    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    What is the engine code on this 2002?
    Seller gave me the following info:
    WAULT64B22N136247-vin#
    2ADXV03.0344 engine family code
    Can I determine the engine code from this info?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    You sure it's an A4? This is what the Bentley VIN decoder gave me:
    VIN: WAULT64B22N136247
    1 Country of origin W Germany
    2 Manufacturer A Audi
    3 Vehicle Type U Passenger Car
    4 Series L A6 4dr quattro
    5 Engine T 3.0L V6
    6 Restraint System 6 Dr/Pass A/B, Dr/Pass Active, Dr/Pass Side A/B Front, Dr/Pass Side Guard Air Curtain
    7 Model (position 7 & 8) 4 A6
    8 B
    9 Check Digit 2
    10 Model Year 2 2002
    11 Assembly Plant N Neckarsulm
    12 Serial Number (position 12 - 17) 1
    13 3
    14 6
    15 2
    16 4
    17 7
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    May 21 2007
    Florida
    edit- nevermind.
    2018 Navarro Blue Q5
    Feb 20 2010
    Brighton, MI
    kwimberly, you are absolutely right. Its a 2002 A6. I had intended to click down to the A6 forum.
    Is the engine code the AVK?
    05 Golf TDI
    Aug 26 2005
    Yes, AVK 3.0l aluminum V6 30 valve. Same engine as used in the A4 B6.
    Vorsprung durch Technik
