All,
I realize it's difficult to diagnose over the internet and unfortunately I'm not 100% familiar with the car and all of its quirks yet, so I hope to do the best I can.
Background:
The car has been sitting for about 4 months for cosmetic reasons (aka roommate driving through the garage door and into the back of it). I let it run once or twice a week. Once a month drive it down the street and back. Car has ~89,000 miles on it, 2001.5 S4.
Situation and Symptoms:
Was messing around in the garage so started the car up and let it run for 15-20 minutes. Decide to drive it down the street. Coming back onto my street, car gives out a little pop and dies. I roll up to the edge of my driveway which is a slight incline.
Car will start 2 out of 3 attempts or so each time. I need to give it gas upon starting. Initially I can hold the revs around 1500-2000 rpm. Then after 15 seconds or so the rev's will drop to ~400 with me lightly pressing on the accelerator. If I let off the pedal, the car will die.
If I attempt to move the car under its own power it dies. It smokes white out of the exhaust and smells like fuel/oil mix. It did not do this prior to this happening.
What potential causes do you all think it could be?
1) ICM?
2) Catastrophic turbo failure? It is still on original k03s and is stage 2.
3) Timing belt failure? Car has been sitting for a while.
I appreciate all the help you guys can give. Thanks.
