Results 1 to 16 of 16
    Veteran Member Three Rings Oceanside's Avatar
    Dec 12 2008
    2001 A4
    St Pete FL
    What WHP does the S4 fuel pump max out at cause ..
    Im going to get a stock S4 fuel pump / basket and throw it in my 1.8BAT cause I want to run 30psi. . . 400whp , Will it support that?
    AWM BAT A4 / AGP D42 .48 / Tapp 630 / IE Rods / LwFw+ S4 SB / APR Stealth / Garrett-Precision 450 / 2001 FWD Highway Menace
    Senior Member Three Rings fazda's Avatar
    Apr 30 2009
    2000 Audi s4
    Edmonton AB, Canada
    i highly doubt a stock s4 fuel pump will support 400whp, its a decent size for stock, but thats twice the flow rate, i would definetly be upgrading.
    2000- Audi S4, Piggie pipes, SSAC catback, Evoms Intake, Stg2+ Vast tune, 710n's, Eibach sportline springs
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by fazda View Post
    I ran a stock s4 fuel pump on 420awhp (aggressive 91+meth tune, 25psi) for almost 2 years with no problems. But if you're going through the hassle, might as well throw a walboro or 044 in there.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Sep 11 2009
    NE
    Stock maxes out at around 400whp at 4 bar FPR, it can push more HPs at 3bar. If you're gonna be running 3bar fpr you should be good to go...
    Senior Member Three Rings ^@ViVid's Avatar
    Sep 03 2010
    2000 S4, 2004 SHD RL, 2003 MDX, 1st Gen RX-7 700whp
    San Diego
    Quote Originally Posted by Rated S View Post
    Just curious this was on a K04 setup right?
    Feb 04 2010
    Bush
    The factory did not think it even supported 380 crank sustained but what do they know, if they only would join forums to learn from the experts.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Why bother when you can get a Walbro for $80 and it will support more.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Why stop at 400whp, get 2 044's and shoot for 800hp.
    l gotta-- l gotta get
    a form from a scientist.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by ^@ViVid View Post
    Yes.
    Established Member Two Rings jettin123's Avatar
    Feb 03 2009
    Richmond, VA
    JHM is still on the OEM fuel pump setup with their LOW 11 second nogaro blue S4.
    Dec 12 2008
    2001 A4
    St Pete FL
    Will my 1.8bat has 4 630cc seimans run from a tapp file, not sure about the bar cause it came with an adjustable euro spec one with the tune pre set. The stock a4 pump maxes out around 22-23 psi and I just want to crank up the boost to around 30 safely. Thanks for the responses guys. and why throw the s4 pump in my a4 instead of an after market one?? cheap. . . free :)
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Quote Originally Posted by Oceanside View Post
    You should have Fuel Pressure gauge somewhere than. Check and see what the base fuel pressure is.......
    Sep 11 2009
    NE
    you'll be fine with 630ccs. I run stock S4 pump on 6x630cc and 23psi or something to that respect without a sign of faltering... but you will be running at the very limit of it though.
    Just get walbro from Vast. They can even sell you ready-to-go pump with it installed in your application specific basket.
    Dec 12 2008
    2001 A4
    St Pete FL
    one again though, I got this S4 pump for Free and it takes like 10 mins to swap them, Im going to install it and turn it up to 26-27 and when I get a fuel pressure gauge try my luck at 32psi
    Veteran Member Three Rings americanthunder's Avatar
    Feb 18 2009
    New Hampshire
    I made 446 on epl's mustang with my bone stock fuel pump. 6 months later still running like a champ. I do plan on switching to a 044 drop in when I get it retuned though. 400whp shouldn't be an issue
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    its not whether or not it can support it, its more of sustaining. an average nfl running back career is 5 years long. after that, they break down, cannot perform properly. of course, there are some exceptions. so your stock S4 pump will put out just fine, as to whether it will last for 6 months or 6 years at that level, no one can know..
    RS6 hybrids and corn
