Results 1 to 7 of 7
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    anyone-ever-considered-a-variable vane holset ?
    I wanted to see what some of the guys on the B6 forums thought, so sather than double posting, I thought I'd put in a link to the B5 forum thread http://www.audizine.com/forum/showth...le-vane-holset any comments should be left there so as not to cross the streams ;)
    Saint Cloud, Fl
    There is B5 guy running one of those on his car. They sound crazy when the spool. check out the 55sec mark
    instagram ------------> low_enforcement
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Man that is a brutal dyno session dammn I would get sooo addicted to that spool I would have to drive with my window cracked all the time hahaaa.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Mar 27 2010
    solar system
    Yeah, I dug some more and I guess a few 1.8T guys have run one. By the looks of it, you'd have to run a mechanical stop to keep the slide section from retracting all the way to the 4cm2 spot. I guess that range was used for engine braking and would create an enormous amount of backpressure.
    I figure an EBC on a wastegate actuator for the VGT mechanism and an external wastegate to cap the peak boost would make a decent setup. Even better would be a staged EBC like the turbosmart ones. For the price, this looks like it could be an interesting proposition.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    wow, really?
    -Doug
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    Get out of the B6 forum and explore
    http://www.audizine.com/forum/showth...1-95.5mm-build)
    4Runner, Rs5 and Alfa Guilia QV
    Mar 27 2010
    solar system
    Thanks for the link, it looks like a promising idea. I`d be curious to see how it works on a 1.8l displacement (i.e. if you could get the same boost profile as his 2.1l by tweaking the VGT actuation). For the downtime it would take to get it running right I think I`d be best to use a HY35 for round one (engine build and maestro tuning) then swap in a limited slip diff (I`m FWD) and VGT turbo for round two.
    Still, if he can prove that you can get one running right, I think this turbo has some major potential for a small displacement engine.
