Results 1 to 12 of 12
    Stage 2 Banner Advertiser Four Rings Tech/Sales@JHM's Avatar
    Jun 04 2008
    The Fastest Audis
    California
    JH Motorsports 4:1 center diff install – HOW TO – for 02X 6-speed M/T
    hey a'ziners - we just performed our 4:1 center differential upgrade on our newest employee's 2004 B6 1.8t quattro 6 speed avant. check out this write-up to see how you can remove and re-install your diff to get this awesome upgrade!!!
    **note: this write up is for the 2004 and up 6-speeds only (02x transmissions) only, however the concepts are 80 to 90% the same for all Audi Manual Transmission cars with quattro. The main difference is that V6 or V8 cars need to have the exhaust partially removed to gain access and the diffs look different. Also the 5-speed B5-B6 A4s are very similar except that the center diff comes out with the rear housing and is stuck inside the housing, requiring removal of a hidden snap ring. If needed, you can send us your whole 5-speed tail housing in with the diff still in it and we will gladly take it out, modify it, and put it back in. Additionally, the 02 and 03 6-speeds in the 3.0l cars are 01E transmissions and have the same bolt sizes as the ones depicted in this write up. In order to remove the diff you just need to unbolt the exhaust to get it out of the way. The tail housing is shorter on these transmissions and includes a cap and a spring that is in the cap along with some shims that must not get lost.**
    alright. let's begin!
    that should be everything! we stock all of the driveshaft bolts and gaskets featured in this write up as well as the above mentioned redline mt-90 transmission oil.
    let us know if you have any questions. you can email us at [email protected]. enjoy those twisties!
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    Nice. Killer price on the website also. Might end up sending mine in for that good a price. How much will this affect the car at the drag strip? I don't drag regularly, but it does get dragged, and I don't want to hurt times at the track...
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by MMMB00ST_A4 View Post
    It is best for twisties but with super stiff suspension at the drag strip the stock diff is best. If your suspension is stock or you adjust it soft enough to get some squat to the rear tires then the 4:1 diff is best. We have cut a 1.67 60ft with our B6 S4 with stock suspension and this diff.
    Thanks.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Jun 04 2008
    The Fastest Audis
    California
    Quote Originally Posted by jaybquick@JHM View Post
    Thanks.
    yea, what the boss said.
    also, i wanted to let you b6 guys know that this differential upgrade is on sale right now along with a lot of our other products. check out this thread for more details on the discounts!
    happy wrenching!
    Mar 31 2009
    NC
    Thanks.
    So with KW V2s on moderate stiffness I should stick with the stock diff. Darn, wanted an excuse to mod something new on the car ='( lol
    -Brandon
    12.9@104mph
    Mar 27 2005
    The Cold North
    The rear spring on the KW's is soft in comparison to other options. I don't see that you will have any issues with the 4:1 diff at the track.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Mar 31 2009
    NC
    Quote Originally Posted by EBG 18T View Post
    Thanks for the response E. So looks like I may send it to JHM anyway. Seems like an awesome price...
    -Brandon
    12.9@104mph
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Is there a warranty associated with this product? I don't see anything listed on the 'site.
    -Doug
    Jun 04 2008
    The Fastest Audis
    California
    mmmboost, definitely send us your money!!! . you really can't beat the price that this upgrade is going for right now with the sale. even when it's not on sale, we are still selling this upgrade for much lower than what other companies do it for.
    dougy, jhm stands behind all of the products we sell. we haven't had any issues with these upgrades so far. we carefully inspect each of the differentials that we receive before we modify them. if we don't think the differential is in good enough shape, we won't modify it.
    since we are simply modifying the differential and not sourcing a new product we cannot provide a full warranty on this modification. like i said though, we stand behind our product and care for our customers so we'll do whatever it takes to help solve an issue *should* one come up.
    feel free to contact us with any further questions you may have! [email protected].
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Would this install procedure be the same for the 01X tranny?
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by komseh View Post
    The 01X is the front wheel drive version. The 02X is the AWD version. Same transmission. Some however use 01X to designate either.
    So yes if you have an 04 and up 6-speed A4 it is the same.
    Thanks.
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    What's the difference in the Torsen diff on the 02X and 01A, are they both T-2 diffs?
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
