Results 1 to 11 of 11
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    car is misfiring and the mechanic cant figure out what the problem is?
    couple days ago after replacing the cam adjuster seal (half moon) i got a CEL for a lean mixture. So i went to mechanic, turns out it was the hose that goes from the turbo to intercooler which had a hole. So i replaced that, came home and noticed the car started to studder slightly, so i took it for a boot and when i came to park, it was misfiring like crazy and CEL was blinking. So back to the mechanic and we did a lot of stuff to check and we cant figure out whats wrong with it. Here is what i checked let me know if i missed anything.
    -Checked for coilpacks and plugs
    -Checked for vaccuum leaks or other leaks(smoke machine)
    -checked the timing, front and back(since i replaced the seal i thought when he put the chain back the timing was messed, but wasnt)
    -the pressure is good in all cylinders cause we tested it
    i doubt its the cat since i replaced it under warranty from audi earlier this year
    let me know if there is something else i should try, im about to explode.........thanks
    Veteran Member Four Rings bez101's Avatar
    Oct 06 2009
    sheffield
    i see u checked them but id go for coils
    did you scan for codes it should have stored something with the blinking cel
    Jun 22 2009
    Dundalk, MD
    Did you run the codes? Is it isolated to one cylinder?
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    i cant remember my mechanic was doing it but it was throwing misfiring codes, i dont know any more. But we did replace all 4 coilpacks and it still ran the same
    Oct 06 2009
    sheffield
    well the chain could be a link out
    i was a tooth out on the belt and it chucked missfires all cylinders
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    How about you check your spark plugs? I popped a coil in my wifes Jetta just this week and ended up needing to replace the spark plug and coils cause it fauled out since I limped it home. Also I would get a new mechanic period.
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Quote Originally Posted by bez101 View Post
    he checked the chain and it looks correct
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Quote Originally Posted by IVRINGS View Post
    that was done. He put all 4 new coilpacks and spark plugs and it ran the same, theres nothing wrong with the mechanic
    Oct 06 2009
    sheffield
    looking correct and been correct did he use the cam tool to check did he count the links ?
    but if he cant figure it out id get a new mechanic
    Jun 29 2007
    Raleigh, NC
    check the coil ground on the valve cover and make sure it's tight
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Quote Originally Posted by B6Lovin View Post
    Good call.
    CEO and General Manager of the AZ Pedal Responce Team
