Results 1 to 29 of 29
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Question Size difference between Rear Sway Bar between Sport and Non-Sport Suspension?
    I was searching around but couldn't find any info on this... does anyone know if the rear sway bar is different between the sport and non-sport A4's? I know the front ones are but I cannot find any details on the rear ones.
    Any input would be greatly appreciated.
    Aug 07 2008
    Tacoma, WA
    The A4 wiki above is very informative, although it is not entirely clear between sport and non sport of later years.
    Apr 10 2007
    Eastern PA
    Yeah, I was trying to find something concrete but came up with nothing.
    Here's the wiki page (checked there too) for future searches: http://www.audizine.com/wiki/index.p..._A4#Suspension
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    I'm not sure about stock.
    But sport swaybars are the same as S4 units.
    00 A4 1.8TQ MT (AJL)
    12 1M
    18*8 RPF1 | Vogtland GT 575F/675R | H-Sport Sways | 320mm B8 Brakes, 300mm S4 rear |
    GT2871R Elim | QMS tuned AJL 627cc EV14 @ 4.3bar | 034 3" DP (8psi backpressure!) | Milltek | JHM SSK
    3090lbs
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by gmx View Post
    Good to know... thanks!
    Anyone else know some details about the stock non-sport versus sport rear sway bar?
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Stock rear 12.5 mm
    Stock sport/S4 rear 15 mm
    I am currently sanding to repaint S4 Swaybars, I'll let you know if theres a difference... because on paper it's only 10%
    Apr 10 2007
    Eastern PA
    Awesome thanks very much for the info!
    Aug 13 2008
    Indiana
    I wouldn't waste my money on the sport rear. Neuspeed rear/ sport front. Not too harsh but gives the car balance accompanied with some good shocks/springs or coilovers.
    However since I want to upgrade anyone can buy my sport rear sway.
    -Nic
    Mar 07 2010
    Sherbrooke, Qc
    Quote Originally Posted by somebody5788 View Post
    Any difference between STD vs Sport? Less understeerrrrr?
    Apr 10 2007
    Eastern PA
    Neuspeed is the next step. I just got a set of sport sways for free so I figured it would be a good upgrade until I find a deal on a neuspeed or hotchkis setup.
    Mar 07 2010
    Sherbrooke, Qc
    Off topic : I upgraded my summer tires from Michelin Hydroedge to Bridgestone Poleposition S-03, and the typical understeer is gone! The tires dont give up no mater what, Insane! Received H&R sport spring... long winter ahead, kick ass car next summer! Add to this, Sport swaybar... understeer will be as eliminated as possible!
    Mar 01 2008
    '12 1M
    Sydney, AU
    Quote Originally Posted by FNK View Post
    What do they do at the limit?
    What pressures are you running?
    12 1M
    3090lbs
    Mar 07 2010
    Sherbrooke, Qc
    Quote Originally Posted by biketsai View Post
    IIRC it was 15mm non and 17mm for the sport.
    Nope, just measued the S4 swaybar, 15mm +0 -0.2mm
    I remember measuring the A4 non-sport and it was quite small, 12mm in fact. maybe smaller, the tolerance seems to be quite high on this part.
    Aug 13 2008
    Indiana
    I have always had a sport one so I wouldnt know. However it's just not good enough.
    -Nic
    Mar 07 2010
    Sherbrooke, Qc
    Ok thanks
    Apr 10 2007
    Eastern PA
    Non-sport sways are not helping understeer. I have those on my car currently. Hopefully the sport ones will yield some help with that.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Gotcha, glad you were able to clear that up.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    What is the best size rear bar on a 2.8 with a stock non sport front bar? I was thinking 19mm for rear and the 22mm for rear if running sport front bar?
    I'm going for less understeer and more stiffness in chassis but don't want oversteer
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by Kronic Budz View Post
    They put them as a set for a reason. If you don't use a matched set then you can run into a problem of either too much oversteer or understeer depending on which one you leave stock and which one you upgrade.
    Also what do you mean by, "19mm for rear and the 22mm for rear"... there is only one sway bar in the rear.
    Oct 01 2007
    1997 A4 2.8 QM
    Quote Originally Posted by GetBoosted84 View Post
    I mean that if I were to leave my stock non sport front bar in, that I would get a 19mm nothing bigger to not let the rear bar be dominate over the front bar and produce oversteer. BUT, if I could find a s4/a4 front sport bar I could go with a 21-22 mm rear bar and be somewhat balanced out because from what I hear the sport/s4 front bar is pretty firm compared to non sport front bar.
    I don't want to get the kit really because 35mm front bar is just overkill for a dd. A 29mm stock bar is already quite large, the rear bars are just pinner...
    Mar 07 2010
    Sherbrooke, Qc
    Some report REAR bar over 19mm have a tendency to crack the subframe. RS4 use 19mm
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    Who loves their 19mm neuspeed rear sway?
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Oct 01 2007
    1997 A4 2.8 QM
    That's why it's recommended to get the subframe reinforcement brackets so that doesn't happen.
    Mar 07 2010
    Sherbrooke, Qc
    Rear S4 sway bar, with Adjustable Sway Bar End Links to shorten the leverage, thus increasing in the stiffness
    http://www.audizine.com/forum/showth...hipped-Special
    Oct 28 2009
    state college pa
    the s4 sway bar makes a big difference in the back. The front doesnt do much. I love mine.
    Oct 01 2007
    1997 A4 2.8 QM
    Since a sport/s4 rear bar is 20% larger in diameter. 15mm vs 12.5mm.
    Does that mean the sport bar is at least 30-40% stiffer?
    ^^^ this guy is saying it made a big difference
    Mar 07 2010
    Sherbrooke, Qc
    Shear stress,
    I don't have the Inertia formula here, but a partial equation give me 20% stiffer swaybar on the S4
    Sep 17 2005
    Fremont, California
    I wouldn't bother upgrading to the S4/Sport bar if you don't already have it. Just man up and grab a Neuspeed rear or an H-Sport rear (and stay away from the fronts), along with some upgraded end links. Drastic handling difference, far less understeer, and the swaybar end links will sharpen up response time even more.
    I run the H-sport 22mm, in the neutral position (closer to the front of the sway bar) on my S4. Much of this depends on your driving style and suspension setup, but we run the stock front swaybar on our A4 Time Attack race car (one of the fastest B5's in the world) just to give you an idea. A front bar might help you at 120mph, but honestly, who goes that fast very often? The rear bar will help your sweet spot, from low to medium-high speeds.
    Apr 10 2007
    Eastern PA
    What will probably make more of a difference in terms of cornering speeds would be changing over to a 4:1 center diff IMO. I have a Stassis unit that I'm thinking about selling if you are interested.
