Page 2 of 6 FirstFirst 1234 ... LastLast
Results 41 to 80 of 209
  1. #41
    Veteran Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    Why am I getting called out on this? I didn't start the thread, nor am I confused on the fix. I fixed mine a couple months ago by basically the same procedure you recommend. Scanned it (myself), researched, replaced. I am just trying to help others with the same issue since it's such an easy fix
    I did not mean to insult you, and it IS good info. Thanks for posting it up. You did what many are incapable of doing.
  2. #42
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by Sprode View Post
    No worries as I wasn't insulted, just confused.
    I bought a scanner a while back because the autozone at my old house stopped doing free scans. Turned out to be one of the best auto tool investments I've made in a while, and it was only like $60 IIRC. Makes researching a CEL so much easier.
  3. #43
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    No difference at all.
  4. #44
    Aug 18 2009
    A Unicorn
    Portland, OR
    ^ lame
  5. #45
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    Also is great of clearing codes... Autozone as a company decided to stop clearing codes, so those cheap scanners work perfectly.
  6. #46
    Aug 18 2009
    A Unicorn
    Portland, OR
    ^ yup. Does that too. A handy little tool for sure.
  7. #47
    Oct 16 2008
    South Florida - Ft Lauderdale
    My N80 was acting up but also one of the line would not longer stayed clipped to the camshaft cover so I replaced it as well
    Here is the DIY I posted a while ago
    http://www.audizine.com/forum/showth...?highlight=n80
    Phil
  8. #48
    Veteran Member Four Rings ataylor's Avatar
    Dec 15 2008
    snowboarding, computer, and mountain-bike parts
    Golden, CO
    off topic,but where did you guys buy your scanners?
    History: MK3 Jetta 2.0 MT; MK3 GTI VR6-SC; B7 A4 6MT STG2; B8 S4 DSG; B8.5 S4 DSG
  9. #49
    Oct 16 2008
    Quote Originally Posted by ataylor View Post
    Ross Tech
    phil
  10. #50
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I just installed the N80 at work and drove home. It took me 15mins for the whole install, hardest part was taking off the old clamps.
    Thus far, the only result I can verify is better fuel mileage (1L/100km less than before), which is more than enough to justify $18 and 15mins of my lunch break.
    Thanks OP, you just helped me keep my money in my pocket!
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
  11. #51
    Aug 18 2009
    A Unicorn
    Portland, OR
    I just have a cheapo one from Autozone. Works perfectly fine
  12. #52
    Jul 18 2007
    Lancaster CA
    Recently had cel stating gas cap was open, then idle was too rich. Also after filling up gas tank the car would be hard to start. Replaced the N80 purge valve, reset the fault code and everything is working great- idle is smooth and very stable.
  13. #53
    Senior Member Two Rings 2007B7cabrio's Avatar
    Apr 05 2010
    2008 MB R-320 4-Matic, Toyota Prius
    Weston, FL, USA
    ^+1, RossTech, more than just a scanner...
  14. #54
    Jul 18 2007
    Lancaster CA
    Hey tankdeer which model scanner did you get from autozone and how much can the scanner do? Just read and clear codes?
  15. #55
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by AudiCVT View Post
    I don't remember the model off the top of my head, but it's orange. And yeah, it's a base model. read and clear is about all it does - but that's all I wanted it for.
  16. #56
    Oct 11 2010
    Long Island/NY
    This is what I have... I got it before I got my Audi. Works well with all 96+ ODBII vehicles:
    Click the picture for a link
  17. #57
    Aug 18 2009
    A Unicorn
    Portland, OR
    Pretty similar to mine.
  18. #58
    Established Member Two Rings BladesBravo's Avatar
    Aug 25 2009
    Quote Originally Posted by B72.0T View Post
    How many miles are on your car?
    Coming up on 57k and if this would get rid, or slow down, the "old age steering wheel shake" i'm in.
  19. #59
    Dec 18 2009
    Pennsylvania
    Right now I'm at 51K.
