Results 1 to 15 of 15
    Veteran Member Three Rings blackjak's Avatar
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Clarification on Dentist Drill Whine
    I searched quite a bit, but I am just curious is the dentist drill noise usually only apparent when your actually boosting and not still in vacuum because all turbos whistle so I just don't want to confuse the whistle/whine with the dentist drill noise. I am at 127k miles on OEM turbos and I want to chip but am hesitant the turbos sound healthy but who knows........
    Jun 15 2010
    San Antonio, TX
    I had actually been concerned about that as well... I occasionally got paranoid as well. Looked it up on youtube and it seems to be a bit more obvious than I expected. Kind of hard to hear on speakers, but with headphones or if you listen carefully, it's pretty obvious:
    http://www.youtube.com/watch?v=iKnI3DS8ino
    Sep 11 2009
    NE
    I chipped at 140k with healthy turbos and they died after 100 miles chipped... to each their own.
    Veteran Member Three Rings ThePeoplesChamp's Avatar
    Apr 28 2009
    New Brunswick, NJ
    Dentist drill is really apparent. You'll know if you have it
    2001 Audi S4
    2004 IS300
    1997 Chevy Corvette
    Sep 11 2009
    NE
    yes it is, imagine dentist drill sound but 10x louder and clearly audible when driving 80mph with windows/sunroof closed.
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Quote Originally Posted by julex View Post
    Hahahha that post alone is enough for this guy
    Jun 15 2010
    San Antonio, TX
    Quote Originally Posted by blackjak View Post
    Ignore that guy. If his turbos were perfectly fine, then they wouldn't have failed in 100 miles. The harder anything is run, the quicker it will fail (in most cases at least). If everything seems fine, I'd say have a little fun. The turbos are going to eventually need work/replacements no matter what.
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Do turbos often blow without any warning or usually get dentist with it
    Established Member Two Rings 28cmod's Avatar
    Apr 08 2010
    Louisville, KY
    Quote Originally Posted by CC Lemon View Post
    My KO4s sound like this, has sense they went in about 6 months back. I bought a set of used "under 10K mile" KO4s and I was a little worried about them, thinking I had been ripped off but got flamed for bringing it up. I suppose my fears were correct then...
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    Quote Originally Posted by 28cmod View Post
    Meh....I've had turbos sound like that for 10's of thousands of mines. Are your's going to blow? Who knows. But you cant worry about it....just drive it like you normally would.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Apr 08 2010
    Louisville, KY
    Kinda my take on it. I daily it, don't hammer all the time. Like anything with these cars, who knows when it'll go...
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    So really never had my question answered I watched the videos, but I do hear a whine/dentist drill in vacuum but as soon as I hit boost It goes away. So I am thinking that they are getting tired???
    Veteran Member Three Rings <CHILIBISKITS4>'s Avatar
    Nov 28 2009
    Lakeland Hills, WA
    you wouldnt hear it in vacuum mang
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Normal.
