Results 1 to 9 of 9
    Senior Member Three Rings Ethar's Avatar
    Sep 10 2009
    A4 2004 USP-A 2003
    Michigan
    Rear Flange change 1.8t b6
    Getting ready to start working on the rear flange. before I begin. Any helpful tips or tricks that you can share that will make this job less pain in the ass. thanks in advance
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I would do the vacuum simplification as it would've made changing the flange a lot easier at the time.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    i hope you have a dremel, the springs clamps on the flange are an absolute bitch to remove, had to cut them off...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    May 21 2007
    Florida
    drain the coolant, take your time. dont rush. and have small hands.
    2018 Navarro Blue Q5
    Veteran Member Three Rings JustinCase's Avatar
    May 25 2007
    2013 A4, 2011 A4 Avant
    Scranton, Pa
    Yeah with the vacuum lines simplified and the Combivalve removed its really easy to get to. Like a 20 minute job.
    -Justin
    2013 A4 Sedan
    2011 A4 Avant
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    If I didn't have the engine out I wouldn't want to do it. Just pray your hands are small and able to bend at weird angles. I heard a little mirror helps you find the things you need to see. 90% of the hard work you will not be able to see.
    Sep 10 2009
    A4 2004 USP-A 2003
    Michigan
    Quote Originally Posted by JustinCase View Post
    How do i simplify the vacuum lines. I am in the process of trying to get this bitch out. how did you guys take it out?
    May 25 2007
    Scranton, Pa
    Has it been changed before? Mine had all stupid one time clamps instead of hose clamps. Yeah take off that breather on the back of the valve cover and you should be able to see it much better. Remember the one bolt has 2 nuts on it because one holds the oil feed line in place.
    -Justin
    2013 A4 Sedan
    2011 A4 Avant
    Sep 10 2009
    A4 2004 USP-A 2003
    Michigan
    first time, I remove all the clamps on the hose the hard part is trying to get this 3 way hose out bottom. its pretty hard in there and I don't want to brake anything. was shaking the car trying to pull it out its in there pretty tight.
