Results 1 to 3 of 3
    Active Member Two Rings AudiA4S's Avatar
    Sep 23 2010
    2008 A4 B7 & 2002 Chevy Trailblazer
    Ontario, Canada
    NEED INFO ASAP for STERN UPPER ARMS & CASTER??????
    Guys my alignment guy just called & my cars in on the machine, just installed the Stern uppers but we have no idea what to set the caster at, anyone know???
    These are the spec I have...
    Front Camber -1.2 to 0.04
    Front Toe 0.08 to 0.25
    Front X Camber -0.5 to 0.5
    Front Total Toe 0.17 to .50
    Rear Camber -1.8 to 0.8
    Rear Toe 0.13 to 0.25
    Rear X Camber -0.5 to 0.5
    Rear Total Toe 0.25 to 0.50
    Rear Thrust Angle -0.12 to 0.12
    Caster is not adjustable from factory so there is no spec to go by.
    EDIT: I spoke to someone over at Pure Motorsport & he told me for a daily driver caster should be around 4 to 4.5
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Listen to Mike at PureMS
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Yeah you dont want anything more than 6* of caster, it will cause the tie rod to hit the inner fender well on full lock of the wheel.
    Although from my opinion, when i had caster set to 10* the car felt unbelievable. just couldnt turn to full lock either way. lol
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
