Originally Posted by
Jason:addict
I admit after noting how far off ECUx is compared to VBox I'm not real excited about letting log files in... If we can't count on accuracy than the data is useless. I also thought the asterisk was for GPS verified runs only.
Were the Pbox times faster or slower (or varying) compared to ECUx times?
When plotting Vagcom generated acceleration curves (based on delta rpm/sec), I find that the data are OK up to approx 5000rpm, but start fluctuating after that, probably due to the decreased sample rate at high rpm, so I agree that only Pbox/Vbox times should be used for the official list.
I use an accelerometer based datalogger (made by the guys that make the Mustang dynos). It spits out power/torque numbers similar to a correctly calibrated Mustang dyno, and the time to speed is dead on accurate (spot on with track timing, magazine tests, etc), but since my times are not Pbox/Vbox based, they should not be added to the list. I will just mention times that I measure in posts, for you guys to use as a reference.
