Results 1 to 40 of 52
Thread: Exhaust?
    Active Member One Ring FrankM16's Avatar
    Oct 26 2010
    rs4, mercedes-benz clk550, bmw e46 m3(modded)
    Miami
    Exhaust?
    does anybody know of a good exhaust for my 2007 rs4. im looking for a throatier sound.
    Drives: 2007 Mercedes CLK550(stock)
    2004 BMW E46 M3(modded)
    2007 Audi RS4(stock)
    Veteran Member Three Rings S4V8's Avatar
    May 19 2010
    Tons to choose from. this has been beaten to death on this forum. Most are "noise maker's" as it seems the stock exhaust fairs quit well on it's own.
    I want an exhaust as well, but am having a tough time deciding between the AWE and Milltek system. Good Luck!
    Dec 05 2006
    So. Cal.
    I love my milltek because of the perfect looking tips and the valves. Te sound is nice also.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    This has been covered but with that said...it depends on what your end goals are and what your personal preference is. If you want performance, leave the OEM manifolds alone they were built quite well and do their job. The downpipes are your enemy so to speak. At a minimum gut the precats or go catless or buy aftermarket DP's with HFC's. If you research DP's you will find various experiences with different manufacturers. Next up is a properly designed cross over or "X" pipe. Research the benefits and what to look for. Pipe diameter and pipe layout are two more important variables. Resonaters - to keep or not to keep. Finally mufflers...you want them to flow well, be light and sound good. There is a great read on this topic, search for JFunkeys write up (I think it was him) it has tons of useful info. Lastly, a tune as you know will help you take advantage of the newly available power you'll have unleashed from helping your exhaust breath easier.
    P.S. JHM is close to releasing a new exhaust set up for the RS4. I'd be patient to see what they came up with before making any decisions. Their proven track record and performance mile stones speak for themselves.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Veteran Member Four Rings Retsujou's Avatar
    Dec 07 2008
    08 RS4 Tit/Exec/Prem/Carbon
    Mississauga
    Quote Originally Posted by S4V8 View Post
    Actually all of them are performance based. I do not know one single RS4 exhaust that cannot give you marginal gains in HP when properly supported. Even the Tubi Rumore are designed as race mufflers as such they have a flow through design and with the right mods they would flow better than the stock mufflers. As everybody else said, please use the search function this has been discussed to death on here and I am partly to blame for it. I spent nearly 13 months researching exhausts and all I can say is that it is a very personal choice based on what you want to achieve. If, by throaty sound, you mean American muscle like, you will not find those type of exhausts unless you do some work on your own. The GMG is a very good suggestion but it has a very unique sound you might not like.
    08 B7 Cherry Black Pearl RS4 + JHM Lightweight Flywheel + JHM Stage III Clutch + VAST Piggie Pipes + K&N High Flow Airfilter + APR Stage II (Testpipe tune) + Hueper Optik 30% + Magnaflow X-Pipe + Centre Resonator Delete + Deflap + HAWK Ceramic front/rear + Stoptech Steel Brake lines + V4 LED Headlights (blackout/clear corner)
    Established Member Two Rings boplaw's Avatar
    Jan 04 2010
    Edge of America
    I bought a non-resonated, non-valved Milltek from an AZ board member and had the tips/cans ceramic coated. I am happy with it.
    I don't think that M3 I went by turning 8k this morning cared for it too much though...
    Oct 11 2007
    Suburbia
    VAST piggies, magnaflow x crossover at end of DP's, center resonator delete w/ straight piping, and milltek tips welded to stock mufflers. My ideal exhaust setup....... Also less than 1K to buy/install while retaining the S button's valving functions.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~
    ~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Bilstein PSS9s~Girodiscs~JHM shifter~
    01' A4 Silver 1.8T Avant 5MT
    ~Motoza Ko4 tune~550cc injectors~Apikol SMIC~3" testpipe~ST coilovers~18" Avuses~
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Capristo with programmable valving system
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Oct 11 2007
    Suburbia
    ^^ If money was no option I would surely spring for that. I just hate the tips, would need to get some Milltek tips instead. BUT, money is no option!
