As the title states, yes I am having a misfire. Yes, I have done my research as far as searching and finding out what the usual causes are. I have checked for boost leaks, I have swapped coil packs, I have changed spark plugs, I have checked my o2 sensors, I have checked my EGT sensors. The problem is that I am consistently getting a misfire on cylinder 6 only under load. If I ease into the throttle I can drive it find and it doesn't seem to misfire unless I am on it for awhile. My next step will be to swap the fuel injectors to see if that is causing the misfire. I'm curious as to what else may be causing this? I don't think it would be the ICM because it is staying on one cylinder. Any and all help with this would be greatly appreciated. Thanks!
