or OEM clamps have self-locking worm-gear screw feature which is very important to prevent the screw from unscrewing itself due to engine vibration