    ~Maxton Aero bits~
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    The Stock RS4 system is nice but with no X its going to have its issues. Power wise ANY high rpm car will pick up and run stronger wiht a crossover..
    Even tho The RS4's have great flowing Dp's the cats still are going to be an issue. that 02 right there measures heat and once that cat gets too hot the ECU will start to pull back power.. The best way to get around this.. take out the Pre cat.
    The guy I sold my RS4 to said he is testing one of the JHM exhaust.. Ill see If I can get some clips from him sould be real exciting
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Dec 07 2008
    Mississauga
    Quote Originally Posted by Alex@Europrice View Post
    Which is a complete waste of money on this engine by the way...
    Veteran Member Four Rings RS4POWER's Avatar
    Jul 19 2008
    2007 RS4
    EC
    Quote Originally Posted by Retsujou View Post
    And you know this how?
    Established Member Two Rings Tweety-s-'s Avatar
    Apr 26 2010
    Audi RS4 b7
    Florence, Italy
    Quote
    ITALIANS DO IT BETTER..... they say!!!!
    Veteran Member Three Rings Brian0473's Avatar
    May 09 2009
    San Antonio, TX
    Quote Originally Posted by RS4POWER View Post
    <Start sarcasm> From my experience on this forum I've found that Retsujou knows everything. </Sarcasm>
    ______________
    Current: '18 Raptor; ‘06 F430; ‘80 Bandit T/A; Porsche Cayenne; ‘95 Ducati SS Custom
    Past: RS4#1 = '07 Misano Red (SOLD); RS4#2 = '07 Phantom Black (SOLD); '08 C63 (SOLD); '09 997.2 Carrera S (RIP); '09 SL63 (SOLD); '92 Spec Miata (SOLD); '10 M3 DCT Coupe (SOLD);
    Jul 19 2008
    2007 RS4
    EC
    Quote Originally Posted by Brian0473 View Post
    <Correction> .... he knows everything about items he doesn't own nor sampled.
    Dec 07 2008
    Mississauga
    I know this because the manufacturer themselves admitted that they only created the variable Valve system to A) comply with Sound regulations that are necessary to pass TueV regulations and B) because they wanted to counteract concerns by people that read about "back pressure" issues with N/A engines. I am more than happy to share the lengthy email threads I have had with Capristo in Germany, unfortunately they are in German. If you want I will translate them though. The engine is considered to be too small in terms of Engine Volume for Back-pressure to really be an issue. That is something many of the other manufacturers such as Tubi will happily verify for you, if you bothered to talk to them.
    I spent nearly 13 months researching exhaust options for my car, do you not think i went over all these concerns when I did the research?
    Dec 07 2008
    Mississauga
    Some more corrections. When I visited my Parents in Germany I actually went and drove the Capristo house RS4. You know the Glut Orange RS4 station Wagon? So do me a favour and do not correct others on what I might know or not know.
    Dec 07 2008
    Mississauga
    Since we are being sarcastic. You are in the wrong forum on the wrong web-site. I am sure there is a Benz forum somewhere for you...
    May 09 2009
    San Antonio, TX
    I didn't know the forum was open only to current RS4 owners...I figured it was open to Audi enthusiasts, prospective buyers, owners, and people who just plain like cars and have an internet connection. The fact is I don't think I have ever seen a post from you which doesn't have attitude written all over it. Do us all a favor, if you're so damn smart help us out! Show us the output of the fountain of knowledge you've acquired relentlessly studying the art of the RS4...and try to be nice about it. Or I guess you could continue getting yourself off by being a big D-Bag all the time.