  20. #60
    Jul 18 2007
    Lancaster CA
    Quote Originally Posted by JPT View Post
    I'm glad you were able to find a cheapo scanner that works. I first brought one of those orange scanners that said ODBII compatible but it didn't work. Returned it and ended up getting the good grade flea bay cable from the same supplier. Cost me about $90 but it worked great and got some more insight into the car. Not as good as Ross tech but it works.
  21. #61
    Veteran Member Four Rings Dangler's Avatar
    PA
    Part #25
    F.T.W.L.T.B.D.W.I.C.T.W
  22. #62
    Senior Member Two Rings joeygriebel's Avatar
    Jun 14 2010
    Broomfield, CO
    has anybody else had success with replacing the n80 valve and smoothing the idle out?
    07 Quartz Grey 2.0T Avant - Revo Stage 1
  23. #63
    Aug 25 2009
    Quote Originally Posted by joeygriebel View Post
    For being this inexpensive ill do it this, or next, weekend (pending dealer stock) and report back
  24. #64
    Jan 30 2011
    Sigourney, Iowa
    Autozone?
    I called autozone and they could not cross reference this part? 06E906517A - I guess I will have to order it in from ecs or primepartssuperstore...
    Does anyone know what the equivalent would be?
  25. #65
    Senior Member Three Rings deeznuts's Avatar
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    i have the juttering problem occassionally when coming to a stop, but only after heavy spirited driving...just called town audi in englewood- its $16..going to pick it up today and install it just as a safe guard
    Koni ss, creative test pipe/downpipe, britalman exhaust, greddy fmic, rs4 sways, apr stg II, a lot of adrenaline
  26. #66
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    im experiencing the jittering too when coming to a stop but only after i do heavily spirited driving...no CEL, but town audi in englewood has these for $16 so gonna change mine today just for the fuck of it
  27. #67
    Aug 25 2009
    x2, the small vibrations are still there after startup when car is put in drive. It may be me but before I could heard other parts inside the cabin shaking when I first got into gear and now I think they have stopped. But for $20.04 its worth being able to say that I replaced the "Tankentlueftungsventill".
  28. #68
    Veteran Member Four Rings Inked's Avatar
    Dec 11 2010
    Polaris Outlaw 525 Quad
    Central FL
    Replaced mine today along with latest revision PCV and noticed a difference right away! Engine runs alot smoother and a big difference is noticed in acceleration, the 1st to 3rd gear shifts are ALOT smoother. Very good results!!!
  29. #69
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 15 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Would this be a good bang for your buck "fix" if you arent getting a CEL, but notice the tranny shifts rough at low rpms sometimes?
  30. #70
    Dec 18 2009
    Pennsylvania
    Quote Originally Posted by magillkirk View Post
    Dude autozone isn't going to have something like that?
  31. #71
    May 20 2008
    2013 Passat TDI
    Do a PCV failure test.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
  32. #72
    Jun 14 2010
    Broomfield, CO
    Quote Originally Posted by Inked View Post
    Thanks for the feedback! I think I am going to give it a try as well as replace the pcv valve
  33. #73
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Quote Originally Posted by NorcalPB View Post
    At under $20 can't hurt to try. And mine was instock so you shouldn't have to wait.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
  34. #74
    Senior Member Two Rings babybepeezy's Avatar
    Aug 12 2009
    California
    Is there a DIY for this?
  35. #75
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    question for anyone. on the stock part what way does the arrow on it face? does it face towards the front of car or towards the firewall? kinda wondering since my stock one was throwing away and i have a replacement but its the esctuning one. let me know thanks
  36. #76
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    ^^The placement is pretty much stationary, you place the device in to its seating and connect the tubes. There is no other way you can do wrong with this.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
  37. #77
    Senior Member Three Rings DrZEUS's Avatar
    Aug 18 2011
    B8.5 S4
    Mississauga
  38. #78
    Aug 05 2011
    CO
    well the one I had ordered has the sensor on the grille side and the arrow is on the firewall side pointing towards grille. I may be mistaken and have to look again
  39. #79
    Oct 09 2007
    Miele S7
    Quote Originally Posted by DrZEUS View Post
    That's the one.
  40. #80
    Jul 03 2011
    IL
    What am I missing? Trying to replace mine...these hoses will not budge at all. Am I just being too weak or is there some trick?
