Well yesterday I woke up and my headlights didn't work. After some searching of the forums and speaking with a couple different people I resolved the problem by replacing my headlight switches. But once I put all the wiring back on, plugged my airbag back in, started the car and boom. Check engine light popped on. The car idles totally fine, the only problem while running is when I come to a stop, or begin to stop. The RPMs drop to like ~500 and unless I give it some gas, the car will otherwise die. Not even a month ago I had a code coming up as TB failure. But I reset the TB and cleaned it out which resolved the problem and the car ran fine. During that time, when the TB wasn't fixed, the car would idle extremely low in RPMs and die when I come to a stop as it does now. Also I noticed that there was a clamped on the hose connection to my TB that wasn't tightened, it was so loose I could turn it with my hand. When I looked into the TB this time, there was a lot of gasoline on the valve and on the gasket. Could all this be connected in some way? Maybe not, I'm not sure. I also cleaned out my MAF Sensor and replaced my air filter along with my fuel filter today. Cleaned out my air box as well. But I got the codes pulled and I got this:
P0134
Definition: Heated oxygen sensor - bank 1 sensor 1 (H0sS11) sensor circuit no activity detected
Explanation: Air/Fuel ratio concern- lean or rich
Probable cause:
- Open or short circuit concern.
- Faulty H02S11 (Bank 1 Sensor 1)
P1198
Definition: 02S heater circuit bank 1 sensor 2 electrical malfunction.
Explanation: Open or short circuit condition
Probable cause:
- Poor electrical connection
- Failed H02S (Heated oxygen sensor)
P1196
Definition: H02D21 Slow response (Heated oxygen sensor - Bank 2 Sensor 1)
Explanation: Oxygen Sensor has a slow reponse during testing period.
Probably cause:
- Defective oxygen sensor
- Very lean air fuel ratio
- Very rich air fuel ratio
P0102
Definition: Mass or volume Air flow sensor circuit low input.
Explanation: Air duct tube damaged
Probable cause:
- Large vacuum leak on engine
- Faulty MASS sensor
P1472
Definition: EVAP control system LDP circuit short to ground.
Probable cause:
- Failed Leak Detection Pump (LDP)
P1425
Definition: Tank Ventilation valve short to ground.
Explanation: Open or short circuit condition.
Probable cause:
- Failed EVAP canister purge regulator valve
I'm really trying to avoid taking it to the auto shop, really my last resort, money is really tight at the moment. So I'm really hoping I can get some input on these problems while I continue to research and browse forums.
My knowledge of cars is pretty limited, everything I know is mostly from these forums and doing a lot of searching so I'm trying to find a sense of direction as to where all these problems might be coming from. Could all these electrical problems be related to me pulling my airbag off and all those electrical connectors?
Thank you to anyone who doesn't go TLDR lol...Really appreciate any help guys, thanks a lot.