    ______________
    Veteran Member Four Rings Zac's Avatar
    Mar 26 2010
    B8.5 A4, MK6 Golf R, F30 330I, 06 Explorer
    So Cal
    Tubi all the way!
    Dec 07 2008
    Mississauga
    I think I have helped enough people while being on this board. My Inbox is a testament to that. If you do not approve of my way of writing than that is unfortunate but there is really nothing I can do about it. There is only so much you can convey in writing and tone of voice or body language are sure not any of them. I am very flattered that you obviously have read all my posts since you are judging them all to be laced with attitude. What kind of attitude are you actually referring to? Maybe we should return to the issue at hand, shall we?
    So, please explain to me why a variable valving system is so very important for the V8 in the RS4 when Quattro GMBH themselves only have the valves in place so that they can pass Noise restrictions? That is not a new thing to do for any German Car Manufacturer, Porsche used to have them on the Turbo models for the longest time. I was not attacking Alex, whom I appreciate and he has a business to run, he obviously _wants_ to sell that system and that is his good right. He is a very smart and helpful member of the forum. If you want a variable valve system on you car, go spend the money. There is no indication, none whatsoever, that you will get any performance value out of it.
    In conclusion I would like to state that I am a human being and not a utensil used to clean a female's vagina. But then again I am sure you knew that already,
    To the OP, I am very sorry that this happened. My apologies.
    Veteran Member Three Rings dtoys4.2's Avatar
    Oct 01 2007
    Imola%20RS4%20bagged/500whp%20300zxTT/Gated%20V10%20R8
    queens NYC
    All he wanted to find out was exhaust options. I hate when this happens in threads. Whatever. I have the magnaflow catback on mine. Only thing I would change about it is the tips. Very well made system for the money. Only thing I looked for when I was buying was sound. It was between gmg and magnaflow. Bottom line is If u pay $500 or $5000 for a system they all are gonna give u almost the same gain. Only 1 or 2 hp difference and everybody can agree to that. I like the magnaflow and it sounds nice in my opinion. A lot more quiet than I expected.
    Jul 19 2008
    2007 RS4
    EC
    Being that I own the system and have actually experienced the acoustical effects in every mode I can tell you this is a very well thought out system. Hardware and software need to be installed as instructed by capristo germany so you can absolutely enjoy how the time and craftsmanship that went in to this system.
    Before installing the capristo programable valving system I had the hardware working with the "S" button.
    If you understand how the "S" button works when not depressed the exhaust valves open very high in the rpms.
    When the "S" is depressed the valves are open at idle and once you start accelerating (or revving) they close until 3.5k rpm when they open again. For the stock system which is choked up its not an issue because the difference in sound is minimal. However that is not the story with the capristo. That gap of silence is very annoying and anything but pleasurable. The car would sound great at idle and then would go mum until 3.5k rpm which was a total turn off.
    Capristo has manufactured their own ecu with performance and sound in mind. In all three modes back pressure and sound comes on as the driver pleases. When in "open" mode the sound from idle to wot is linear with no cutoffs and the sound is absolutely intoxicating. I am sure you witnessed this in your visit to Capristo and they enlightened you as to why none of their efforts were a waste of money. They have been making exhaust systems for exotics for a long time. I am sure they would want to keep their expenses down if they truly thought anything was a waste of time and money.
    Again I understand the tough regulations in Germany but the capristo ecu does so much more than satisfy tuev standards.
    I hardly think its a waste of money and everyone should choose to spend their money as they so desire.
    Jul 19 2008
    2007 RS4
    EC
    Quote Originally Posted by dtoys4.2 View Post
    He asked and he should get facts. When members comment on items they know very little about they should be corrected. That would serve the whole community a lot better.
    Exhaust sound is all about preference. I really don't think you can go wrong with any RS4 system and that includes the stocker as well.
