Results 1 to 11 of 11
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    rs4 pedal question
    to anyone that did the installs, did u notice that your brake pedal isnt snug? the dead pedal, clutch and gas went on no problem and are a nice tight fit but the brake kinda shimmies around a little bit. last thing i need in an emergency situation is for the brake pedal cover to come off
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    I just did this mod this evening myself and ended up with the same result.
    I don't think it will come off. Just to be sure, I did some test driving on uncrowded roads. Doesn't seem to effect braking ability.
    Seems like it should be tight though! Especially for the BRAKE pedal! I noticed that both the original anmd the RS4 brake pedals have a center rubber tab which inserts into a hole in the center of the actual brake arm and pedal form/support.
    Looking at the original oem brake pedal cover, the design in the way each attaches appears the same?
    Anyone else have any opinion or experience on this? Maybe it will better mold to the base over time?
    Senior Member Two Rings atombomb33's Avatar
    Mar 21 2010
    Los Angeles, CA
    Yes, noticed the same. The brake pedal seems to have a little bit of give up and down. Maybe a couple millimeters but you can notice it with you hand. I can't notice it with my foot. I've pulled quite hard with my hands and it doesn't seem like it is coming off :)
    2019 RS5 Sportback | Glacier White Metallic | Black Optic Carbon Pkg | Black Nappa Leather w/Rock Gray Stitching | RS Driver Assistance Pkg | Dynamic & Dynamic Plus Pkg | 20" Bi-color Titanium Wheels | Bang & Olufsen | Dynamic Steering
    May 12 2010
    '93 F150 PU
    Kansas
    +1 After installing mine, I noticed the brake pedal could be moved by hand a few mm's. I pulled and tugged and twisted to see if it could come off by accident and I see no way that can happen.
    One plus if that with the added thickness on the gas pedal, I think it makes it easier for heel/toe.
    2011 S4 | Premium Plus | Quartz | 6MT | SD | B&O|APR 91 Octane|Carbonio Stage I & II intake|Alu Kreuz|RS4 pedals|JHM Shifter
    gone 2001.5 A4 QMS
    Sep 28 2011
    Valencia, CA
    Regarding the movement of the brake pedal cover, I took it to my Auto Sound-Electronics Guru. He ingeniously applied some black silicone adhesive under it and by the next morning it was tight as a drum.
    It's something that doesn't show but can still be removed if necessary.
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Are we talking about the RS5 pedals? I have them on order at ECS and they will come some day...
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Nov 05 2006
    Fair Lawn
    no... rs4 pedals ...
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Quote Originally Posted by richib86 View Post
    They should be the same as these I hope http://www.ecstuning.com/Audi-B8_S4-...dal/ES2207875/
    Nov 05 2006
    Fair Lawn
    do people on this forum really have that much trouble reading. it's so damn frustrating
    Sep 28 2011
    Valencia, CA
    Tribe:
    The shimmy problem (I believe) is only with the manual brake pedal. My understanding is you would use the RS6 pedal set if you have automatic transmission.
    I am not even sure there is such a thing as RS5 sport pedals and I know they are not made by BMW!
    So you might just want to compare the RS6 oem pedal part numbers listed in David B8's instructions here and confirm with ECS Tuning.
    http://www.audienthusiasts.com/ProjectRS4PedalSwap.html
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Quote Originally Posted by B G 8er View Post
    Tribe:
    Thanks. I just asked ECS tuning and those will fit and are Audi. Don't know what the BMW deal is...
    To the OP; sorry for failing to read that you had a :
    2011 S4, 6 speed, phantom black, black and silver nappa leather, carbon atlas inlays, prestige, B&O, sport diff, titanium package, S4 alu-optics package, JHM short throw, P3 boost gauge, KW V3 coilovers, APR 93 flash, APR pulley, APR CPS, Miltek full res exhaust, AWE intake, tunerdomes LED's, VNSmedia tv simulator, Eurocode headers, BBS CH-R, E-code's, TT-RS steering wheel, RS4 pedals/dead pedal, Eurocode stabilizer bar, RS5 brakes, Ocarbon carbon dash, stvbek CF lip, deval rear CF diffuser
