Results 1 to 16 of 16
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    Shifter problem. Video!
    Hi all,
    97 a4 1.8tq
    So when I'm in 1rst gear I can make it look like I'm in 1 or 3. if Im in 3rd i can make it look like I'm in 1rst or 5th. 2nd looks like 4 and vice versa (that is how loose the shifter is). However, when I try to go into reverse I think that its in gear but maybe not all the way because it just sorta grinds. it doesn't pop out, it just grinds. I think that the bushing are just so shot it cant find reverse? here is the video turn the speakers up to hear it.
    http://www.youtube.com/user/seanj130.../0/3LWqLFM16jY
    Thanks in advance,
    Sean.
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Veteran Member Three Rings wildbill's Avatar
    Jan 25 2010
    work
    sounds like possibly a linkage adj....have you looked?
    boost. a new band aid by Johnston&johnston
    Sep 05 2008
    Pittsford, NY
    dont even know where to begin looking, i will try and look tomorrow when there is more light out as I dont need a car tonight (no drinky and drivey for me) but what exactly am i looking for?
    Best regards,
    Sean.
    Jan 25 2010
    work
    theres linkages to the bell housing area. start there, it seems like somethings off, did you launch/slam into gear before it happened?
    Sep 05 2008
    Pittsford, NY
    yepp.. been slamming into reverse for awhile now.. dont launch much.. every once in a blue moon,(not in the past month or so)
    Best regards,
    Sean.
    Jan 25 2010
    work
    could have done it. once youre in a gear is it ok?
    Sep 05 2008
    Pittsford, NY
    dont know, cant get it into gear. but yea it was ok when it was in
    Best regards,
    Sean.
    Jan 25 2010
    work
    is it grinding into all gears?
    Sep 05 2008
    Pittsford, NY
    ^^ no just reverse.
    Best regards,
    Sean.
    Jan 25 2010
    work
    but is it tough into all gears? if its just reverse it could still be linkage issue, but that grinding is your synchro = trans rebuild is inevitable if you ever want to back up again. so first check the top of the housing for the linkages and post up your results
    Sep 05 2008
    Pittsford, NY
    Sometimes it misses first and i can only get into 3rd. when it does that i can get into reverse however i cant get into first. a tranny with 35k on it just went into the car. think the bolt on the tranny housing backed off and shit became loose (remember it did not gradually get like this, it just started at once)
    Best regards,
    Sean.
    Jan 25 2010
    work
    possible, wailing into gear will do it. also your synchros are turning to coffee beans, thats the grind
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    i would start with adjusting the shifter inside the car. it isnt fully engaging the gears. there are 2 rods right in front of the shifter which deal with the shifter placement and throw of the gears, loosen the allen bolts and move it around. im about 80% sure thats your problem.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Sep 05 2008
    Pittsford, NY
    ^^ thank you. just dont wanna spend another grand on a tranny build.
    Best regards,
    Sean.
    Jan 25 2010
    work
    not yet....fix it b4 its too late....like lymphoma!!! deffg sounds linkage related, also looks like a f^%&*D up linkage
    Sep 05 2008
    Pittsford, NY
    So i have an update. i loosened the the plastic surrounding my whole shifter assembly. and i was able to find reverse and got it working with no problems. with everything tightened down i cant get to reverse. the shifter just woke make it over that far!. So it works, just needs some adjusting it looks like.
    Best regards,
    Sean.