    Oct 01 2007
    queens NYC
    Ur right and most parts for cars are all about personal preference. All the cb systems sound good. Do what I did. Listen to as many rs4s I can find with cbs and watch every youtube vid on rs4 exhaust sounds lol
    Active Member Three Rings
    Nov 21 2008
    Romania
    I`m very happy with my awe not resonated system with no cats. Sure it drones. But hey :D
    NAZI MOD FAIL!
    Dec 05 2006
    So. Cal.
    ^^. I love the truth!
    Milltek FTW!
    May 09 2009
    San Antonio, TX
    I had a magnaflow catback. It was cheap (around $700 shipped) and sounded great. I also had an RS4 with down pipes and full Milltek resonated catback which also sounded great, but better (IMO). Not as loud believe it or not and with a more refined tone.
    The bottom line is that on this engine a bunch of hollowed out soup cans taped together would sound good.
    ______________
    May 08 2009
    Southern California
    Here's a vid with the GMG racing exhaust...
    I really like the GMG unit (have it on my car). Gives it some definitely noticeable growl during normal driving and while on the pedal, people can definitely hear you :) No droning or anything either which is always a nice thing when getting an aftermarket exhaust kit. I actually dont think its as loud as the Miltek or the Magnaflow but it does give a very nice refined but aggressive V8 rumble. If at all possible I'd head to a meet somewhere to try and hear the different ones in person. Videos really only do so much as Im sure you know.
    Good luck! And as others have said...gut your precats while your having it installed. Whatever system you get...
    New - 2013 S4 Moonlight Blue Metallic
    Gone But Never Forgotten - 2007 RS4 Phantom Black Pearl - Stasis MS, Hotchkis F/R Sways, Clutchmasters FX300, GMG Exhaust, Piggy Pipes, VMR V710 19x9.5, K&N Drop-in
    Apr 26 2010
    Audi RS4 b7
    Florence, Italy
    How come almost all of you care about sound better than performace???
    Almost all of you just talk about sound, in my opinion if I have to spend a lot of money (as in many cases) in an Exhaust System, first I NEED to be sure to get some HP with it.. then the sound....
    You guys don't care about performance??
    Nov 21 2008
    Romania
    Try to sell them those headers and they`ll care about performance lol :))
    NAZI MOD FAIL!
    Apr 26 2010
    Audi RS4 b7
    Florence, Italy
    Quote Originally Posted by duud40 View Post
    ehehehe ....hopefully soon enough...
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    really? when i cut the cats out of my miltek downpipes i really had NO drone, a lot of noise but none of it was drone
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Nov 21 2008
    Romania
    You`re not doing it right then. :D
    NAZI MOD FAIL!
    Mar 26 2010
    So Cal
    Quote Originally Posted by Tweety-s- View Post
    Because its a RS4 and you really wont gain a whole lot of performance from the stock exhaust. But sound is a whole different ball game, these engines sound just amazing imo and I take advantage of that.
    Aug 07 2008
    Dallas, TX
    This is a really good point. Exhausts on normally aspirated motors won't usually net you a ton of bhp or torque gain, unless the factory exhaust is really restrictive. The sound is honestly the biggest deciding factor when picking an exhaust. That is a personal preference and the best way to pick the exhaust you want on your car is to listen to as many exhausts as you can, in person is best, but via youtube is the easiest way. Performance gains on cars like this are generally small, they do exist, but it isn't going to be anything dramatic. I'd rather not gain 5bhp and have an exhaust which sounds the best to my ears versus having something I personally do not like and gain a few bhp, at best.
    Cheers,
    www.europrice.us
    [email protected]
    Apr 26 2010
    Audi RS4 b7
    Florence, Italy
    Well I gained 18Hp with SuperSprint exhaust system...
    and I don't think 18 hp are peanuts, especially for a car that should have 420hp but in the real world it only stays around 390hp...
    And by the way... GREAT SOUND, does not overlap the sound of the engine (wich I think is the most important thing) but still pretty amazing.
    May 19 2010
    Where can one purchase a SuperSprint Exhaust system?
